Re: PDE support for running tests in a separate thread [message #36244 is a reply to message #12148] |
Fri, 22 May 2009 14:04 |
Originally posted by: jlp.maconomy.com
I noticed that the PDE fix was made for 3.5M5. Does the newest version
of SWTBOT depend on this fix being available? The reason I ask is that I
just installed version 2.0.0.316-dev. Launching that from Eclipse 3.4
seems to force SWTBOT to run on the UI thread. The other team members in
my team experience that SWTBOT does NOT run on the UI thread - they are
using version 2.0.0.204-dev.
-- Jakob.
Re: PDE support for running tests in a separate thread [message #36309 is a reply to message #36276] |
Fri, 22 May 2009 14:33 |
Hi Ketan,
Yeah, I do that, actually. So, are there any other explanations why it
looks like my tests are run on the UI thread?
Jakob.
Ketan Padegaonkar wrote:
> You need to run the tests SWTBot tests not PDE-junit tests.
> -- Ketan
>> -- Jakob.
Re: PDE support for running tests in a separate thread [message #36620 is a reply to message #36341] |
Mon, 25 May 2009 07:04 |
Yes, it returns a non-null value.
And Display.getCurrent() also returns a non-null value (meaning that the
current thread is the UI thread). (I guess getDefault() always returns a
non-null value?)
Jakob.
> Does Display.getDefault() inside the test give you a non-null value ?
> -- Ketan
> On 22/5/09 20:03, Jakob Lyng Petersen wrote:
>> Hi Ketan,
>> Jakob.
>>> -- Ketan
>>>> that I
>>>> members in
>>>> -- Jakob.
Re: PDE support for running tests in a separate thread [message #36654 is a reply to message #36620] |
Mon, 25 May 2009 07:37 |
Actually, I found the work-around in another thread in this newsgroup:
You have to add the following command-line argument to the
runtime-configuration (even if it runs as an SWTBot Test):
-application org.eclipse.swtbot.eclipse.core.swtbottestapplication
(see the tread "New SWTBot Release"(
--Jakob.
> non-null value?)
> Jakob.
>> -- Ketan
>>> Hi Ketan,
>>> Jakob.
>>>> -- Ketan
>>>>> that I
>>>>> members in
>>>>> are
>>>>> -- Jakob.
Re: PDE support for running tests in a separate thread [message #36722 is a reply to message #36654] |
Mon, 25 May 2009 10:13 |
Ketan Padegaonkar Messages: 873 Registered: July 2009 |
I've fixed this in the latest build available on the update site.
-- Ketan
> --Jakob.
>> the current thread is the UI thread). (I guess getDefault() always
>> returns a non-null value?)
>> Jakob.
>>> -- Ketan
>>>> Hi Ketan,
>>>> Jakob.
>>>>> -- Ketan
>>>>>> version
>>>>>> that I
>>>>>> members in
>>>>>> they are
>>>>>> -- Jakob.
Re: PDE support for running tests in a separate thread [message #36756 is a reply to message #36654] |
-- Ketan
> --Jakob.
>> Jakob.
>>> -- Ketan
>>>> Hi Ketan,
>>>> Jakob.
>>>>> -- Ketan
>>>>>> version
>>>>>> that I
>>>>>> members in
>>>>>> they are
>>>>>> -- Jakob.
FUDForum. Page generated in 0.03719 seconds
