Problem with RadioGroupFieldEditor [message #723002] |
Wed, 07 September 2011 12:09 |
michal.anglart Messages: 1 Registered: September 2011 |
I have a SWTBot test for our RCP application (based on 3.6) which doesn't work correctly, but only under linux. Scenario is as follows:
- open preferences
- change some value in RadioGroupFieldEditor
- save preferences
- do something which depends on changed preference
Test fails passes under windows, but fails under linux. After investigation I found out that:
I have a RadioGroupFieldEditor with few options:
- Option 1
- Option 2
- Option 3 ...
when preferences page is loaded "Option 1" is selected, then SWTBot changes it to "Option 2"; after clicking OK I try to get preference and it returns "Option 1". This happens because of selection listener in RadioGroupFieldEditor (line 268) - the events comes in wrong order: first there is an event for selecting "Option 2", so 'value' field of this object changes properly, but then an event for unselecting "Option 1" comes and 'value' field changes once again to "Option 1".
This only happens under linux and only with SWTBots. When I'm clicking it on my own under linux the events comes in proper order and everything is fine.
Any ideas? Is it a bug or am I doing something wrong?
Michal
FUDForum. Page generated in 0.03922 seconds
