wizard and splash logon before an app runs [message #15465] |
Mon, 19 January 2009 16:29 |
Marc Messages: 32 Registered: July 2009 |
Member |
Hi all,
This post follows one I sent to the old mailing list, but Ketan has gently
redirected me to the rigth place.
I wasn't able to run swtbot on my app while it was running well on rcpmail
example.
Before the "heart" of my app runs, there is first some configuration
wizard to fill and then a login/password splash screen.
1)
[extract]
org.eclipse.jface.wizard.WizardDialog
WizardDialog dialog = new CustomWizardDialog(null, theWizard);
dialog.open();
In another thread "can SWTBot 2.0 test a wizard?" on this ML, it seems a
wizard can be tested.
But swtbot does not run when the wizard is opened.
May it be a problem that the wizard is launched before anything else in my
app?
2)splash
import org.eclipse.ui.splash.AbstractSplashHandler;
public class SplashHandler extends AbstractSplashHandler
splashHandler is set as an extension for the app
(http://pookzilla.net/wp/2007/01/i-want-to-tell-you-story-i/),
not called from code.
I modified the source code to skip the wizard.
Now, if I launch my app through swtbot...
the splash login popup will not display (?), but my app's main screen
shows up and swtbot is running!
The splashHandler seems not loaded when the app is called from swtbot.
Does it have to do with swtbot?
Thanks for your time,
Marc
FUDForum. Page generated in 0.04132 seconds
