Re: Run SWT Bot outside of Eclipse [message #11980 is a reply to message #11942] |
Fri, 19 December 2008 10:54 |
Ketan Padegaonkar Messages: 873 Registered: July 2009 |
Renat,
This is already available. If you're in a hurry and want to use the
existing SWTBot at sf.net, just use the patched
eclipse-test-framework[1] and the build scripts available in svn[2] (the
"swtbot-test" target).
In order to run, you'll need to extract the eclipse-test-framework[1],
swtbot.finder and swtbot.eclipse.finder plugins into the eclipse
instance you want to test.
I'm hoping to clean up the eclipse-test-framework so that it works
without a patch, and you should be able to use SWTBot on cruise or
developer machines from within ant.
[1] -
https://swtbot.svn.sourceforge.net/svnroot/swtbot/branches/j ava-1.5-api-spike/org.eclipse.swtbot.releng/test-sandbox/ecl ipse-test-framework-3.3.zip
[2] -
https://swtbot.svn.sourceforge.net/svnroot/swtbot/branches/j ava-1.5-api-spike/org.eclipse.swtbot.releng/test-sandbox/org .eclipse.swtbot.eclipse.finder.test.xml
-- Ketan
On 19/12/08 15:01, Renat Zubairov wrote:
> Hello All,
> We really liked the SWT Bot approach for automated UI testing, however we
> can't really find out how to run the SWT Bot tests outside of Eclipse.
> As a good adopers of Agile SW priniciples we would like to run SWT Bot tests
> as a part of our automated acceptance tests therefore we would need to
> somehow automate transfer of compiled test code to the automated acceptance
> test run envirnoment and run it from there.
> What also be nice to have is to allow users who has a source code of our
> system ability to run SWT Bot driven tests directly on their computers, i.e.
> Checkout source code from SVN, and run a build which will also trigger
> automatic acceptance tests. We are using maven, maven2 and ant for building
> environment.
> Thanks!
> Renat
FUDForum. Page generated in 0.04224 seconds
