Home » Eclipse Projects » SWTBot » Getting Teststeps from swtbot
Getting Teststeps from swtbot [message #506819] Sun, 10 January 2010 06:37 Go to next message
is there a way to log the the steps of a test.
For exampel.
  1. Select Treeitem "test"
  2. click contextMenuItem "edit"
  3. choose shell "edit"
  4. deselect radiobutton "delete"
  5. click button "ok"
Is there a chance to get such entries or something like that.
I dont know all findWidgets texts, but the actions, which I make in the applications. I want to put them in a protocol later. So a developer, canfaster reproduce the testcase with a failure.
Re: Getting Teststeps from swtbot [message #506951 is a reply to message #506819] Mon, 11 January 2010 03:54 Go to previous messageGo to next message
Michelle Davidson wrote:
> Hello,
> is there a way to log the the steps of a test. For exampel.
> choose shell "edit"
> click button "ok"
SWTBot uses log4j to log all sorts of information. All you need to do is
setup your log4j.xml to tell log4j what to log to what priority. There
is an example of this in the tests of SWTBot; checkout the latest source
from svn and check this file:
org.eclipse.swtbot.eclipse.finder.test/src/log4j.xml
Hope this helps.
Pascal Gélinas | Software Developer
*Nu Echo Inc.*
http://www.nuecho.com/ | http://blog.nuecho.com/
*Because performance matters.*
Re: Getting Teststeps from swtbot [message #508167 is a reply to message #506951] Sat, 16 January 2010 18:28 Go to previous messageGo to next message
Thanks for the answer. I have tried that. But now I have too much log statements. I want only action like click, activate, type or something like this. But I also get the log statements for sending events from the class Abstract SWTBot. Because both have the loglevel debug and the class AbstractSWTBot is in the same package like the widget classes.
Is the chance to get only the statements for the actions and not for the events.
I tried to set the loglevel for the class Abstract SWTBot to OFF and for the package ....widgets to DEBUG. But I get also this.
17 Jan 2010 00:17:48.332 - WorkbenchTestable - TRACE - SWTBotButton - (AbstractSWTBot.java:151) - Enquing event Deactivate [27]: ShellEvent{Button {*Disposed*} time=963483308 data=null doit=true} on (of type 'Button' and with mnemonic 'OK' and with style 'SWT.PUSH')
17 Jan 2010 00:17:48.332 - main - TRACE - SWTBotButton - (AbstractSWTBot$2.java:155) - Not notifying (of type 'Button' and with mnemonic 'OK' and with style 'SWT.PUSH') is null or has been disposed
17 Jan 2010 00:17:48.332 - WorkbenchTestable - TRACE - SWTBotButton - (AbstractSWTBot.java:151) - Enquing event FocusOut [16]: FocusEvent{Button {*Disposed*} time=963483308 data=null} on (of type 'Button' and with mnemonic 'OK' and with style 'SWT.PUSH')
17 Jan 2010 00:17:48.334 - main - TRACE - SWTBotButton - (AbstractSWTBot$2.java:155) - Not notifying (of type 'Button' and with mnemonic 'OK' and with style 'SWT.PUSH') is null or has been disposed
17 Jan 2010 00:17:48.334 - WorkbenchTestable - DEBUG - SWTBotButton - (SWTBotButton.java:78) - Clicked on
17 Jan 2010 00:17:48.335 - WorkbenchTestable - TRACE - SWTBotTreeItem - (AbstractSWTBot.java:151) - Enquing event Expand [17]: TreeEvent{Tree {} time=963483311 data=null item=TreeItem {Root} detail=0 x=0 y=0 width=0 height=0 stateMask=0 text=null doit=true} on TreeItem with text {TreeItem {Root}}
17 Jan 2010 00:17:48.335 - main - TRACE - SWTBotTreeItem - (AbstractSWTBot$2.java:162) - Sending event Expand [17]: TreeEvent{Tree {} time=963483311 data=null item=TreeItem {Root} detail=0 x=0 y=0 width=0 height=0 stateMask=0 text=null doit=true} to TreeItem with text {TreeItem {Root}}
17 Jan 2010 00:17:48.336 - main - DEBUG - SWTBotTreeItem - (AbstractSWTBot$2.java:164) - Sent event Expand [17]: TreeEvent{Tree {} time=963483311 data=null item=TreeItem {Root} detail=0 x=0 y=0 width=0 height=0 stateMask=0 text=null doit=true} to TreeItem with text {TreeItem {Root}}
17 Jan 2010 00:17:48.340 - WorkbenchTestable - TRACE - SWTBotTreeItem - (AbstractSWTBot.java:151) - Enquing event MouseMove [5]: MouseEvent{Tree {} time=963483313 data=null button=0 stateMask=0 x=0 y=0 count=0} on TreeItem with text {TreeItem {Root}}
17 Jan 2010 00:17:48.340 - main - TRACE - SWTBotTreeItem - (AbstractSWTBot$2.java:162) - Sending event MouseMove [5]: MouseEvent{Tree {} time=963483313 data=null button=0 stateMask=0 x=0 y=0 count=0} to TreeItem with text {TreeItem {Root}}
17 Jan 2010 00:17:48.341 - main - DEBUG - SWTBotTreeItem - (AbstractSWTBot$2.java:164) - Sent event MouseMove [5]: MouseEvent{Tree {} time=963483313 data=null button=0 stateMask=0 x=0 y=0 count=0} to TreeItem with text {TreeItem {Root}}
17 Jan 2010 00:17:48.341 - WorkbenchTestable - TRACE - SWTBotTreeItem - (AbstractSWTBot.java:151) - Enquing event Activate [26]: ShellEvent{Tree {} time=963483317 data=null doit=true} on TreeItem with text {TreeItem {Root}}
17 Jan 2010 00:17:48.342 - main - TRACE - SWTBotTreeItem - (AbstractSWTBot$2.java:162) - Sending event Activate [26]: ShellEvent{Tree {} time=963483317 data=null doit=true} to TreeItem with text {TreeItem {Root}}
That was a part of the log file.
This is my log4j.xml
<?xml version="1.0" encoding="UTF-8" ?>
<!DOCTYPE log4j:configuration SYSTEM "log4j.dtd">
<log4j:configuration xmlns:log4j="http://jakarta.apache.org/log4j/"
	debug="false">
	<appender name="consoleAppender" class="org.apache.log4j.ConsoleAppender">
		<param name="Target" value="System.out" />
		<layout class="org.apache.log4j.PatternLayout">
			<param name="ConversionPattern"
				value="%d{dd MMM yyyy HH:mm:ss.SSS} - %25t - %-5p - %30c{1} - (%C{1}.java:%L) - %m%n" />
		</layout>
	</appender>
	<appender name="fileAppender" class="org.apache.log4j.FileAppender">
		<param name="File" value="/tmp/debug.log" />
		<param name="Append" value="true" />
		</layout>
	</appender>
	<!-- don't log matchers, this is very high amount of chatter -->
	<category name="org.eclipse.swtbot.swt.finder.matchers">
		<priority value="OFF" />
	</category>
		don't log the class AbstractSWTBot but all other classes from this package
	<category name="org.eclipse.swtbot.swt.finder.widgets">
		<priority value="ALL" />
	</category>
		<category name="org.eclipse.swtbot.swt.finder.widgets.AbstractSWTBot">
		</category>
	<!-- don't log finders, this is moderate chatter -->
	<category name="org.eclipse.swtbot.swt.finder.finders">
	</category>
	<category name="org.eclipse.swtbot.swt.finder.keyboard">
		<!-- set to a value higher than debug to turn on. -->
		<priority value="DEBUG" />
	</category>
	<category name="org.eclipse.swtbot">
	</category>
	<root>
		<!--appender-ref ref="consoleAppender" /-->
		<appender-ref ref="fileAppender" />
	</root>
</log4j:configuration>
Re: Getting Teststeps from swtbot [message #508541 is a reply to message #508167] Tue, 19 January 2010 06:40 Go to previous message
I guess a grep pattern is the only way to do this. You may potentially
write your own Appender implementation[1] that logs only if certain
keywords are present in the log statement.
-- Ketan
[1] -
http://logging.apache.org/log4j/1.2/apidocs/org/apache/log4j /FileAppender.html
On 1/16/10 3:28 PM, Michelle Davidson wrote:
> Hello,
> events.
> Quote:
>> (SWTBotButton.java:78) - Clicked on 17 Jan 2010 00:17:48.335 -
> debug="false">
> </layout>
> </appender>
> </layout>
> </appender>
> </category>
> </category>
> <category name="org.eclipse.swtbot.swt.finder.widgets.AbstractSWTBot" >
> </category>
> </category>
> </category>
> </category>
> <root>
> </root>
Previous Topic:ShellIsActive wait condition
Next Topic:How to find the matches in Build Console View
Current Time: Tue Nov 04 22:30:51 EST 2025
Powered by FUDForum. Page generated in 0.03399 seconds
