Failed to start test application with "Application Error" message [message #632082] |
Mon, 11 October 2010 13:50 |
Ravi Messages: 7 Registered: October 2010 |
Hi Ketan
I tried to execute a swtbot test using "headless" option on an exported Eclipse application. But, it fails to start the test application with "Application error" message. Following are the logs:
Install location:
file:/c:/Program Files/XXXX/XXXX/
Configuration file:
file:/c:/Program Files/XXXX/XXXX/configuration/config.ini loaded
Configuration location:
Framework located:
file:/c:/Program Files/XXXX/XXXX/plugins/org.eclipse.osgi_3.5.0.v20090520.jar
Framework classpath:
Debug options:
file:/C:/Documents and Settings/rsingal/Desktop/.options not found
Time to load bundles: 15
Starting application: 1110
!SESSION 2010-10-11 19:05:55.592 -----------------------------------------------
eclipse.buildId=unknown
java.version=1.6.0_19
Framework arguments: -application org.eclipse.swtbot.eclipse.junit4.headless.swtbottestapplica tion -testApplication com.lm.uc.app.application -product com.lm.uc.app.product formatter=org.apache.tools.ant.taskdefs.optional.junit.XMLJU nitResultFormatter,results.xml formatter=org.apache.tools.ant.taskdefs.optional.junit.Plain JUnitResultFormatter -testPluginName com.lm.uc.app.product.swtbottests -className MyFirstTestCase
Command-line arguments: -application org.eclipse.swtbot.eclipse.junit4.headless.swtbottestapplica tion -testApplication com.lm.uc.app.application -product com.lm.uc.app.product -data test-workspace formatter=org.apache.tools.ant.taskdefs.optional.junit.XMLJU nitResultFormatter,results.xml formatter=org.apache.tools.ant.taskdefs.optional.junit.Plain JUnitResultFormatter -testPluginName com.lm.uc.app.product.swtbottests -className MyFirstTestCase -os win32 -ws win32 -arch x86 -consoleLog -debug
!ENTRY org.eclipse.osgi 4 0 2010-10-11 19:05:56.749
!MESSAGE Application error
!STACK 1
org.eclipse.core.runtime.AssertionFailedException: null argument:
at org.eclipse.core.runtime.Assert.isNotNull(Assert.java:85)
at org.eclipse.core.runtime.Assert.isNotNull(Assert.java:73)
at org.eclipse.swtbot.eclipse.junit4.headless.UITestApplication .start(UITestApplication.java:47)
at org.eclipse.equinox.internal.app.EclipseAppHandle.run(Eclips eAppHandle.java:194)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .runApplication(EclipseAppLauncher.java:110)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .start(EclipseAppLauncher.java:79)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:368)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:179)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java: 559)
at org.eclipse.equinox.launcher.Main.main(Main.java:1287)
at org.eclipse.core.launcher.Main.main(Main.java:34)
I do not have access to the source code of the test application. I copied the required plugin jar files in the ECLIPSE_HOME/plugins folder and then executed the following command from the Command Prompt:
java -Xms256M -Xmx512M -XX:MaxPermSize=512M -classpath "C:\Program Files\XXXX\XXXX\plugins\org.eclipse.equinox.launcher_1.0.200 .v20090520.jar " org.eclipse.core.launcher.Main -application org.eclipse.swtbot.eclipse.junit4.headless.swtbottestapplica tion -testApplication com.lm.uc.app.application -product com.lm.uc.app.product -data test-workspace formatter=org.apache.tools.ant.taskdefs.optional.junit.XMLJU nitResultFormatter,results.xml formatter=org.apache.tools.ant.taskdefs.optional.junit.Plain JUnitResultFormatter -testPluginName com.lm.uc.app.product.swtbottests -className MyFirstTestCase -os win32 -ws win32 -arch x86 -consoleLog -debug
but, it fails to start the application. Am I missing some required plugin or we have to make some changes in the test application itself?
[Updated on: Mon, 11 October 2010 13:51] Report message to a moderator
Re: Failed to start test application [message #632124 is a reply to message #632082] |
Mon, 11 October 2010 15:45 |
Ketan Padegaonkar Messages: 873 Registered: July 2009 |
Looking at the stacktrace indicates that the application corresponding
to -testApplication is not found. I've fixed the error messages to
provide more information on what went wrong instead of a stacktrace like
the one you just saw.
Please see http://wiki.eclipse.org/SWTBot/Troubleshooting if you're
unable to run eclipse with the following args
-application com.your.application.id -consoleLog -debug -os win32 -ws
win32 -arch x86
If you're unable to start the app with the above command line, means
that your application might be missing some dependencies, or that swtbot
may have broken some of your apps dependencies causing it to not startup...
Ketan
ketan.padegaonkar.name | eclipse.org/swtbot | @ketanpkr
On 10/11/10 6:50 AM, Ravi wrote:
> Hi Ketan
> Install location:
> Configuration file:
> Framework located:
> file:/c:/Program
> file:/c:/Program
> Debug options:
> BootLoader constants: OS=win32, ARCH=x86, WS=win32, NL=en_US
> !STACK 1
> tarter.java:368)
> tarter.java:179)
FUDForum. Page generated in 0.03286 seconds
