Home » Eclipse Projects » SWTBot » [3.5 M7] Test launch problem
[3.5 M7] Test launch problem [message #35095] Fri, 08 May 2009 07:18 Go to next message
I tried to run my SWTbot test from eclipse 3.5 M7. On eclipse 3.5 M6 it
works ok. On my test I right click and select Run As - SWT bot.
I receive error "An internal error occurred during: "Launching AllTests".
org.eclipse.pde.internal.ui.launcher.LaunchPluginValidator.g etPluginsToRun(Lorg/eclipse/debug/core/ILaunchConfiguration; )Ljava/util/Map; "
Re: [3.5 M7] Test launch problem [message #35167 is a reply to message #35095] Sat, 09 May 2009 03:43 Go to previous messageGo to next message
Fixed as part of https://bugs.eclipse.org/bugs/show_bug.cgi?id=274083.
You may just checkout and build the org.eclipse.swtbot.eclipse.ui plugin
and drop it into your plugins directory if you want to work with 3.5M7.
-- Ketan
Re: [3.5 M7] Test launch problem [message #35261 is a reply to message #35167] Mon, 11 May 2009 04:10 Go to previous message
When do you expect this to be in the nightly builds?
-Peter
On 2009-05-09 10:13:15 +0200, Ketan Padegaonkar
> plugin and drop it into your plugins directory if you want to work with
> 3.5M7.
> -- Ketan
Previous Topic:Eclipse 3.4.2 Ganymede supported by SWTBot?
Next Topic:PDE headless throws java return 13 error
Current Time: Wed Nov 05 07:47:09 EST 2025
Powered by FUDForum. Page generated in 0.03155 seconds
