| how to get screenshots, logger messages into results/${class-name}.html file? [message #648081] |
Tue, 11 January 2011 02:23 |
I'm using swtbot for last 2/3 months and had a good experience using it. I use headless test framework and I get .html, .txt and .xml in 'results' folder.
I often generate screenshots, logger messages to analyze failures. I got the screenshots in 'results' folder by specifying the folder name along with filename. I also generated logger output in 'results' folder by editing log4j.xml. But in this setup, all the things are scattered in different files.
I want to have a consolidated html report in which I should see all the things (screenshots, logger messages and standard html output with test pass/fail status etc.) in a single file.
That would be very easy to analyze the failure when you have lot many tests. Currently I've to first look at the .html. If there a failure then I've to open logger messages output file. I also need to open screenshots files side by side and then I can analyze the failure reason. It would be great help if all such things come in a single file.
I looked at JUNIT.XSL, library.xml in org.eclipse.swtbot.eclipse.junit4.headles_xxxx folder. But doing changes in those files seems difficult.
Is there any known standard method to get consolidated report including screenshots, logger output and html standard output?
FUDForum. Page generated in 0.03026 seconds
