Home » Eclipse Projects » SWTBot » SWTBot and SplashHandler
SWTBot and SplashHandler [message #547900] Tue, 20 July 2010 03:07 Go to next message
Hi, i'm trying to create tests for RCP application. The problem is that before the application starts there is a splash with login form (and if app is started for the first time also the wizard). The splash is added by extension. I've found the post with the same problem but there is no answer:
http:// dev.eclipse.org/mhonarc/newsLists/news.eclipse.swtbot/msg001 91.html
When I run my test the application starts but it omits the login splash (so as a result the application crashes because part of initialization is omitted).
How can I solve this problem? Will SWTBot support the splashhandler in the future?
Thanks, Łukasz
Re: SWTBot and SplashHandler [message #548067 is a reply to message #547900] Tue, 20 July 2010 10:47 Go to previous message
AFAIK, this issue is not resolved yet.
Here's a workaround: http://goo.gl/WYQy
Ketan
http://ketan.padegaonkar.name | http://eclipse.org/swtbot
> answer:
> http://dev.eclipse.org/mhonarc/newsLists/news.eclipse.swtbot /msg00191.html
> is omitted).
> the future?
> Thanks, Łukasz
Previous Topic:How to click a checkbox inside a tree
Next Topic:How to define plugin start level in SWTBot run configuration (Spring DM)
Current Time: Wed Nov 05 00:24:39 EST 2025
Powered by FUDForum. Page generated in 0.02666 seconds
