Home » Eclipse Projects » SWTBot » problems with viewByTitle in Mars
problems with viewByTitle in Mars [message #1692227] |
Tue, 14 April 2015 11:52 |
I started to port one of my projects to Mars, where SWTBot is used
extensively (https://www.eclipse.org/emf-parsley/).
The tests that use bot.viewByTitle fail, though the view is actually
visible when the test is run.
By debugging, it looks like the culprit is a change in
org.eclipse.ui.internal.WorkbenchPage.getViewReferences (which is used
in SWTBot by WorkbenchContentsFinder.findViewsInternal).
In Luna, the code of getViewReferences used to be
public IViewReference[] getViewReferences() {
MPerspective perspective = getCurrentPerspective();
if (perspective != null) {
List<MPlaceholder> placeholders = modelService.findElements(window, null,
MPlaceholder.class, null, EModelService.PRESENTATION);
List<IViewReference> visibleReferences = new ArrayList<IViewReference>();
for (ViewReference reference : viewReferences) {
for (MPlaceholder placeholder : placeholders) {
if (reference.getModel() == placeholder.getRef()
&& placeholder.isToBeRendered()) {
// only rendered placeholders are valid view references
visibleReferences.add(reference);
return visibleReferences.toArray(new
IViewReference[visibleReferences.size()]);
return new IViewReference[0];
In Mars, it became
return getViewReferences(false);
private IViewReference[] getViewReferences(boolean allPerspectives) {
int scope = allPerspectives ? WINDOW_SCOPE : EModelService.PRESENTATION;
MPlaceholder.class, null, scope);
and my views are not found anymore (again, my view is visible in the
current perspective)...
has anyone else experienced such problems when switching to Mars?
thanks in advance
Lorenzo
HOME: http://www.lorenzobettini.it
Xtext Book:
http://www.packtpub.com/implementing-domain-specific-languages-with-xtext-and-xtend/book
TDD Book: https://leanpub.com/tdd-buildautomation-ci
Xtext Book: https://www.packtpub.com/application-development/implementing-domain-specific-languages-xtext-and-xtend-second-edition
Re: problems with viewByTitle in Mars [message #1692563 is a reply to message #1692227] |
Thu, 16 April 2015 13:50 |
Hi Lorenzo.
That code looks like it should perform identically. What version of Mars were you using? There was a bug in the bug fix for bug 457939, committed on March 25 and fixed on April 10, that might account for this changed behaviour.
Brian.
Current Time: Fri Apr 26 13:52:10 GMT 2024
Powered by FUDForum. Page generated in 0.03529 seconds
