| Re: IPropertySource for EObject [message #428949] |
Fri, 03 April 2009 11:31  |
--------------080106090400040307000400
Esteban,
It's best to use the EMF newsgroup. I've added it to the "to" list of
the reply.
Esteban DUGUEPEROUX wrote:
> I post here because I don't know which group is adapted.
> I have a view componed of a TreeViewer with as input a tree of EObject
> from my generated Ecore model.
> I want see properties of my selected item (EObject) of my TreeViewer
> in PropertySheet Viewer, then I have added this line :
> getSite().setSelectionProvider(viewer);
> but I need that my EObjects implements IAdaptable or IPropertySource
> following this article :
> http://www.eclipse.org/articles/Article-Properties-View/prop erties-view.html
No you don't need that. The generated editor already shows how this is
supported using an AdapterFactoryContentProvider:
* This accesses a cached version of the property sheet.
* <!-- begin-user-doc -->
* <!-- end-user-doc -->
* @generated
public IPropertySheetPage getPropertySheetPage()
if (propertySheetPage == null)
propertySheetPage =
new ExtendedPropertySheetPage(editingDomain)
public void setSelectionToViewer(List<?> selection)
LibraryEditor.this.setSelectionToViewer(selection);
LibraryEditor.this.setFocus();
public void setActionBars(IActionBars actionBars)
super.setActionBars(actionBars);
getActionBarContributor().shareGlobalActions(this,
actionBars);
propertySheetPage.setPropertySourceProvider(new
AdapterFactoryContentProvider(adapterFactory));
return propertySheetPage;
> How can I specify to my .genmodel to generate EObject implementing one
> of these above interfaces with default implementations.
EMF has an adapter mechanism already; one that includes support for
notification as well.
> I have to manually add one of these interfaces to my Ecore generated
> code?
There are definitely automatic ways you could support this, for example
by extending EObjectImpl with something that supports additional
interfaces, and then using that base class in place of EObjectImpl. in
the GenModel Root Extends Class property.
It sounds like it would be a good idea for you to generate the editor
and see how it works...
> Regards
<html>
<head>
</head>
Esteban,<br>
<br>
the reply.<br>
<br>
<br>
<blockquote cite="mid:gr58jh$g38$1@build.eclipse.org" type="cite">Hi,
<br>
<br>
<br>
<br>
<br>
I want see properties of my selected item (EObject) of my TreeViewer in
<br>
<br>
<br>
<br>
<br>
<br>
<a class="moz-txt-link-freetext" href=" http://www.eclipse.org/articles/Article-Properties-View/prop erties-view.html"> http://www.eclipse.org/articles/Article-Properties-View/prop erties-view.html</a>
<br>
</blockquote>
supported using an AdapterFactoryContentProvider:<small><br>
</small>
<blockquote><small> /**</small><br>
<small> * This accesses a cached version of the property sheet.</small><br>
<small> * <!-- begin-user-doc --></small><br>
<small> * <!-- end-user-doc --></small><br>
<small> * @generated</small><br>
<small> */</small><br>
<small> public IPropertySheetPage getPropertySheetPage()</small><br>
<small> {</small><br>
<small> if (propertySheetPage == null)</small><br>
<small> propertySheetPage =</small><br>
<small> new ExtendedPropertySheetPage(editingDomain)</small><br>
<small> @Override</small><br>
<small> public void setSelectionToViewer(List<?>
selection)</small><br>
<small> LibraryEditor.this.setSelectionToViewer(selection);</small> <br>
<small> LibraryEditor.this.setFocus();</small><br>
<small> }</small><br>
<br>
<small> public void setActionBars(IActionBars actionBars)</small><br>
<small> super.setActionBars(actionBars);</small><br>
<small> getActionBarContributor().shareGlobalActions(this,
<small> };</small><br>
<small> propertySheetPage.setPropertySourceProvider(new
AdapterFactoryContentProvider(adapterFactory));</small><br >
<br>
<small> return propertySheetPage;</small><br>
</blockquote>
<br>
<blockquote cite="mid:gr58jh$g38$1@build.eclipse.org" type="cite"><br>
<br>
</blockquote>
notification as well.<br>
code?
<br>
</blockquote>
the GenModel Root Extends Class property.<br>
<br>
and see how it works...<br>
<br>
</blockquote>
</body>
</html>
--------------080106090400040307000400--
| Re: IPropertySource for EObject [message #429058 is a reply to message #428949] |
Tue, 07 April 2009 05:51  |
Ed Merks a écrit :
> Esteban,
> the reply.
> * @generated
> propertySheetPage =
> @Override
> @Override
> actionBars);
>> code?
>> Regards
Hi Ed,
Thanks for your reply.
I have added the "public Object getAdapter(Class adapter)" method to
fetch my PropertySheetPage. And used a ComposedAdapterFactory
initialized with default ResourceItemProviderAdapterFactory and
XXXItemProviderAdapterFactory from my own model.
My TreeViewer configured with my own AdapterFactoryContentProvider and
AdapterFactoryLabelProvider.
And now it works fine :)
Thanks for your help and for your works in Eclipse.
FUDForum. Page generated in 0.03865 seconds
