Home » Modeling » TMF (Xtext) » Kepler TypeNotFoundException
Kepler TypeNotFoundException [message #1007731] Thu, 07 February 2013 05:52 Go to next message
Is Kepler for usage with Xtext?
I get this error on a new Xtext project and on an old one:
0 [main] ERROR mf.mwe2.launch.runtime.Mwe2Launcher - com.google.inject.internal.ComputationException: com.google.inject.internal.ComputationException: java.lang.NoClassDefFoundError: org/eclipse/xtext/common/types/access/TypeNotFoundException
com.google.inject.internal.ComputationException: com.google.inject.internal.ComputationException: com.google.inject.internal.ComputationException: java.lang.NoClassDefFoundError: org/eclipse/xtext/common/types/access/TypeNotFoundException
at com.google.inject.internal.MapMaker$StrategyImpl.compute(MapMaker.java:553)
at com.google.inject.internal.MapMaker$StrategyImpl.compute(MapMaker.java:419)
at com.google.inject.internal.CustomConcurrentHashMap$ComputingImpl.get(CustomConcurrentHashMap.java:2041)
at com.google.inject.internal.FailableCache.get(FailableCache.java:46)
at com.google.inject.ConstructorInjectorStore.get(ConstructorInjectorStore.java:52)
at com.google.inject.ConstructorBindingImpl.initialize(ConstructorBindingImpl.java:57)
at com.google.inject.InjectorImpl.initializeBinding(InjectorImpl.java:377)
at com.google.inject.BindingProcessor$1$1.run(BindingProcessor.java:169)
at com.google.inject.BindingProcessor.initializeBindings(BindingProcessor.java:224)
at com.google.inject.InjectorBuilder.initializeStatically(InjectorBuilder.java:120)
at com.google.inject.InjectorBuilder.build(InjectorBuilder.java:105)
Re: Kepler TypeNotFoundException [message #1007799 is a reply to message #1007731] Thu, 07 February 2013 09:20 Go to previous messageGo to next message
Hi Christophe,
Xtext is tested on top of Kepler, so yes, Xtext is kepler compatible.
Which version of Xtext are you using? How do you install Xtext (which features are installed)?
Dennis.
Re: Kepler TypeNotFoundException [message #1007805 is a reply to message #1007799] Thu, 07 February 2013 09:52 Go to previous messageGo to next message
I found the problem. It turns out if you have your own target definition, the plugins in it need to match the .mwe2 version in the Eclipse install. So MWE2.launch is taken from the target.
Works like a charm now on keppler with xtext 2.4/Mwe 2.4.
Thanks.
Re: Kepler TypeNotFoundException [message #1572113 is a reply to message #1007805] Sun, 18 January 2015 20:54 Go to previous messageGo to next message
If you're still around, can you explain how you did it?
Re: Kepler TypeNotFoundException [message #1573662 is a reply to message #1572113] Mon, 19 January 2015 16:51 Go to previous message
I'm interested too.
I have a project working well with Keppler and Xtext 2.5 but I am currently trying out Mars and what appears to be Xtext 2.8 (according to the plugins) even though the 2.8 release appears to be scheduled for 19 May 2015, and get the same exception (see other thread: https://www.eclipse.org/forums/index.php/t/933092/ )
Previous Topic:Embedded languages
Next Topic:Error "Cyclic linking detected" in editor window
Current Time: Sat Nov 08 12:17:03 EST 2025
Powered by FUDForum. Page generated in 0.03190 seconds
