Page objects for standard views? [message #524854] |
Fri, 02 April 2010 23:54 |
Richard Adams Messages: 77 Registered: July 2009 Location: Edinburgh |
Member |
Hello
I've been reading about the use of 'Page Objects' to provide an API to ui elements and was wondering if it would be useful to create some classes to access standard Eclipse views.
For example in our app we've written a class around the SearchResults view, with methods like:
getNumResults()
getResult(int row)
etc
and we
also need to interrogate the ProgressView as well - if anyone thinks this is possibly useful we can polish them up and make them available.
Cheers
Richard
Dr Richard Adams, University of Edinburgh
http://richardadams606blog.blogspot.com/
http://csbe.bio.ed.ac.uk/adams.php
Re: Page objects for standard views? [message #526435 is a reply to message #525280] |
Sun, 11 April 2010 01:34 |
Member |
Hello
Here (below) is an attempt at a page object for a standard Eclipse search result view or any page implementing the org.eclipse.search.searchResultViewPages
extension point. It's by no means complete (e.g., it could have more convenience methods for analyzing results displayed in a tree).
Interested to hear if this is useful.
Best wishes
Richard
package swtbot.pageobjects;
import org.eclipse.search.ui.text.AbstractTextSearchViewPage;
import org.eclipse.swtbot.eclipse.finder.SWTWorkbenchBot;
import org.eclipse.swtbot.eclipse.finder.widgets.SWTBotView;
import org.eclipse.swtbot.swt.finder.waits.DefaultCondition;
import org.eclipse.swtbot.swt.finder.widgets.SWTBotTable;
import org.eclipse.swtbot.swt.finder.widgets.SWTBotTree;
import org.eclipse.ui.part.PageBookView;
* <p>Page object class for a basic search page implementing the <br/>
* <code>org.eclipse.search.searchResultViewPages</code><br/>
* extension point.</p>
* <p>
* In particular this class assumes the search result page extends the
* default abstract class: <br/>
* <code>org.eclipse.search.ui.text.AbstractTextSearchViewPage</code>
* </p>
* <p>
* One further requirement for using this class is that the table or tree configured in the
* method: <br/>
* <code> protected abstract void configureTableViewer(TableViewer viewer);<code><br/>
* or <br/>
* protected abstract void configureTreeViewer(TreeViewer viewer); <br/>
* sets an ID for the underlying widget.</p>
* <p> For example:<br/>
* <code>viewer.getTable().setData("org.eclipse.swtbot.widget.key", "myID");</code>
* </p>
* <p>
* Usage of this class in a test could be as follows :<br/>
* <pre>
* //... perform a search and wait for search page to appear..
* SearchResultViewPO view = new SearchResultViewPO(bot,
* BioModelsSearchResultPage.VIEW_WIDGET_ID, "Search");
assertTrue(view.isFlat());
assertTrue(view.getNumResults()==2);
assertTrue(view.getNumColumns()==4);
</pre>
</p>
<p> So this class should only be instantiated when a search view is present.
This can be established by a simple waitUntil condition. E.g.,
</p>
<pre>
class SearchResultViewOpened extends DefaultCondition {
private SWTWorkbenchBot bot;
private String viewTitle;
public SearchResultViewOpened(SWTWorkbenchBot bot, String viewTitle) {
this.bot = bot;
this.viewTitle=viewTitle;
public String getFailureMessage() {
return "Search results view could not be opened";
public boolean test() throws Exception {
return bot.viewByTitle(viewTitle) != null;
</pre>
<p>
Eg.,
</p>
<pre>
//do Search
bot.waitUntil(new SearchResultViewOpened());
// SearchResultViewPO view = .... as example above.
</pre>
* @author Richard Adams
public class SearchResultViewPO {
private final SWTWorkbenchBot bot;
private final String id;
private SWTBotView view;
* Constructor for SearchResultViewPO. Should be called from the test thread.
* @param bot A non-null {@link SWTWorkbenchBot}
* @param viewWidgetID A non-null & non-empty <code>String</code>.
* The ID of either the tree or table widget holding the results.
* @param viewTitle A <code>String </code> of the view title.
* @throw {@link IllegalArgumentException} if any argument is null or
* String arguments are empty.
public SearchResultViewPO (final SWTWorkbenchBot bot, final String viewWidgetID, final String viewTitle) {
super();
if(bot==null || viewWidgetID==null || viewWidgetID.equals("")
|| viewTitle.equals("")){
throw new IllegalArgumentException();
this.bot = bot;
this.id=viewWidgetID;
view = bot.viewByTitle(viewTitle);
* Gets the number of results. For a tree this is the number of top-level results.
* For a table, this is the number of rows in the result table.
* @return An <code>int</code> number of results.
public int getNumResults() {
if (isTree()){
return bot.tree().rowCount();
} else {
return bot.tableWithId(id).rowCount();
* Gets the number of columns in the result view.
* @return An <code>int</code> number of columns.
public int getNumColumns() {
if (isTree()){
return bot.treeWithId(id).columnCount();
} else {
return bot.tableWithId(id).columnCount();
* Retrieves the underlying <code>SWTBotTable</code>. <br/>
* This method should only be called for a search result view configured
* to be flat. <br/>
* I.e., if isFlat() == <code>true</code>
* @return The underlying {@link SWTBotTable}
* @throw {@link IllegalStateException} if <br/>
* <code> isFlat() == false </code>
public SWTBotTable getSearchResultTable() {
if (!isFlat()){
throw new IllegalStateException();
return bot.tableWithId(id);
* Retrieves the underlying <code>SWTBotTree</code>. <br/>
* to be a tree. <br/>
* I.e., if isTree() == <code>true</code>
* @return The underlying {@link SWTBotTree}
* <code> isTree() == false </code>
public SWTBotTree getSearchResultTree() {
if (!isTree()){
return bot.treeWithId(id);
* Boolean test for whether the search result view is tree-based.
* @return <code>true </code> if the search result page is tree based.
public boolean isTree(){
return getSearchPage().isLayoutSupported(AbstractTextSearchViewPage.FLAG_LAYOUT_TREE);
* Boolean test for whether the search result view is flat (table-based).
* @return <code>true </code> if the search result page isflat.
public boolean isFlat(){
return getSearchPage().isLayoutSupported(AbstractTextSearchViewPage.FLAG_LAYOUT_FLAT);
private AbstractTextSearchViewPage getSearchPage() {
PageBookView sv = ((PageBookView)(view.getViewReference().getView(false)));
AbstractTextSearchViewPage isp = (AbstractTextSearchViewPage)sv.getCurrentPage();
return isp;
Re: Page objects for standard views? [message #526801 is a reply to message #524854] |
Tue, 13 April 2010 00:38 |
Member |
And here is a possible page object for a 'Problems' view - could probably be improved with use of Matchers etc. Plenty more useful methods possible but these are currently sufficient in our tests.
import static org.junit.Assert.assertTrue;
import java.io.File;
import org.eclipse.swtbot.swt.finder.widgets.SWTBotTreeItem;
import uk.ac.ed.csbe.sbsivisual.conditions.ViewOpened;
import uk.ac.ed.csbe.sbsivisual.test.ProjectUtils;
*<p> This class is a wrapper around a Problems View for the purposes of testing.
* It is not particularly intended to be used in testing the Problems View itself, more that
* it provides a way to ensure that markers are being generated and displayed.
* <p>This current version assumes that you have a default Problems view grouped by 'Severity'.I.e.,
* the top level items in the view are 'Errors' and 'Warnings'.
* <p>Example usage:
* <pre>
* // here we create 2 new projects, each with a single application specific error
* ProjectUtils.createStandardProjectWithTestDataAndHeader("TEST",
new File("TestData/ABC_withMissingHeader.sbsidata"),
TestDataUtils.getTestDataHeader(), bot);
ProjectUtils.createStandardProjectWithTestDataAndHeader("TEST2",
// test set up
final String EXPECTED_WARNING_MESSAGE_FRAGMENT="No header file found";
// open problems view
ProblemsViewPO problemsPO = ProblemsViewPO.openProblemsView(bot);
// wait for all markers to appear in the view after running in a workspace listener.
problemsPO.waitForAtLeastNofType(ProblemsViewPO.WARNINGS, 2);
// check correct warnings are displayed.
assertTrue(problemsPO.getMessage(0, ProblemsViewPO.WARNINGS).contains(EXPECTED_WARNING_MESSAGE_FRAGMENT));
* </pre>
* @author radams
public class ProblemsViewPO {
// private constructor used by static factory methods.
private ProblemsViewPO(SWTWorkbenchBot bot) {
super();
this.bot = bot;
private SWTBotView botView;
public final static String ERROR = "Errors";
public final static String WARNINGS = "Warnings";
* Factory method which opens the Problems view. This method waits for the problem view to
* appear. Assumes the standard Window->Other->Show View mechanism is used and that the
* view is called 'Problems' ( the default name).
* @param bot A non-null SWTWorkbenchBot bot.
* @return A {@link ProblemsViewPO} object wrapping a Problems view.
* @throws Timeout exception if the problems view cannot be opened.
public static ProblemsViewPO openProblemsView(final SWTWorkbenchBot bot) {
return openProblemsView(bot, "Problems");
* appear. Assumes the standard Window->Other->Show View mechanism is used.
* @param title A <code>String</code> title of the Problems view as it appears in the Window menu.
public static ProblemsViewPO openProblemsView(final SWTWorkbenchBot bot,
final String title) {
ProblemsViewPO viewPO = new ProblemsViewPO(bot);
viewPO.init(title);
return viewPO;
private void init(final String title) {
bot.menu("Window").menu("Other...").click();
bot.shell("Show View").activate();
bot.tree().expandNode("General").expandNode(title).doubleClick();
bot.waitUntil(new ViewOpened(bot, title)); // simple Condition class to test for view
botView = bot.viewByTitle(title);
* Getter for underlying SWTBotView of this problems view.
* @return the {@link SWTBotView} wrapped by this class. Will not be null if this object
* has initialized properly.
public SWTBotView getBotView() {
return botView;
* Getter for number of displayed warnings
public int getDisplayedWarningCount() {
return getCountofType("Warnings");
* Getter for number of displayed errors
public int getDisplayedErrorCount() {
return getCountofType("Errors");
* Gets the String error/warning message for a problem at a specified index.
* @param rowNumber the index of the warning message.
* @param type
* @return The message, or the empty string if no problems of the spcified type found
* @throws IndexOutOfBoundsException if rowNumber does not exist ( zero -based).
public String getMessage(int rowNumber, String type) {
final int MESSAGE_COLUMN=0;
SWTBotTree tree = botView.bot().tree();
SWTBotTreeItem[] items = tree.getAllItems();
for (SWTBotTreeItem item : items) {
if (item.getText().contains(type)) {
return item.expand().getItems()[rowNumber]
.row().get(MESSAGE_COLUMN);
return "";
* Waits until a given number of errors or warnings are displayed.
* This method is useful if you have modified a resource and want to check the markers
* are updated. Currently this just works for number of displayed markers, rather than all markers.
* This is not a test for an exact number of problems
* @param problemType One of ProblemsViewPO.ERROR or ProblemsViewPO.Warnings
* @param expected An <code> int </code> of the number of expected errors or warnings, >=0
* @throws IllegalArgumentException if <code> expected < 0</code>, or problem type is not a valid String
public void waitForAtLeastNofType (String problemType, int expected) {
if (expected < 0 || (!checkType(problemType))) {
bot.waitUntil(new NAreGenerated(expected, problemType));
private boolean checkType(String problemType) {
return problemType.equals(ProblemsViewPO.ERROR) ||
problemType.equals(ProblemsViewPO.WARNINGS);
private int getCountofType(String type) {
return item.expand().getItems().length;
return 0;
* Condition class which tests for n warnings or errors being in the P
class NAreGenerated extends DefaultCondition {
private int expected=0;
private String type;
private NAreGenerated(int expected, String type) {
super();
this.expected = expected;
this.type=type;
return "Could not find " + expected + " problems of type [" + type + "]";
return getCountofType(type) == expected;
* General condition that a view with a given title has opened.
public class ViewOpened extends DefaultCondition {
public ViewOpened(SWTWorkbenchBot bot, String viewTitle) {
this.bot = bot;
return "View could not be opened";
FUDForum. Page generated in 0.04833 seconds
