Home » Archived » Eclipse Communications Framework (ECF) » Question with jslp library included in ECF jslp provider
Re: Question with jslp library included in ECF jslp provider [message #623499 is a reply to message #623498] |
Tue, 06 May 2008 05:47 |
Markus Kuppe Messages: 177 Registered: July 2009 |
Phuong Hoang wrote:
> Hi Markus,
> Thanks very much for clarification,
> Phuong Hoang
> "Markus Alexander Kuppe" <news.eclipse.org.08@lemmster.de> wrote in message
> news:fvejaq$bt2$1@build.eclipse.org...
>> Phuong Hoang wrote:
>>> Anyway, I have another question regarding the jslp library included in
>>> the download of ECF at http://www.eclipse.org/ecf/downloads.php
>>> The library of jslp downloaded is
>>> "ch.ethz.iks.slp_1.0.0.RC2_v200803061811.jar" which is not a OSGI version
>>> but a standalone version of jSLP instead.
>>> => This leaves the org.eclipse.ecf.provider.jslp un-operational because
>>> it cannot find Locator or Advertiser registered as OSGI services.
>>> When replaced with OSGI version of jslp downloaded from sourceforge, the
>>> jslp ECF provider works fine.
>>> So I'm wondering if that jslp library (RC2_v200803031811) is the correct
>>> one?
>> Hi,
>> it is an OSGi bundle, but it lacks the Bundle-Activator OSGi header as
>> well as the activator class ch.ethz.iks.slp.impl.Activator. Orbit must
>> have accidentally used the non-OSGi sf.net jSLP jar. I've filed
>> https://bugs.eclipse.org/bugs/show_bug.cgi?id=229922
>> Cheers,
>> Markus
>> P.S.: If you feel comfortable with it, I'd suggest using trunk of
>> http://jslp.sf.net anyway. It contains a few bug fixes too. Updates in
>> Orbit usually take a while because of the IP process.
Hi Phuong,
the problem has been solved. Please verify with builds > 20080505.
Markus
Re: Question with jslp library included in ECF jslp provider [message #623500 is a reply to message #623499] |
Tue, 06 May 2008 06:03 |
Scott Lewis Messages: 1038 Registered: July 2009 |
One thing to point out...the jslp provider is built by the Orbit project
http://www.eclipse.org/orbit
and they only do builds occasionally, so it may be a few days until ECF
can consume a new Orbit build.
I will make a request for another Orbit build to pick up these changes
and we will get them in place as soon as possible.
Scott
Markus Alexander Kuppe wrote:
> Phuong Hoang wrote:
>> Hi Markus,
>> Phuong Hoang
>> message news:fvejaq$bt2$1@build.eclipse.org...
>>>> in the download of ECF at http://www.eclipse.org/ecf/downloads.php
>>>> version but a standalone version of jSLP instead.
>>>> because it cannot find Locator or Advertiser registered as OSGI
>>>> services.
>>>> the jslp ECF provider works fine.
>>>> correct one?
>>> Hi,
>>> as well as the activator class ch.ethz.iks.slp.impl.Activator. Orbit
>>> must have accidentally used the non-OSGi sf.net jSLP jar. I've filed
>>> Cheers,
>>> Markus
>>> in Orbit usually take a while because of the IP process.
> Hi Phuong,
> Thanks
> Markus
ECF 2.0.0 M7a was: Re: Question with jslp library included in ECF jslp provider [message #623507 is a reply to message #623500] |
Wed, 07 May 2008 22:25 |
Hi Folks,
This morning, the Orbit build promoted the fix to this jSLP bundle to
the Orbit I-build (I20080505235349) to address this bug:
In order to pick up the jSLP fix, I've done an M7a build for ECF, and
deployed it to the normal locations (see below). This build should fix
this issue...and I decided to build and deploy an M7a today so that
Phuong and others could test and verify it. This is the only change
from M7 done last night.
I've just completed the deploy to the download and update site. The
Eclipse replication may take a little while, but it should be ready
soon. Note that the version qualifier for this build is v20080507-1345.
ECF Download: http://www.eclipse.org/ecf/downloads.php
N&N: http://www.eclipse.org/ecf/NewAndNoteworthy.html
ECF Extras: http://ecf1.osuosl.org
CVS tag: v20080507-1345
Thanks...sorry about any trouble.
Scott
> Scott
>> Phuong Hoang wrote:
>>> Hi Markus,
>>> Phuong Hoang
>>>>> services.
>>>>> sourceforge, the jslp ECF provider works fine.
>>>>> correct one?
>>>> Hi,
>>>> Cheers,
>>>> Markus
>> Hi Phuong,
>> Thanks
>> Markus
Current Time: Fri Apr 26 13:32:30 GMT 2024
Powered by FUDForum. Page generated in 0.02792 seconds
