Load second UML model with ANT [message #1725170] |
Tue, 01 March 2016 11:04 |
Hi all,
I'm beginner in Epsilon. I need to load 2 or 3 UML models for comparison but when I use epsilon.loadmodel in ANT, this has BUILD FAILED for second UML model and can't create task or type epslion.loadmodel. however first UML model is loaded.
This is my build.xml:
<project default="compare">
<target name="loadModels">
<epsilon.eol>
"TESTMODEL".println();
</epsilon.eol>
<epsilon.loadModel name="V1" type="UML" impl="org.eclipse.epsilon.emc.uml.UmlModel">
<parameter name="modelFile" value="/ANTPro/V1.uml"/>
<parameter name="readOnLoad" value="true"/>
</epsilon.loadModel>
<epsilon.eol>
<model ref="V1"/>
Class.all.size().println();
</epsilon.eol>
<epsilon.emf.loadmodel name="V2" impl="org.eclipse.epsilon.emc.uml.UmlModel">
<parameter name="modelFile" value="/ANTPro/V2.uml"/>
</epsilon.emf.loadmodel>
<epsilon.eol>
<model ref="V2"/>
</epsilon.eol>
</target>
<target name="compare" depends="loadModels">
<epsilon.ecl src="CompareUML.ecl"
exportmatchtrace="matchTrace1">
<model ref="V1" alias="Source"/>
<model ref="V2" alias="Source"/>
</epsilon.ecl>
</target>
</project>
Ant the console output is:
Buildfile: E:\eclipse-epsilon-1.2-win32-x86_64\workspace\ANTPro\build.xml
loadModels:
[epsilon.eol] TESTMODEL
[epsilon.eol] 2
BUILD FAILED
E:\eclipse-epsilon-1.2-win32-x86_64\workspace\ANTPro\build.xml:19: Problem: failed to create task or type epsilon.emf.loadmodel
Cause: The name is undefined.
Action: Check the spelling.
Action: Check that any custom tasks/types have been declared.
Action: Check that any <presetdef>/<macrodef> declarations have taken place.
Total time: 508 milliseconds
My Epsilon version is 1.2 and my eclipse is Luna 4.4.0
Can someone help me?
Thanks ...
Re: Load second UML model with ANT [message #1725271 is a reply to message #1725224] |
Wed, 02 March 2016 08:45 |
Hi Dimitris,
Yes, I selected the "Run in the same JRE as the workspace" option under the JRE tab of my launch configuration.
I think, it's problem of epsilon loadmodel for loading more than one UML models.
Can you test it?
A sample project is attached.
Mohammadreza
Attachment: ANTPro.zip
(Size: 20.02KB, Downloaded 158 times)
FUDForum. Page generated in 0.05012 seconds
