SWT standalone newbie question [message #634237] |
Wed, 20 October 2010 21:55 |
Keith Willenson Messages: 21 Registered: July 2009 |
I am trying to test my standalone application with SWTBot. I can start an Eclipse workbench (using the plugin example), but there is nothing in it. I thought about loading my application, but decided there must be an easier way. Please let me know if I am wrong. I can run junit4 tests, but I can not get an SWTBot to see my applicaiton. So what do I need to do to get the junit tests and SWTBot together? I am using Eclipse Helios 3.6, version 2.0.0.595-dev-e36 of SWTBot, and junit4.
When I uncomment the bot in PPSOpen.beforeClass, I get
java.lang.IllegalStateException: Could not find a display
at org.eclipse.swtbot.swt.finder.utils.SWTUtils.display(SWTUtil s.java:249)
at org.eclipse.swtbot.swt.finder.finders.ControlFinder.<init>(ControlFinder.java:82)
at org.eclipse.swtbot.swt.finder.finders.ControlFinder.<init>(ControlFinder.java:72)
at org.eclipse.swtbot.swt.finder.SWTBot.<init>(SWTBot.java:106)
at org.eclipse.swtbot.eclipse.finder.SWTWorkbenchBot.<init>(SWTWorkbenchBot.java:56)
at test.PPSOpen.beforeClass(PPSOpen.java:28)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAcce ssorImpl.java:39)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMe thodAccessorImpl.java:25)
at org.junit.runners.model.FrameworkMethod$1.runReflectiveCall( FrameworkMethod.java:44)
at org.junit.internal.runners.model.ReflectiveCallable.run(Refl ectiveCallable.java:15)
at org.junit.runners.model.FrameworkMethod.invokeExplosively(Fr ameworkMethod.java:41)
at org.junit.internal.runners.statements.RunBefores.evaluate(Ru nBefores.java:27)
at org.junit.runners.BlockJUnit4ClassRunner.runChild(BlockJUnit 4ClassRunner.java:76)
at org.junit.runners.BlockJUnit4ClassRunner.runChild(BlockJUnit 4ClassRunner.java:50)
at org.junit.runners.ParentRunner$3.run(ParentRunner.java:193)
at org.junit.runners.ParentRunner$1.schedule(ParentRunner.java: 52)
at org.junit.runners.ParentRunner.runChildren(ParentRunner.java :191)
at org.junit.runners.ParentRunner.access$000(ParentRunner.java: 42)
at org.junit.runners.ParentRunner$2.evaluate(ParentRunner.java: 184)
at org.junit.runners.ParentRunner.run(ParentRunner.java:236)
at org.junit.runners.Suite.runChild(Suite.java:128)
at org.junit.runners.Suite.runChild(Suite.java:24)
at org.eclipse.jdt.internal.junit4.runner.JUnit4TestReference.r un(JUnit4TestReference.java:49)
at org.eclipse.jdt.internal.junit.runner.TestExecution.run(Test Execution.java:38)
at org.eclipse.jdt.internal.junit.runner.RemoteTestRunner.runTe sts(RemoteTestRunner.java:467)
at org.eclipse.jdt.internal.junit.runner.RemoteTestRunner.runTe sts(RemoteTestRunner.java:683)
at org.eclipse.jdt.internal.junit.runner.RemoteTestRunner.run(R emoteTestRunner.java:390)
at org.eclipse.jdt.internal.junit.runner.RemoteTestRunner.main( RemoteTestRunner.java:197)
I run the following as a junit test
I have AllTests.java
package test;
import org.junit.runner.RunWith;
import org.junit.runners.Suite;
@RunWith(Suite.class)
@Suite.SuiteClasses({
PPSOpen.class,
OtherTests.class,
PPSClose.class,
public class AllTests {
} // AllTests
PPSOpen.java
package test;
import static org.eclipse.swtbot.swt.finder.waits.Conditions.shellIsActive ;
public class PPSOpen
private static SWTWorkbenchBot bot = null;
public static SWTWorkbenchBot getBot()
return bot;
@Before
public void beforeClass() throws Exception {
// bot = new SWTWorkbenchBot();
@Test(timeout=6000)
public void initPPS()
try
PPS.main(new String[] { });
catch (Exception e)
e.printStackTrace();
fail("initialize PPS failed");
//ICondition waitForWidget = shellIsActive("PPS");
// bot.waitUntilWidgetAppears(waitForWidget);
@Test
public void getPPS()
PPS pps = Setup.getPps();
assertNotNull("PPS is null", pps);
and PPSClose.java
package test;
import org.junit.* ;
public class PPSClose
@Test
public void closePPS()
PPS.getDisplay().syncExec(new Runnable() {
public void run()
assertTrue(pps != null);
pps.close();
Re: SWT standalone newbie question [message #634789 is a reply to message #634237] |
Sat, 23 October 2010 15:17 |
Ketan Padegaonkar Messages: 873 Registered: July 2009 |
See SWTBotApplicationLauncherClassRunner: http://goo.gl/g4ae
Also you'd need to use SWTBot class and not SWTWorkbenchBot for SWT only
tests. SWTWorkbenchBot is for eclipse based tests.
Ketan
ketan.padegaonkar.name | eclipse.org/swtbot | @ketanpkr
> at
> at
> at
> ssorImpl.java:39)
> at java.lang.reflect.Method.invoke(Method.java:597)
> nBefores.java:27)
> Execution.java:38)
> package test;
> PPSOpen.class,
> OtherTests.class,
> PPSClose.class,
> } // AllTests
> PPSOpen.java
> package test;
> import static
> { private static SWTWorkbenchBot bot = null;
> return bot; }
> @Before
> @Test(timeout=6000)
> try
> catch (Exception e)
> @Test
> and PPSClose.java
> package test;
> { @Test
> @Override
> public void run()
> pps.close();
FUDForum. Page generated in 0.03714 seconds
