Home » Newcomers » Newcomers » Error popup on launch: "'Load QML Analyzer' has encountered a problem."
Error popup on launch: "'Load QML Analyzer' has encountered a problem." [message #1832784] Thu, 24 September 2020 19:45 Go to next message
The full message is as follows:
An internal error occurred during: "Load QML Analyzer"."
If I click "Details" I get:
"An internal error occurred during: "Load QML Analyzer".
Cannot invoke "javax.script.ScriptEngine.getContext()" because "this.engine" is null"
I'm on macOS, and I'm using Eclipse for a programming course through my university, so I'm new to the software and pretty new to programming in general, so I apologize for any lack of knowledge. I've emailed a TA about this, however this issue seems quite uncommon so it remains unresolved.
If I click "OK" on the popup I'm able to continue using Eclipse and it seems to work fine for everything I've tried to do on it so far, but the error is still annoying.
So far I've tried reinstalling JDK, as well as reinstalling Eclipse itself. My Mac had a software update I hadn't yet installed, so I tried that as well.
I'm not sure what else to try. Any help would be greatly appreciated, thank you.
Re: Error popup on launch: "'Load QML Analyzer' has encountered a problem." [message #1832785 is a reply to message #1832784] Fri, 25 September 2020 00:21 Go to previous messageGo to next message
I suspect it's like this problem:
https://www.eclipse.org/lists/cdt-dev/msg34634.html
I.e., you are probably running with Java 15 which has yet again removed some packages/libraries that were previous available. You should have better luck running the IDE with Java 14.
Re: Error popup on launch: "'Load QML Analyzer' has encountered a problem." [message #1832833 is a reply to message #1832785] Fri, 25 September 2020 19:55 Go to previous messageGo to next message
Ed Merks wrote on Fri, 25 September 2020 04:21
That worked, thank you!
Re: Error popup on launch: "'Load QML Analyzer' has encountered a problem." [message #1851515 is a reply to message #1832833] Thu, 07 April 2022 04:54 Go to previous messageGo to next message
I am using Eclipse 2021-06 (4.20.0) on Fedora 35 with the latest java (/usr/lib/jvm/java-18-openjdk-18.0.0.0.37-2.rolling.fc35.x86_64/bin/java).
I mostly use Eclipse as a C++ development environment or for XML tooling.
While starting Eclipse, I didn't see the "'Load QML Analyzer' has encountered a problem." message for quite some time but after a recent update, the message comes up again.
It has already been more than 5 years ago that I did Java-development so if I have to remove some java-jars, I will probably not miss them.
Is there any java-stuff that has to be removed in order to get rid of the message? If so, which java-stuff and how should that be done?
Ben
Re: Error popup on launch: "'Load QML Analyzer' has encountered a problem." [message #1851854 is a reply to message #1832784] Wed, 20 April 2022 05:12 Go to previous messageGo to next message
Grayson Flood wrote on Thu, 24 September 2020 23:45
Cannot invoke "javax.script.ScriptEngine.getContext()" because "this.engine" is null"io games
I'm on macOS, and I'm using Eclipse for a programming course through my university, so I'm new to the software and pretty new to programming in general, so I apologize for any lack of knowledge. I've emailed a TA about this, however, this issue seems quite uncommon so it remains unresolved.
If I click "OK" on the popup I'm able to continue using Eclipse and it seems to work fine for everything I've tried to do on it so far, but the error is still annoying. wordle website
You are probably running with Java 15 which has yet again removed some packages/libraries that were previously available. You should have better luck running the IDE with Java 14.
[Updated on: Tue, 26 April 2022 05:54] by Moderator
Re: Error popup on launch: "'Load QML Analyzer' has encountered a problem." [message #1856322 is a reply to message #1851515] Fri, 02 December 2022 15:54 Go to previous messageGo to next message
The problem still persists, even now that I am using Fedora 17 with java-17-openjdk...
Re: Error popup on launch: "'Load QML Analyzer' has encountered a problem." [message #1856744 is a reply to message #1856322] Tue, 27 December 2022 22:01 Go to previous messageGo to next message
I am having this problem.
Re: Error popup on launch: "'Load QML Analyzer' has encountered a problem." [message #1856747 is a reply to message #1856322] Wed, 28 December 2022 04:17 Go to previous messageGo to next message
Well, yes, the features removed in Java 15 weren't added back in to later versions.
Re: Error popup on launch: "'Load QML Analyzer' has encountered a problem." [message #1856751 is a reply to message #1856747] Wed, 28 December 2022 10:21 Go to previous messageGo to next message
After upgrading Eclipse the probleme remained. So I just deleted Eclipse and installed the latest version. The problem has gone now.
Ben
Re: Error popup on launch: "'Load QML Analyzer' has encountered a problem." [message #1857795 is a reply to message #1856751] Sun, 26 February 2023 04:30 Go to previous messageGo to next message
Ben Engbers wrote on Wed, 28 December 2022 15:21
Ben
Deleting Eclipse was the last option I gave a chance. After installing the latest version, it is finally working!
Re: Error popup on launch: "'Load QML Analyzer' has encountered a problem." [message #1862699 is a reply to message #1857795] Thu, 21 December 2023 08:17 Go to previous messageGo to next message
It seems like there might be an issue with the QML Analyzer in Eclipse. Since you've already tried reinstalling JDK and Eclipse, you may want to check if there's a specific plugin related to QML or scripting that needs updating. Additionally, searching online forums or Eclipse communities might provide insights into similar issues and potential solutions. If the error doesn't impact your work, you can continue using Eclipse, but seeking advice from your course's TA or online communities could help resolve the annoyance.
Re: Error popup on launch: "'Load QML Analyzer' has encountered a problem." [message #1862742 is a reply to message #1862699] Tue, 26 December 2023 06:51 Go to previous messageGo to next message
I also encountered the same problem, but the above solution was not effective. Have you solved it?
Re: Error popup on launch: "'Load QML Analyzer' has encountered a problem." [message #1862766 is a reply to message #1862742] Thu, 28 December 2023 05:46 Go to previous message
As I already told on 28 December 2022 I deleted Eclipse and installed a new version.
I am now using 2023-12 and the problem has gone.
Previous Topic:Newb - Installation issue
Next Topic:Hello World
Current Time: Fri Sep 12 06:57:15 EDT 2025
Powered by FUDForum. Page generated in 0.10065 seconds
