Home » Newcomers » Newcomers » how to import new SSL cert into existing default keystore?(how to import new SSL cert into existing default keystore?)
how to import new SSL cert into existing default keystore? [message #1244784] Wed, 12 February 2014 17:09 Go to next message
Im following the steps here:
http://www.eclipse.org/jetty/documentation/current/configuring-ssl.html
Im trying to add ssl cert into an existing jetty implementation that already has self-signed cert and working SSL connector/factory. I converted my key, cert, and intermediate cert into pkcs12 as per eclipse wiki, and imported that into existing keystore using the storepwd password, no errors so far, but upon starting my .jar it crashes with "java.lang.reflect.InvocationTargetException" caused by "Caused by: java.security.UnrecoverableKeyException: Cannot recover key"
the new key did seem to get put into that existing keystore:
# keytool -list -keystore ./keystore
Enter keystore password:
Keystore type: JKS
Keystore provider: SUN
Your keystore contains 1 entry
1, Feb 12, 2014, PrivateKeyEntry,
Certificate fingerprint (SHA1): 0B:50:A2:84:81:4A:9C:15:42:6C:19:30:13:98:1D:B2:53:B6:C4:B1
at org.eclipse.jetty.start.Main.invokeMain(Main.java:297)
at org.eclipse.jetty.start.Main.start(Main.java:724)
at org.eclipse.jetty.start.Main.main(Main.java:103)
at sun.security.provider.KeyProtector.recover(Unknown Source)
at sun.security.provider.JavaKeyStore.engineGetKey(Unknown Source)
at sun.security.provider.JavaKeyStore$JKS.engineGetKey(Unknown Source)
at java.security.KeyStore.getKey(Unknown Source)
at sun.security.ssl.SunX509KeyManagerImpl.<init>(Unknown Source)
at sun.security.ssl.KeyManagerFactoryImpl$SunX509.engineInit(Unknown Source)
at javax.net.ssl.KeyManagerFactory.init(Unknown Source)
at org.eclipse.jetty.util.ssl.SslContextFactory.getKeyManagers(SslContextFactory.java:904)
at org.eclipse.jetty.util.ssl.SslContextFactory.doStart(SslContextFactory.java:297)
at org.eclipse.jetty.util.component.AbstractLifeCycle.start(AbstractLifeCycle.java:69)
at org.eclipse.jetty.util.component.ContainerLifeCycle.start(ContainerLifeCycle.java:117)
at org.eclipse.jetty.util.component.ContainerLifeCycle.doStart(ContainerLifeCycle.java:99)
at org.eclipse.jetty.server.SslConnectionFactory.doStart(SslConnectionFactory.java:64)
at org.eclipse.jetty.server.AbstractConnector.doStart(AbstractConnector.java:259)
at org.eclipse.jetty.server.AbstractNetworkConnector.doStart(AbstractNetworkConnector.java:81)
at org.eclipse.jetty.server.ServerConnector.doStart(ServerConnector.java:218)
at org.eclipse.jetty.server.Server.doStart(Server.java:336)
at org.eclipse.jetty.xml.XmlConfiguration$1.run(XmlConfiguration.java:1250)
at org.eclipse.jetty.xml.XmlConfiguration.main(XmlConfiguration.java:1174)
... 7 more
Re: how to import new SSL cert into existing default keystore? [message #1245410 is a reply to message #1244784] Thu, 13 February 2014 14:27 Go to previous message
for anyone else with this issue, Ive found the problem. the examples from
https://wiki.eclipse.org/Jetty/Howto/Configure_SSL#Configuring_Jetty
have this
<Call name="addConnector">
<Arg>
<New class="org.eclipse.jetty.server.ssl.SslSelectChannelConnector">
<Arg>
<New class="org.eclipse.jetty.http.ssl.SslContextFactory">
<Set name="keyStore"><SystemProperty name="jetty.home" default="." />/etc/keystore</Set>
<Set name="keyStorePassword">OBF:1vny1zlo1x8e1vnw1vn61x8g1zlu1vn4</Set>
<Set name="keyManagerPassword">OBF:1u2u1wml1z7s1z7a1wnl1u2g</Set>
<Set name="trustStore"><SystemProperty name="jetty.home" default="." />/etc/keystore</Set>
<Set name="trustStorePassword">OBF:1vny1zlo1x8e1vnw1vn61x8g1zlu1vn4</Set>
</New>
</Arg>
<Set name="port">8443</Set>
<Set name="maxIdleTime">30000</Set>
</New>
</Arg>
</Call>
and a keen eye will see that the keymanager password is different than the other 2. I just took out all keymanager/truststore stuff as then they inherit the config from keystore. now my cert works.
Previous Topic:Compare function like in WinMerge
Next Topic:Check for Update fails
Current Time: Tue Sep 23 05:27:44 EDT 2025
Powered by FUDForum. Page generated in 0.08794 seconds
