Re: Zest: Hints about Integrating Context Menus / New Connections? [message #240721 is a reply to message #240649] |
Tue, 15 January 2008 05:04 |
Originally posted by: irbull.cs.uvic.ca
The context menu should be pretty easy. In the PDE Viz viewer [1] I
added one simply on the view:
[1] http://www.eclipse.org/pde/incubator/dependency-visualizatio n/
Actually, this would be a pretty good example of some stuff you can do
in Zest.
As for adding new connections, drawing them (i.e. with a palette) opens
up a whole can of worms. Actually, if you want to add connections, then
what about nodes? This is really what GEF is ideal at. If you want to
add them "programmatically", this shouldn't be to hard. (Just create a
new GraphConnection).
ian
Miles Parker wrote:
> Ian et. al..
> Thanks for your pointers -- worked perfectly!
> I'm liking the speed and ease of development enough that I'm thinking of
> using as a suplementary editor. I'm pretty confident I can wire in a
> context menu easily but not so confident about drawing new connections.
> Is this way outside of the Zest usage target?
Re: Zest: Hints about Integrating Context Menus / New Connections? [message #240975 is a reply to message #240721] |
Sun, 27 January 2008 02:13 |
Miles Parker Messages: 1341 Registered: July 2009 |
Yep, got it.. actually I have some minor issues with integration with
the EMF editor but that has nothing to do with Zest...
> then what about nodes? This is really what GEF is ideal at. If you
> want to add them "programmatically", this shouldn't be to hard. (Just
> create a new GraphConnection).
Yeah, the whole palette thing is exactly what I was hoping to avoid. :)
(OTOH I really like the simple check-boxes and so on you have for the
PDE vis.) Elegant to develop == elegant for users, I think. My agenda
with these tools is precisely to avoid the kind of fiddly UML ish or
every-possible-situation-covered GMF stuff -- not that that isn't great
but its just too heavyweight. I'm aiming for an auto-layout kind of
situation where people can highlight and move nodes around to visualize
thigns but none of that is persisted. Context menus already support the
creation of nodes, so I really am thinking of some kind of
shift-drag-click thing. But I assume that I can do that very simply by
listening for a key-mod mouse-click on source, perhaps creating a
tracking arrow figure, and taking the target from the node at mouse
release, if any.
FUDForum. Page generated in 0.02964 seconds
