Home » Modeling » Papyrus » Moka for Papyrus 2018-09 (4.1.X)(Unable to install Moka for Papyrus 2018-09 (4.1.X))
Moka for Papyrus 2018-09 (4.1.X) [message #1799952] Mon, 17 December 2018 17:40 Go to next message
I am non technical user and wanted to use Papyrus and Moka for simulating a process, similar to what is shown in this you tube video titled: [WIP] Modeling and simulation of manufacturing processes with Papyrus and Moka
I installed Eclipse on my Mac. Just the Eclipse Modeling Tools Package.
Then, installed the following plug ins:
- Nebula from http://download.eclipse.org/nebula/releases/2.0.0
- Papyrus 2018-09 (4.1.X) from http://download.eclipse.org/modeling/mdt/papyrus/updates/releases/2018-09
Now, when i try installing Moka plugin from either of the following links, it does not work :
- https://hudson.eclipse.org/papyrus/view/Moka/job/papyrus-moka-neon/lastSuccessfulBuild/artifact/releng/org.eclipse.papyrus.moka.p2/target/repository/
- Moka 2.0.0 -http://download.eclipse.org/modeling/mdt/papyrus/components/moka/oxygen
After referring some older posts, I also tried downloading Orbit Bundles:
http://download.eclipse.org/tools/orbit/downloads/drops/R20180905201904/repository
http://download.eclipse.org/tools/orbit/downloads/drops/R20181128170323/repository
In all of the above cases it gives a dependencies error and/or something to do with specifying target platform for GWT toolkit.
I also went to this link : https://git.eclipse.org/c/papyrus/org.eclipse.papyrus-moka.git/
Here I see a higher version of Moka: org.eclipse.papyrus-moka-3.1.0.tar.gz but the download weblink is unavailable and I am technically savvy to download this directly.
Can some one please guide me as what needs to be done to fix this problem or alternately, if you know any better alternates for Moka, please let me know.
Hussain
Note: Older posts I have already to are as follows:
https://wiki.eclipse.org/Papyrus/UserGuide/ModelExecution
https://www.eclipse.org/forums/index.php/t/1088998/
https://www.eclipse.org/forums/index.php/t/1094406/
https://www.eclipse.org/forums/index.php/t/1088467/
Re: Moka for Papyrus 2018-09 (4.1.X) [message #1800039 is a reply to message #1799952] Wed, 19 December 2018 04:48 Go to previous messageGo to next message
Hi Hussain,
I think the problem you had was that you tried to install a neon/oxygen version of Moka in a 2018-09 version of the IDE. You should get the latest Moka version (thought not yet published it seems) throught this update site:
https://ci.eclipse.org/papyrus/view/Moka/job/papyrus-moka-master/lastSuccessfulBuild/artifact/releng/org.eclipse.papyrus.moka.p2/target/repository/
I'll see with the Moka team if they can squeeze a release in their timetable but this should work for you (it did for me with a fresh 2018-09 committer version + Papyrus 2018-09 and the provided moka p2 repository which is built against 2018-09)
HTH,
Quentin
Re: Moka for Papyrus 2018-09 (4.1.X) [message #1800176 is a reply to message #1800039] Thu, 20 December 2018 18:07 Go to previous message
Hi Quentin,
Many many thanks !. It worked. It gave me the below warning, I ignored it and went ahead with installation. I hope it is alright.
"You are installing software that contains unsigned content. The authencity or validity of this software cannot be established. Do you want to continue with the installation ? "
Now, I need to start using Papyrus-Moka. Therefore, I have one more questions-
The his you tube video titled: "[WIP] Modeling and simulation of manufacturing processes with Papyrus and Moka", was really good in demonstrating the final outcome of simulation. Would you know of any tutorial that shows how do this from scratch starting with defining a UML activity and ending with Simulating the process ?
Hussain
Previous Topic:Installing Papyrus Moka in Eclipse Photon
Next Topic:Class Diagram - Class Constructor
Current Time: Sat Jul 26 03:11:32 EDT 2025
Powered by FUDForum. Page generated in 0.07475 seconds
