Home » Eclipse Projects » SWTBot » Jenkins xvnc for windows(Jenkins xvnc for windows)
Jenkins xvnc for windows [message #972195] Mon, 05 November 2012 07:36 Go to next message
Do we need xvnc plugin for jenkins while running on windows platform?
-Ramesh
Re: Jenkins xvnc for windows [message #981328 is a reply to message #972195] Mon, 12 November 2012 05:30 Go to previous messageGo to next message
Hi Ramesh,
You should ask the jenkins-user mailing list:
https://groups.google.com/forum/?fromgroups#!forum/jenkinsci-users
Windows does not use the X standard for display, so I'm pretty sure
neither Xvfb no Xvnc plugins will work directly. Maybe there is another
way to provide a similar "job-specific display" for Windows, but I'm not
aware of it.
A possible workaround is to start an instance Cygwin/X before you run
your tests, but I've no idea how well it could be working.
You should consider using Linux for your test execution since those
plugins allow you to run different test jobs in parallel. You could set
it up on a Virtual Machine such as KVM or VirtualBox.
HTH
Mickael Istria
JBoss, by Red Hat
My blog: http://mickaelistria.wordpress.com
My Tweets: http://twitter.com/mickaelistria
Re: Jenkins xvnc for windows [message #983734 is a reply to message #981328] Wed, 14 November 2012 00:25 Go to previous message
Thanks Mickael. I found out how to run SWTBot tests with Jenkins on windows.
By not starting Jenkins as a service, SWTBot tests runs fine.
Ramesh
Previous Topic:Eclipse 4.2 support
Next Topic:Can't find TitleAreaDialog
Current Time: Sat Jul 26 00:23:29 EDT 2025
Powered by FUDForum. Page generated in 0.03256 seconds
