Re: Running SWTBot testcase with ant [message #45194 is a reply to message #45076] |
Thu, 23 July 2009 16:35 |
Derek Messages: 30 Registered: July 2009 |
Member |
Ketan Padegaonkar wrote:
> On 23/7/09 04:29, Derek wrote:
>> I tried running the steps for executing SWTBot tests from Ant. I
>> followed the tutorial which was helpful.
>> When I run ant from the cmd prompt, it goes through the build.xml, says
>> it's running my testcase and ends with a Build Successful.
>> In the tutorial I see that it shows Eclipse run and steps performed.
>> Mine does not visually show this, but does take the time I would expect
>> it to.
>> I also get a "Java Result: 13"
> Can you look at the generated XML file ? It contains the JUnit report
> for the tests. You may also optionally import it into the junit view to
> see any errors.
The generated XML file that was put in the results folder doesn't have any
information in it. Just:
<?xml version="1.0" encoding="UTF-8" ?>
<testsuites />
The text file gives more information:
Looks like it's got a bunch of class not found errors, though, I really
don't know what these actually mean. >_>;;
Install location:
file:/c:/eclipse_ganymede/eclipse/
Configuration file:
file:/c:/eclipse_ganymede/eclipse/configuration/config.ini loaded
Configuration location:
Framework located:
file:/c:/eclipse_ganymede/eclipse/plugins/org.eclipse.osgi_3 .4.3.R34x_v20081215-1030.jar
Framework classpath:
Debug options:
file:/C:/eclipse_ganymede/eclipse/.options not found
Time to load bundles: 16
Starting application: 3609
!SESSION 2009-07-23 10:12:13.705
eclipse.buildId=M20090211-1700
java.version=1.6.0_14
BootLoader constants: OS=win32, ARCH=x86_64, WS=workspace, NL=en_US
Framework arguments: -application
org.eclipse.swtbot.eclipse.junit4.headless.swtbottestapplica tion
formatter=org.apache.tools.ant.taskdefs.optional.junit.XMLJU nitResultFormatter,C:/eclipse_ganymede/eclipse/MySampleTestC ase.xml
formatter=org.apache.tools.ant.taskdefs.optional.junit.Plain JUnitResultFormatter
-testPluginName com.eclipse.swtbot.tester -className MySampleTestCase
Command-line arguments: -application
org.eclipse.swtbot.eclipse.junit4.headless.swtbottestapplica tion -data
workspace
-testPluginName com.eclipse.swtbot.tester -className MySampleTestCase -os
win32 -ws workspace -arch x86_64 -consoleLog -debug
!ENTRY org.eclipse.osgi 4 0 2009-07-23 10:12:17.361
!MESSAGE An error occurred while automatically activating bundle
org.eclipse.ui.workbench (158).
!STACK 0
org.osgi.framework.BundleException: The activator
org.eclipse.ui.internal.WorkbenchPlugin for bundle
org.eclipse.ui.workbench is invalid
at
org.eclipse.osgi.framework.internal.core.AbstractBundle.load BundleActivator(AbstractBundle.java:146)
at
org.eclipse.osgi.framework.internal.core.BundleContextImpl.s tart(BundleContextImpl.java:980)
at
org.eclipse.osgi.framework.internal.core.BundleHost.startWor ker(BundleHost.java:346)
at
org.eclipse.osgi.framework.internal.core.AbstractBundle.star t(AbstractBundle.java:265)
at
org.eclipse.osgi.framework.util.SecureAction.start(SecureAct ion.java:400)
at
org.eclipse.core.runtime.internal.adaptor.EclipseLazyStarter .postFindLocalClass(EclipseLazyStarter.java:111)
at
org.eclipse.osgi.baseadaptor.loader.ClasspathManager.findLoc alClass(ClasspathManager.java:427)
at
org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.fin dLocalClass(DefaultClassLoader.java:193)
at
org.eclipse.osgi.framework.internal.core.BundleLoader.findLo calClass(BundleLoader.java:370)
at
org.eclipse.osgi.framework.internal.core.BundleLoader.findCl assInternal(BundleLoader.java:446)
at
org.eclipse.osgi.framework.internal.core.BundleLoader.findCl ass(BundleLoader.java:399)
at
org.eclipse.osgi.framework.internal.core.BundleLoader.findCl ass(BundleLoader.java:387)
at
org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.loa dClass(DefaultClassLoader.java:87)
at java.lang.ClassLoader.loadClass(ClassLoader.java:252)
at
org.eclipse.osgi.framework.internal.core.BundleLoader.loadCl ass(BundleLoader.java:315)
at
org.eclipse.osgi.framework.internal.core.BundleHost.loadClas s(BundleHost.java:227)
at
org.eclipse.osgi.framework.internal.core.AbstractBundle.load Class(AbstractBundle.java:1274)
at
org.eclipse.core.internal.registry.osgi.RegistryStrategyOSGI .createExecutableExtension(RegistryStrategyOSGI.java:160)
at
org.eclipse.core.internal.registry.ExtensionRegistry.createE xecutableExtension(ExtensionRegistry.java:867)
at
org.eclipse.core.internal.registry.ConfigurationElement.crea teExecutableExtension(ConfigurationElement.java:243)
at
org.eclipse.core.internal.registry.ConfigurationElementHandl e.createExecutableExtension(ConfigurationElementHandle.java: 51)
at
org.eclipse.equinox.internal.app.EclipseAppHandle.run(Eclips eAppHandle.java:188)
at
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .runApplication(EclipseAppLauncher.java:110)
at
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .start(EclipseAppLauncher.java:79)
at
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:386)
at
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:179)
at
at
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java: 549)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:504)
at org.eclipse.equinox.launcher.Main.run(Main.java:1236)
at org.eclipse.equinox.launcher.Main.main(Main.java:1212)
at org.eclipse.core.launcher.Main.main(Main.java:30)
Caused by: java.lang.NoClassDefFoundError: org/eclipse/swt/SWTError
at java.lang.Class.getDeclaredConstructors0(Native Method)
at java.lang.Class.privateGetDeclaredConstructors(Class.java:23 89)
at java.lang.Class.getConstructor0(Class.java:2699)
at java.lang.Class.newInstance0(Class.java:326)
at java.lang.Class.newInstance(Class.java:308)
at
org.eclipse.osgi.framework.internal.core.AbstractBundle.load BundleActivator(AbstractBundle.java:141)
... 34 more
Caused by: java.lang.ClassNotFoundException: org.eclipse.swt.SWTError
at
org.eclipse.osgi.framework.internal.core.BundleLoader.findCl assInternal(BundleLoader.java:483)
at
at
at
at java.lang.ClassLoader.loadClassInternal(ClassLoader.java:320 )
... 40 more
Root exception:
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
... 40 more
!MESSAGE Application error
!STACK 1
org.eclipse.core.runtime.CoreException: Plug-in
org.eclipse.swtbot.eclipse.junit4.headless was unable to load class
org.eclipse.swtbot.eclipse.junit4.headless.UITestApplication .
at
org.eclipse.core.internal.registry.osgi.RegistryStrategyOSGI .throwException(RegistryStrategyOSGI.java:180)
at
org.eclipse.core.internal.registry.osgi.RegistryStrategyOSGI .createExecutableExtension(RegistryStrategyOSGI.java:162)
at
at
at
at
at
at
at
at
at
at
Caused by:
org.eclipse.core.runtime.internal.adaptor.EclipseLazyStarter $TerminatingClassNotFoundException:
at
org.eclipse.core.runtime.internal.adaptor.EclipseLazyStarter .postFindLocalClass(EclipseLazyStarter.java:125)
at
at
at
at
at
at
at
at
at
at
at
... 17 more
Caused by: org.osgi.framework.BundleException: The activator
at
at
at
at
at
at
... 29 more
at
... 34 more
at
at
at
at
... 40 more
!ENTRY org.eclipse.osgi 2 0 2009-07-23 10:12:17.408
!MESSAGE The following is a complete list of bundles which are not
resolved, see the prior log entry for the root cause if it exists:
!SUBENTRY 1 org.eclipse.osgi 2 0 2009-07-23 10:12:17.408
!MESSAGE Bundle
reference:file:plugins/org.eclipse.core.filesystem.win32.x86 _1.1.0.v20080604-1400.jar
[23] was not resolved.
!SUBENTRY 2 org.eclipse.core.filesystem.win32.x86 2 0 2009-07-23
10:12:17.408
!MESSAGE Platform filter did not match: (& (osgi.os=win32) (osgi.arch=x86))
!SUBENTRY 1 org.eclipse.osgi 2 0 2009-07-23 10:12:17.424
!MESSAGE Bundle
reference:file:plugins/org.eclipse.core.net.win32.x86_1.0.0. I20080521.jar
[26] was not resolved.
!SUBENTRY 2 org.eclipse.core.net.win32.x86 2 0 2009-07-23 10:12:17.424
!MESSAGE Bundle
reference:file:plugins/org.eclipse.core.resources.win32.x86_ 3.4.0.v20071204.jar
[29] was not resolved.
!SUBENTRY 2 org.eclipse.core.resources.win32.x86 2 0 2009-07-23
10:12:17.424
!MESSAGE Bundle
reference:file:plugins/org.eclipse.equinox.launcher.win32.wi n32.x86_1.0.101.R34x_v20080731/
[54] was not resolved.
!SUBENTRY 2 org.eclipse.equinox.launcher.win32.win32.x86 2 0 2009-07-23
10:12:17.424
!MESSAGE Platform filter did not match: (& (osgi.ws=win32) (osgi.os=win32)
(osgi.arch=x86))
!MESSAGE Bundle
reference:file:plugins/org.eclipse.equinox.security.win32.x8 6_1.0.0.v20080529-1600.jar
[80] was not resolved.
!SUBENTRY 2 org.eclipse.equinox.security.win32.x86 2 0 2009-07-23
10:12:17.424
!MESSAGE Bundle
reference:file:plugins/org.eclipse.swt.win32.win32.x86_3.4.1 .v3452b.jar
[131] was not resolved.
!SUBENTRY 2 org.eclipse.swt.win32.win32.x86 2 0 2009-07-23 10:12:17.424
(osgi.arch=x86))
!MESSAGE Bundle
reference:file:plugins/org.eclipse.ui.win32_3.2.100.v2008040 8-0800.jar
[157] was not resolved.
!SUBENTRY 2 org.eclipse.ui.win32 2 0 2009-07-23 10:12:17.424
!MESSAGE Platform filter did not match: (osgi.ws=win32)
FUDForum. Page generated in 0.04523 seconds
