Home » Archived » BIRT » Report Engine API
Report Engine API [message #250384] Mon, 30 July 2007 10:16 Go to next message
i am searching the Report Engine API for Version 2.2.
I found the Api for Version 2.1:
http://help.eclipse.org/help31/index.jsp?topic=/org.eclipse. birt.doc/engine/api/org/eclipse/birt/report/engine/api/Repor tEngine.html
Ich tried to replace "help31" with "help33" without success. Where can i
find the api for the Birt Report Engine 2.2? Better would be, where can
download the Api 2.2 for offline work. In the birt-runtime-2.2.0.zip
file, there is no documentation.
Thx
Orkus
Re: Report Engine API [message #250400 is a reply to message #250384] Mon, 30 July 2007 11:29 Go to previous messageGo to next message
Getting the help can be a real pain.
I found out just downloading the Birt Project from the Discovery site
doesn't work either.
What does work is downloading the all-in-one download and starting from
there.
Once you have the all-in-one download from inside Eclipse go to
Help->Help Contents, you'll then find the BIRT Programming Reference in
the Contents window.
Maybe the dev team could look into adding the help to packages other
than the all-in-one?
Hope that helps.
Orkus wrote:
> Thx
> Orkus
Re: Report Engine API [message #250404 is a reply to message #250384] Mon, 30 July 2007 12:00 Go to previous messageGo to next message
Orkus,
Have you looked in the allinone download help?
The API docs are listed under the BIRT Programmer Reference.
Jason
Orkus wrote:
> Thx
> Orkus
Re: Report Engine API [message #250487 is a reply to message #250404] Tue, 31 July 2007 02:42 Go to previous messageGo to next message
Do you mean this page
http://www.eclipse.org/birt/phoenix/ref/rom/index.html ?
It seems to be also "old", cause the Class "ScalarParameter"
http://www.eclipse.org/birt/phoenix/ref/rom/elements/ScalarP arameter.html
has not the method "isRequired" like in Report Engine 2.2.
What do you mean with "allinone download"? Do you mean Birt + Eclipse in
one? In "birt-report-designer-all-in-one-linux-gtk-2_2_0.tar.gz" i found
no report engine Documentation or API.
Jason Weathersby schrieb:
> Orkus,
> Jason
> Orkus wrote:
>> i find the api for the Birt Report Engine 2.2? Better would be, where
>> can download the Api 2.2 for offline work. In the
>> birt-runtime-2.2.0.zip file, there is no documentation.
>> Thx
>> Orkus
Re: Report Engine API [message #250491 is a reply to message #250400] Tue, 31 July 2007 02:51 Go to previous messageGo to next message
Thx. At Help->Help Contents i found it.
> there.
> Hope that helps.
> Orkus wrote:
>> Thx
>> Orkus
Re: Report Engine API [message #250571 is a reply to message #250487] Tue, 31 July 2007 13:07 Go to previous message
Orkus,
i was referring to the help contents within the allinone designer download.
Jason
>> Orkus,
>> Jason
>> Orkus wrote:
>>> Hi,
>>> can i find the api for the Birt Report Engine 2.2? Better would be,
>>> where can download the Api 2.2 for offline work. In the
>>> Thx
>>> Orkus
Previous Topic:BIRT cannot load the JDBC Driver
Next Topic:Connecting to Oracle
Current Time: Sun Nov 09 12:36:23 EST 2025
Powered by FUDForum. Page generated in 0.04420 seconds
