Is SWTbot supposed to work with Eclipse 3.3.2? [message #40292] |
Wed, 24 June 2009 13:34 |
I'm completely new to SWTbot, and trying to install it under Eclipse 3.3.2.
The installation itself seems to work (using a locally unzipped
swtbot-update-site-2.0.0.358-dev.zip). I then created a test plug-in
project, added org.eclipse.swtbot.eclipse.finder,
org.eclipse.swtbot.swt.finder and org.junit4 as dependencies, and pasted
the TestSampleDialog class from
http://wiki.eclipse.org/SWTBot/UsersGuide#Getting_started_wi th_SWTBot in
there. The class compiled OK (although with many deprecation warnings),
but I don't know how to run it. I don't have the "SWTbot Test" entry in
my "Run as" menu.
I tried the exact same procedure under an Eclipse 3.4, and there I have
the "SWTbot Test" entry and can run the class.
Am I doing something wrong, or is SWTbot not supposed to work under
Eclipse 3.3?
Pierre-Charles David - Obeo
Re: Is SWTbot supposed to work with Eclipse 3.3.2? [message #40322 is a reply to message #40292] |
Wed, 24 June 2009 16:33 |
Ketan Padegaonkar Messages: 873 Registered: July 2009 |
Eclipse 3.3 used to work fine about 6 months ago.
The only things that may not work are:
- support for any additional widgets or swt styles that were
introduced in eclipse 3.4. You may have to comment out such api.
- bundle manifests that have a minimum version requirement on bundles
that ship with eclipse 3.4. They may possibly work with eclipse 3.3.
Try checking out the swtbot source code from trunk and see what does not
compile and/or breaks and file a bug report. If it's not too much work
for me I'll try to provide some form of backport to 3.3.
Ketan
http://studios.thoughtworks.com/twist | http://twitter.com/ketanpkr
On 24/6/09 19:04, Pierre-Charles David wrote:
> my "Run as" menu.
> Eclipse 3.3?
Re: Is SWTbot supposed to work with Eclipse 3.3.2? [message #40352 is a reply to message #40322] |
Thu, 25 June 2009 11:37 |
Is there an old release I can download which worked with 3.3? I don't
see any on the website.
> - support for any additional widgets or swt styles that were introduced
I'm not sure if/when I will have the time to do that, sorry.
Re: Is SWTbot supposed to work with Eclipse 3.3.2? [message #40503 is a reply to message #40472] |
Thu, 25 June 2009 15:23 |
>> I guess your best bet is to get things from
>> http://sf.net/projects/swtbot or move to eclipse 3.4 even better 3.5 :)
> I can't move to 3.4 or later, but I think I'll try the sf.net version.
> Thanks.
I only tested the TestSampleDialog class, but I confirm that at least on
this case, version net.sf.swtbot.eclipse-1.2.0.921 from the URL above
works with Eclipse 3.3.2. I had to do the following changes to the code
of the sample test case:
- adjust the plugin dependencies and imports to use the net.sf packages;
- add "throws WidgetNotFoundException" to both test methods to make it
compile;
- remove the following section from the testCreateJavaProjet test case:
//Click Next button
bot.button("Next >").click();
bot.sleep(500);
It seems the projectSelectionTree.select("Java Project"); above
already advances to the next (and last) wizard page.
Thanks for your help.
Re: Is SWTbot supposed to work with Eclipse 3.3.2? [message #484728 is a reply to message #40503] |
Tue, 08 September 2009 22:16 |
John Reysa Messages: 21 Registered: July 2009 |
>> Thanks.
> compile;
> //Click Next button
> bot.sleep(500);
Can I do the following. I have an eclipse 3.3.2 RCP application.
I am developing it on Eclipse 3.5 and have my target application set to
a subset of 3.3.2 plugins. I added the sf.net plugins above. But I get
the following exception at the end of this post. I see that it is
recommended to add org.eclipse.swtbot.eclipse.core. However, if I add
that, then it depends on org.eclipse.core.runtime; version="3.4.0". But
the target needs to have v3.3.2. Does this have a chance of working?
java.lang.RuntimeException: Application
"org.eclipse.swtbot.eclipse.core.swtbottestapplication" could not be
found in the registry. The applications available are:
org.eclipse.update.core.standaloneUpdate,
org.eclipse.update.core.siteOptimizer,
org.eclipse.help.base.infocenterApplication,
org.eclipse.help.base.helpApplication, org.eclipse.help.base.indexTool,
org.eclipse.equinox.app.error,
net.sf.swtbot.eclipse.ui.swtbottestapplication,
org.eclipse.ant.core.antRunner,
org.eclipse.pde.junit.runtime.uitestapplication,
org.eclipse.pde.junit.runtime.legacytestapplication,
org.eclipse.pde.junit.runtime.coretestapplication,
org.eclipse.pde.build.Build, org.eclipse.jdt.core.JavaCodeFormatter.
at
org.eclipse.equinox.internal.app.EclipseAppContainer.startDe faultApp(EclipseAppContainer.java:242)
at
org.eclipse.equinox.internal.app.EclipseAppContainer.start(E clipseAppContainer.java:98)
at
org.eclipse.equinox.internal.app.Activator.addingService(Act ivator.java:112)
at
org.osgi.util.tracker.ServiceTracker$Tracked.trackAdding(Ser viceTracker.java:1064)
at
org.osgi.util.tracker.ServiceTracker$Tracked.trackInitialSer vices(ServiceTracker.java:926)
at org.osgi.util.tracker.ServiceTracker.open(ServiceTracker.jav a:330)
at org.osgi.util.tracker.ServiceTracker.open(ServiceTracker.jav a:274)
at org.eclipse.equinox.internal.app.Activator.start(Activator.j ava:54)
at
org.eclipse.osgi.framework.internal.core.BundleContextImpl$2 .run(BundleContextImpl.java:999)
at
org.eclipse.osgi.framework.internal.core.BundleContextImpl.s tartActivator(BundleContextImpl.java:993)
at
org.eclipse.osgi.framework.internal.core.BundleContextImpl.s tart(BundleContextImpl.java:974)
at
org.eclipse.osgi.framework.internal.core.BundleHost.startWor ker(BundleHost.java:346)
at
org.eclipse.osgi.framework.internal.core.AbstractBundle.star t(AbstractBundle.java:260)
at
org.eclipse.osgi.framework.util.SecureAction.start(SecureAct ion.java:400)
at
org.eclipse.core.runtime.internal.adaptor.EclipseLazyStarter .postFindLocalClass(EclipseLazyStarter.java:111)
at
org.eclipse.osgi.baseadaptor.loader.ClasspathManager.findLoc alClass(ClasspathManager.java:417)
at
org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.fin dLocalClass(DefaultClassLoader.java:189)
at
org.eclipse.osgi.framework.internal.core.BundleLoader.findLo calClass(BundleLoader.java:340)
at
org.eclipse.osgi.framework.internal.core.SingleSourcePackage .loadClass(SingleSourcePackage.java:37)
at
org.eclipse.osgi.framework.internal.core.BundleLoader.findCl assInternal(BundleLoader.java:405)
at
org.eclipse.osgi.framework.internal.core.BundleLoader.findCl ass(BundleLoader.java:369)
at
org.eclipse.osgi.framework.internal.core.BundleLoader.findCl ass(BundleLoader.java:357)
at
org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.loa dClass(DefaultClassLoader.java:83)
at java.lang.ClassLoader.loadClassInternal(Unknown Source)
at
org.eclipse.core.internal.runtime.PlatformActivator.startApp Container(PlatformActivator.java:47)
at
org.eclipse.core.internal.runtime.PlatformActivator.start(Pl atformActivator.java:32)
at
at
at
at
at
org.eclipse.osgi.framework.internal.core.AbstractBundle.resu me(AbstractBundle.java:350)
at
org.eclipse.osgi.framework.internal.core.Framework.resumeBun dle(Framework.java:1118)
at
org.eclipse.osgi.framework.internal.core.StartLevelManager.r esumeBundles(StartLevelManager.java:634)
at
org.eclipse.osgi.framework.internal.core.StartLevelManager.i ncFWSL(StartLevelManager.java:508)
at
org.eclipse.osgi.framework.internal.core.StartLevelManager.d oSetStartLevel(StartLevelManager.java:282)
at
org.eclipse.osgi.framework.internal.core.StartLevelManager.d ispatchEvent(StartLevelManager.java:468)
at
org.eclipse.osgi.framework.eventmgr.EventManager.dispatchEve nt(EventManager.java:195)
at
org.eclipse.osgi.framework.eventmgr.EventManager$EventThread .run(EventManager.java:297)
FUDForum. Page generated in 0.05038 seconds
