| TPTP issues [message #102239] |
Mon, 02 July 2007 07:57  |
I'm part of team which is starting to develop some testing application. We
want to bulid our solution on TPTP. Currenty I'm using Eclipse 3.3 with
all TPTP Runtimes and SDKs v.4.4. I focus on TPTP Testing project.
After some time of investigation I wasn't able to solve these problems:
1. Where can I find source code for
org.eclipse.hyades.test.core_4.2.200.v200706050100 plugin? I'd expect
plugin org.eclipse.hyades.test.core.source in TPTP Test SDK, but I can't
see anything like this in there. It would be nice to trace the code.
2. How can I know which jars I have to add to my Java project reference to
be able to run example of TestExecutionHarness class presented in javadoc
in this link
http://europa-mirror2.eclipse.org/tptp/4.3.0/javadoc/Testing _Tools/public/org/eclipse/hyades/execution/harness/TestExecu tionHarness.html#main
I bypass this problem by creating Eclipse plugin project and by adding all
TPTP Platform and Testing plugins into Required plugins section but this
is a bit hardcore approach I guess.
Thanks for your help.
Jiri
| Re: TPTP issues [message #102547 is a reply to message #102482] |
Tue, 03 July 2007 08:35  |
Hi Jiri,
https://bugs.eclipse.org/bugs/show_bug.cgi?id=195148 will address this
issue for the 4.4 release. I believe you have an install problem with
4.3.1 -- the source zips are in the SDK download, and I just verified by
stepping into TPTP code from a 4.3.1 driver. The source is there. You
won't get the source by installing from the update manager -- if you
want to be certain, download a fresh eclipse (3.2.2) and the necessary
dependencies, along with the SDK download from the TPTP download page:
http://www.eclipse.org/tptp/home/downloads/?ver=4.3.1
I expect we will get more information on the resolution of 195148 when
my colleagues in Toronto return from holiday. Hopefully this will be
something they can address quickly. I have marked the defect as
critical, but like most release engineering teams, ours is understaffed
and overworked. Please monitor the defect to kept informed of the progress.
--Joe
Jiri Bjalek wrote:
> Hello again,
> thanks for your answers, it looks promising to me. But anyway I'm facing
> another problem you can hopefully help me with.
> I can't see any source code when I try to explore any class from TPTP
> framework in Eclipse. In other words just Class File Editor shows with
> information that there is no source attached to it.
> As I said before I'm using Eclipse SDK 3.3 with TPTP SDK 4.4.0 now, but
> I had this problem before when trying this on Eclipse 3.2 with TPTP SDK
> 4.3.1 or 4.3.0.
> The only way I'm able to get class - source binding is to checkout
> needed project from CVS repository to my current workspace. And this is
> far from ideal for me. I tried to install TPTP by install manager or by
> manual way with the same results. Everyting seems all right by I can't
> see the source code for TPTP classes.
> Jiri
FUDForum. Page generated in 0.03570 seconds
