Home » Eclipse Projects » SWTBot » activate a tab in the properties view
activate a tab in the properties view [message #953641] Mon, 22 October 2012 08:11 Go to next message
Hello all,
i am quite new to SWTBot. I implemented custom properties sheet and i want to test them.
But i don't know how to click on a tab so that the properties sections get displayed.
Can someone tell me how to do that with SWTBot?
I use Eclipse 4.2 on Windows.
Many thanks
Junior
Re: activate a tab in the properties view [message #981293 is a reply to message #953641] Mon, 12 November 2012 05:04 Go to previous messageGo to next message
I created some code that clicks on a properties tab with a given name. For this I copied some SWTBot code for clicking into this class http://code.google.com/a/eclipselabs.org/p/melanie/source/browse/de.uni_mannheim.informatik.swt.mlm.tests.core.ui/src/de/uni_mannheim/informatik/swt/mlm/tests/core/ui/SWTUtilsEx.java
and created a method which takes a String and clicks on the tab. You can find the method selectTabbedProperiesPage(final String name, final SWTBot bot) here: http://code.google.com/a/eclipselabs.org/p/melanie/source/browse/de.uni_mannheim.informatik.swt.mlm.tests.core.ui/src/de/uni_mannheim/informatik/swt/mlm/tests/core/ui/GMFTestUtil.java
Hope this helps you!
Ralph
Re: activate a tab in the properties view [message #981302 is a reply to message #953641] Mon, 12 November 2012 05:07 Go to previous messageGo to next message
On 10/22/2012 02:11 PM, Junior Lekane Nimpa wrote:
> Hello all,
> want to test them.
> get displayed.
Do you mean you're using a MultiTab property view like this one:
http://wiki.eclipse.org/images/b/b1/Jwt_we_multitabproperties_addtab.gif
? If yes, this concept is not (yet) supported by SWTBot. You should open
a feature request for it and suggest a patch. As an
implementation/workaround, you should rely on underlying JFace code in a
UIThreadRunnable. See what BonitaSoft guys did as an example (beware,
it's GPL, so act accordingly)
http://www.bonitasoft.org/websvn/filedetails.php?repname=Bonita+Open+Solution&path=%2Fbonita-studio%2Ftags%2Fbonita-studio-5.8%2Ftests%2Forg.bonitasoft.studio.diagram.test%2Fsrc%2Forg%2Fbonitasoft%2Fstudio%2Fdiagram%2Ftest%2FSWTBotTestUtil.java
If your request is just about enabling an open View, then use bot.view
and then activate() or select() or enable() or setFocus() or any method
whose name seems to do what you expect ;)
HTH
Mickael Istria
JBoss, by Red Hat
My blog: http://mickaelistria.wordpress.com
My Tweets: http://twitter.com/mickaelistria
Re: activate a tab in the properties view [message #981303 is a reply to message #981293] Mon, 12 November 2012 05:09 Go to previous message
On 11/12/2012 11:04 AM, Ralph Gerbig wrote:
> SWTBot bot) here:
> Ralph
Hi Ralph,
If you could turn it into a SWTBot patch, I'd be glad to integrate it!
Mickael Istria
JBoss, by Red Hat
Previous Topic:How to maximize the eclipse runtime using SWTBot?
Next Topic:SWTBot for RAD 8.0
Current Time: Thu Jul 24 23:50:04 EDT 2025
Powered by FUDForum. Page generated in 0.05726 seconds
