Re: Export current Eclipse installation to *.setup file [message #1580569 is a reply to message #1580437] |
Fri, 23 January 2015 15:27 |
Hi Thomas,
We haven't developed anything that automatically derives a setup file from an existing installation. We plan to do that
as part of our commercial offering that's hopefully coming soon. In the meantime you can use a trick to author the
P2Director task(s) for your setup file quite easily. Open the new "Repository Explorer" view in Eclipse and your
system's file manager (e.g., Windows Explorer), then find your installations profile folder under your p2 agent folder
(e.g., file:/C:/Users/Stepper/.p2/org.eclipse.equinox.p2.engine/profileRegistry/C__develop_oomph_eclipse.profile), drag
it and drop it on the Repository Explorer's URL combo box. You should see all the features/IUs in your current
installation and be able to drag them and drop them into your setup file's P2Director task(s). I hope that helps ;-)
Cheers
/Eike
http://www.esc-net.de
Am 23.01.2015 um 14:48 schrieb Thomas Laegler:
> Hi folks.
> I'm a little familar with Oomph especially as consumer of *.setup files to setup my eclipse installation.
> I have a properly set up eclipse installation with workspace, git, projects and tons of good plugins. Now, the problem
> is, that I want to backup this current Eclipse installation so that I'm able to install the same installation on
> another pc.
> So here is my question to the community: Is there an easy and fast way to export the my current Eclipse installation
> with all that stuff to a *.setup file? Or do I have to add all the p2-repos, plugins, projects etc. pp. manually into
> my *.setup file?
> Thanks and greets :) Thomas
Cheers
/Eike
Re: Export current Eclipse installation to *.setup file [message #1725564 is a reply to message #1725560] |
Fri, 04 March 2016 12:57 |
Ed Merks Messages: 33141 Registered: July 2009 |
Abel,
The bottom part of that view has versions for the selected IU. With the
check and radio buttons you can influence what range is represented, and
you can drag and drop those to get the range you want.
On 04.03.2016 13:25, Abel Hegedus wrote:
> You can find the context through the Eclipse Forums:
> https://www.eclipse.org/forums/index.php/t/959921/
> However, for your convenience, Eike wrote the following before Peter's
> post as an answer to Thomas:
> Quote:
>> from an existing installation. We plan to do that as part of our
>> can use a trick to author the P2Director task(s) for your setup file
>> your system's file manager (e.g., Windows Explorer), then find your
>> installations profile folder under your p2 agent folder (e.g.,
>> drag it and drop it on the Repository Explorer's URL combo box. You
>> should see all the features/IUs in your current installation and be
>> task(s). I hope that helps ;)
Ed Merks
FUDForum. Page generated in 0.04548 seconds
