Authentication/Transport Error [message #1752719] |
Thu, 26 January 2017 13:04 |
Max Schwund Messages: 10 Registered: January 2017 |
Hey guys,
I have some trouble to clone my Repository. The Repository is running on Bitbucket if neseccary.
I tried to clone it via Egit with https. But when i type in my credentials and URI of the Repository and click next... Eclipse asks me again for my credentials... It asks me 3 Times for my credentials and then throws an exception. My Username and Password ist correct.
I guess Eclipse is not let me connect to the server.
Proxys Working fine (Marketplace is working).
I am also able to clone this repository besides Eclipse (Git bash)
EDIT: Neon.2, Windows 7 64 Bit...
Greetings Max
Error Message:
java.lang.Exception: org.eclipse.jgit.api.errors.TransportException: https://mschwund@stash.Path.to/my/repo.git: not authorized
at org.eclipse.oomph.setup.git.impl.GitCloneTaskImpl.perform(GitCloneTaskImpl.java:882)
at org.eclipse.oomph.setup.internal.core.SetupTaskPerformer.doPerformNeededSetupTasks(SetupTaskPerformer.java:3305)
at org.eclipse.oomph.setup.internal.core.SetupTaskPerformer.access$1(SetupTaskPerformer.java:3248)
at org.eclipse.oomph.setup.internal.core.SetupTaskPerformer$WorkspaceUtil$1.run(SetupTaskPerformer.java:4469)
at org.eclipse.core.internal.resources.Workspace.run(Workspace.java:2240)
at org.eclipse.core.internal.resources.Workspace.run(Workspace.java:2267)
at org.eclipse.oomph.setup.internal.core.SetupTaskPerformer$WorkspaceUtil.performNeededSetupTasks(SetupTaskPerformer.java:4463)
at org.eclipse.oomph.setup.internal.core.SetupTaskPerformer$WorkspaceUtil.access$0(SetupTaskPerformer.java:4461)
at org.eclipse.oomph.setup.internal.core.SetupTaskPerformer.performNeededSetupTasks(SetupTaskPerformer.java:3239)
at org.eclipse.oomph.setup.internal.core.SetupTaskPerformer.performTriggeredSetupTasks(SetupTaskPerformer.java:3214)
at org.eclipse.oomph.setup.internal.core.SetupTaskPerformer.perform(SetupTaskPerformer.java:3114)
at org.eclipse.oomph.setup.ui.wizards.ProgressPage$9.run(ProgressPage.java:556)
at org.eclipse.oomph.setup.ui.wizards.ProgressPage$11$1.run(ProgressPage.java:682)
[Updated on: Thu, 26 January 2017 15:06] Report message to a moderator
Re: Authentication/Transport Error [message #1752958 is a reply to message #1752770] |
Tue, 31 January 2017 10:27 |
Ok now the Problem is this:
org.eclipse.jgit.api.errors.TransportException: https://mschwund@XXX.XXX.XXX/scm/Test/testprof.git: cannot open git-upload-pack
at org.eclipse.jgit.api.LsRemoteCommand.execute(LsRemoteCommand.java:221)
at org.eclipse.jgit.api.LsRemoteCommand.call(LsRemoteCommand.java:159)
at org.eclipse.egit.core.op.ListRemoteOperation.run(ListRemoteOperation.java:100)
at org.eclipse.egit.ui.internal.clone.SourceBranchPage$8.run(SourceBranchPage.java:341)
at org.eclipse.jface.operation.ModalContext$ModalContextThread.run(ModalContext.java:119)
Caused by: org.eclipse.jgit.errors.TransportException: https://mschwund@XXX.XXX.XXX/scm/Test/testprof.git: cannot open git-upload-pack
at org.eclipse.jgit.transport.TransportHttp.connect(TransportHttp.java:510)
at org.eclipse.jgit.transport.TransportHttp.openFetch(TransportHttp.java:288)
at org.eclipse.jgit.api.LsRemoteCommand.execute(LsRemoteCommand.java:198)
... 4 more
[Updated on: Tue, 31 January 2017 12:35] Report message to a moderator
FUDForum. Page generated in 0.03878 seconds
