Home » Eclipse Projects » SWTBot » How to click on toolbar dropdown menu item using SWTBOT
How to click on toolbar dropdown menu item using SWTBOT [message #1033456] Thu, 04 April 2013 04:42 Go to next message
I am trying to automate the functional testcase of RCP application which requirs to click on menu item from the toolbar dropdown menu. I tried below snippet but it didn't worked, it just clicked on the dropdown menu but menuItems are not getting displayed. Same things works correctly when exeuted manually.
SWTBotToolbarDropDownButton myDropdown = getBot().toolbarDropDownButtonWithTooltip( "My Dropdown" );
SWTBotMenu showMenuItem = myDropdown.menuItem( "Show" );
showMenuItem.click();
This is how the dropdown menu in view toolbar
index.php/fa/14232/0/
and menu items in this menu are
index.php/fa/14233/0/
But when executing the SWTBOT testcase to click 'Show' menu item using above code I am getting the dropdown menu as
index.php/fa/14238/0/
Can some one suggest what might be wrong in above code or is there other way to do this ?
Amruta
Re: How to click on toolbar dropdown menu item using SWTBOT [message #1037071 is a reply to message #1033456] Tue, 09 April 2013 02:27 Go to previous messageGo to next message
Is you application based on Eclipse 4.x ? I think you are hitting this
bug: https://bugs.eclipse.org/bugs/show_bug.cgi?id=388306
A change in implementation of menus in Eclipse 4 makes that the sequence
of events generated by SWTBot for some menus does not populate the menu.
I'd really glad if you could have a look to this bug, and maybe provide
a patch or any contribution that would help to get it fixed.
Mickael Istria
JBoss, by Red Hat
My blog: http://mickaelistria.wordpress.com
My Tweets: http://twitter.com/mickaelistria
Re: How to click on toolbar dropdown menu item using SWTBOT [message #1758589 is a reply to message #1037071] Thu, 30 March 2017 07:16 Go to previous messageGo to next message
Is there a trick to close the shell that has been opened by the toolbar drop down button? I tried ESC but probably at the wrong location.
Re: How to click on toolbar dropdown menu item using SWTBOT [message #1758801 is a reply to message #1758589] Mon, 03 April 2017 06:42 Go to previous messageGo to next message
Have you tried sending ESC on the toolbarbutton itself?
The following code works for me.
SWTBotToolbarDropDownButton b = bot.toolbarDropDownButtonWithTooltip("tooltip");
b.menuItem("menu").click();
b.pressShortcut(Keystrokes.ESC);
Re: How to click on toolbar dropdown menu item using SWTBOT [message #1758811 is a reply to message #1758801] Mon, 03 April 2017 08:37 Go to previous message
Aparna Argade wrote on Mon, 03 April 2017 10:42
That's what I am doing currently but the drop down does not close. It's still open and stays open (Oxygen using SWTBot snapshots). I've opened https://bugs.eclipse.org/514687 with a reproducible test for further investigation.
[Updated on: Tue, 04 April 2017 07:32] by Moderator
Previous Topic:Execute SWTBot in running IDE
Next Topic:SWTBot support for Nebula TableCombo?
Current Time: Mon Jun 23 12:57:59 EDT 2025
Powered by FUDForum. Page generated in 0.09924 seconds
