Re: Problem in installing the Eclipse Memory Analyzer [message #648397 is a reply to message #638378] |
Wed, 12 January 2011 17:29 |
Philippe EUGENE Messages: 58 Registered: January 2011 |
Member |
I just download the stand-alone version of MAT (release 1.0.1 and 1.0.0).
When i try to launch the product i obtain the stacktrace below ( at the launch of the RCP app).
The archive on the donwload page are OK ?
Thanks for reply.
!SESSION 2011-01-12 18:13:43.956 -----------------------------------------------
eclipse.buildId=unknown
java.version=1.4.2_03
BootLoader constants: OS=win32, ARCH=x86, WS=win32, NL=fr_FR
Command-line arguments: -os win32 -ws win32 -arch x86
!ENTRY org.eclipse.equinox.app 0 0 2011-01-12 18:13:44.519
!MESSAGE Product org.eclipse.mat.ui.rcp.MemoryAnalyzer could not be found.
!ENTRY org.eclipse.osgi 4 0 2011-01-12 18:13:44.550
!MESSAGE Application error
!STACK 1
java.lang.RuntimeException: No application id has been found.
at org.eclipse.equinox.internal.app.EclipseAppContainer.startDe faultApp(EclipseAppContainer.java:236)
at org.eclipse.equinox.internal.app.MainApplicationLauncher.run (MainApplicationLauncher.java:29)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .runApplication(EclipseAppLauncher.java:110)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .start(EclipseAppLauncher.java:79)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:368)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:179)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java: 559)
!ENTRY org.eclipse.osgi 2 0 2011-01-12 18:13:44.628
!MESSAGE One or more bundles are not resolved because the following root constraints are not resolved:
!SUBENTRY 1 org.eclipse.osgi 2 0 2011-01-12 18:13:44.628
!MESSAGE Bundle update@plugins/org.eclipse.mat.jdt_1.0.1.201008091353.jar was not resolved.
!SUBENTRY 2 org.eclipse.mat.jdt 2 0 2011-01-12 18:13:44.628
!MESSAGE Missing required bundle org.eclipse.jdt.ui_0.0.0.
!MESSAGE Missing required bundle org.eclipse.jdt.core_0.0.0.
!MESSAGE The following is a complete list of bundles which are not resolved, see the prior log entry for the root cause if it exists:
!MESSAGE Bundle org.eclipse.birt.chart.device.extension_2.5.0.v20090514 [15] was not resolved.
!SUBENTRY 2 org.eclipse.birt.chart.device.extension 2 0 2011-01-12 18:13:44.628
!MESSAGE Missing required bundle org.eclipse.birt.chart.engine_[2.1.0,3.0.0).
!MESSAGE Bundle org.eclipse.birt.chart.device.swt_2.5.0.v20090514 [16] was not resolved.
!SUBENTRY 2 org.eclipse.birt.chart.device.swt 2 0 2011-01-12 18:13:44.628
!MESSAGE Bundle org.eclipse.birt.chart.engine.extension_2.5.0.v20090527 [17] was not resolved.
!SUBENTRY 2 org.eclipse.birt.chart.engine.extension 2 0 2011-01-12 18:13:44.628
!MESSAGE Bundle org.eclipse.birt.chart.engine_2.5.0.v20090604 [18] was not resolved.
!SUBENTRY 2 org.eclipse.birt.chart.engine 2 0 2011-01-12 18:13:44.628
!MESSAGE Missing required bundle org.eclipse.emf.ecore_[2.2.0,3.0.0).
!MESSAGE Missing required bundle org.eclipse.emf.ecore.xmi_[2.2.0,3.0.0).
!MESSAGE Missing required bundle org.eclipse.birt.core_[2.1.0,3.0.0).
!MESSAGE Bundle org.eclipse.birt.core_2.5.0.v20090601 [19] was not resolved.
!MESSAGE Bundle org.eclipse.emf.common_2.5.0.v200906151043 [44] was not resolved.
!MESSAGE Bundle org.eclipse.emf.ecore.xmi_2.5.0.v200906151043 [45] was not resolved.
!SUBENTRY 2 org.eclipse.emf.ecore.xmi 2 0 2011-01-12 18:13:44.628
!MESSAGE Missing required bundle org.eclipse.emf.ecore_[2.5.0,3.0.0).
!MESSAGE Bundle org.eclipse.emf.ecore_2.5.0.v200906151043 [46] was not resolved.
!SUBENTRY 2 org.eclipse.emf.ecore 2 0 2011-01-12 18:13:44.628
!MESSAGE Missing required bundle org.eclipse.emf.common_[2.5.0,3.0.0).
!MESSAGE Bundle org.eclipse.mat.api_1.0.1.201008091353 [76] was not resolved.
!SUBENTRY 2 org.eclipse.mat.api 2 0 2011-01-12 18:13:44.628
!MESSAGE Missing required bundle org.eclipse.mat.report_1.0.0.
!MESSAGE Bundle org.eclipse.mat.chart.ui_1.0.1.201008091353 [77] was not resolved.
!SUBENTRY 2 org.eclipse.mat.chart.ui 2 0 2011-01-12 18:13:44.628
!MESSAGE Missing required bundle org.eclipse.mat.chart_1.0.0.
!MESSAGE Missing required bundle org.eclipse.mat.ui_1.0.0.
!MESSAGE Missing required bundle org.eclipse.birt.chart.device.extension_2.2.0.
!MESSAGE Missing required bundle org.eclipse.birt.chart.device.swt_2.2.0.
!MESSAGE Missing required bundle org.eclipse.birt.chart.engine.extension_2.2.0.
!MESSAGE Missing required bundle org.eclipse.birt.chart.engine_2.2.0.
!MESSAGE Missing required bundle org.eclipse.birt.core_2.2.0.
!MESSAGE Bundle org.eclipse.mat.chart_1.0.1.201008091353 [78] was not resolved.
!SUBENTRY 2 org.eclipse.mat.chart 2 0 2011-01-12 18:13:44.628
!MESSAGE Missing required bundle org.eclipse.mat.api_1.0.0.
!MESSAGE Bundle org.eclipse.mat.dtfj_1.0.1.201008091353 [79] was not resolved.
!SUBENTRY 2 org.eclipse.mat.dtfj 2 0 2011-01-12 18:13:44.628
!MESSAGE Missing required bundle org.eclipse.mat.parser_1.0.0.
!SUBENTRY 2 org.eclipse.mat.dtfj 2 0 2011-01-12 18:13:44.644
!MESSAGE Missing optionally required bundle com.ibm.dtfj.api_1.3.0.
!MESSAGE Missing imported package com.ibm.dtfj.*_0.0.0.
!SUBENTRY 1 org.eclipse.osgi 2 0 2011-01-12 18:13:44.644
!MESSAGE Bundle org.eclipse.mat.hprof_1.0.1.201008091353 [80] was not resolved.
!SUBENTRY 2 org.eclipse.mat.hprof 2 0 2011-01-12 18:13:44.644
!MESSAGE Bundle org.eclipse.mat.ibmdumps_1.0.1.201008091353 [81] was not resolved.
!SUBENTRY 2 org.eclipse.mat.ibmdumps 2 0 2011-01-12 18:13:44.644
!MESSAGE Bundle org.eclipse.mat.jdt_1.0.1.201008091353 [82] was not resolved.
!SUBENTRY 2 org.eclipse.mat.jdt 2 0 2011-01-12 18:13:44.644
!MESSAGE Bundle org.eclipse.mat.parser_1.0.1.201008091353 [83] was not resolved.
!SUBENTRY 2 org.eclipse.mat.parser 2 0 2011-01-12 18:13:44.644
!MESSAGE Bundle org.eclipse.mat.report_1.0.1.201008091353 [84] was not resolved.
!MESSAGE Bundle org.eclipse.mat.ui.rcp_1.0.1.201008091353 [86] was not resolved.
!SUBENTRY 2 org.eclipse.mat.ui.rcp 2 0 2011-01-12 18:13:44.644
!MESSAGE Bundle org.eclipse.mat.ui_1.0.1.201008091353 [87] was not resolved.
!SUBENTRY 2 org.eclipse.mat.ui 2 0 2011-01-12 18:13:44.644
!MESSAGE Bundle org.hamcrest.core_1.1.0.v20090501071000 [114] was not resolved.
!MESSAGE Bundle org.junit4_4.5.0.v20090423 [115] was not resolved.
!SUBENTRY 2 org.junit4 2 0 2011-01-12 18:13:44.644
!MESSAGE Missing required bundle org.hamcrest.core_1.1.0.
FUDForum. Page generated in 0.04138 seconds
