Home » Eclipse Projects » SWTBot » 64bit swtbot junit headless testing with ant(unable to find the test plugins while trying to execute test cases on 64bit environment)
64bit swtbot junit headless testing with ant [message #901464] |
Sun, 12 August 2012 14:31  |
I am trying to execute swtbot junit test cases on 64 bit windows7 machine.
For that i changed arch value x86_64, 64bit eclipse platform and 64 bit jre.
But while running the test cases it is showing like unable to find the test plugin.
Is anything missing in configuration.
could you please help me on this.
Thanks and regards,
Narender
Re: 64bit swtbot junit headless testing with ant [message #901811 is a reply to message #901705] |
Tue, 14 August 2012 12:08   |
Hello Swapnil,
Thank you for your reply.
please find the stack trace below :
build 14-Aug-2012 17:47:06 swtbot-test:
build 14-Aug-2012 17:47:06 java-test:
build 14-Aug-2012 17:47:06 [echo] jvm value:C:\toolbase\java_jre\1.7.0_03_64b/bin/java
build 14-Aug-2012 17:47:06 [echo] ======================================
build 14-Aug-2012 17:47:06 [echo] Running swtbot junit tests in com.xx.codenav.bookmarking.tests.BookmarkingSWTBotTestSuite
build 14-Aug-2012 17:47:06 [echo] Command line args are -application org.eclipse.swtbot.eclipse.junit4.headless.swtbottestapplication -data C:\CI7/builds/ECLDGSSWANALYSER-INT1026TESTPLAN-JOB1/junit-workspace -clean -product com.xx.ubk.targetproduct.product.product formatter=org.apache.tools.ant.taskdefs.optional.junit.XMLJUnitResultFormatter,C:\CI7/targets/WTAgent7/eclipse/com.xx.codenav.bookmarking.tests.BookmarkingSWTBotTestSuite.xml formatter=org.apache.tools.ant.taskdefs.optional.junit.PlainJUnitResultFormatter -testPluginName com.xx.codenav.bookmarking.tests -className com.xx.codenav.bookmarking.tests.BookmarkingSWTBotTestSuite -os win32 -ws win32 -arch x86_64 -consoleLog -debug
build 14-Aug-2012 17:47:06 [echo] JVM args are -Dosgi.framework.extensions=org.eclemma.runtime.equinox -Demma.session.out.file=C:\CI7/builds/ECLDGSSWANALYSER-INT1026TESTPLAN-JOB1/test-plugins/cvg/emma_coverage.es -Declemma.instrument.bundles=com.xx.codenav.fti.help,com.xx.codenav.ecuworx,com.xx.codenav.ecuworx.cdtconfig.help,com.xx.codenav.bookmarking,com.xx.codenav.ecuworx.cdtconfig,com.xx.codenav.externalsearch,com.xx.codenav.externalsearch.help,com.xx.codenav.cdt.help,com.xx.codenav.cdg.importconfig,com.xx.codenav.exuworx.swblaunchconfigs,com.xx.codenav.core.help,com.xx.codenav.cdt.extensions,com.xx.codenav.ecuworx.swbindexsync,com.xx.codenav.cdt.util,com.xx.codenav.core,com.xx.codenav.externaltexteditor.help,com.xx.codenav.fti,com.xx.codenav.multidomainsearch,com.xx.codenav.help,com.xx.codenav.viewfilters,com.xx.codenav.ecuworx.importconfig,com.xx.codenav.ecuworx.ulf,com.xx.codenav.viewfilters.help,com.xx.codenav,com.xx.codenav.ecuworx.newcfile,com.xx.codenav.multidomainsearch.help,com.xx.codenav.externaltexteditor -Demma.filter=+com.xx*,-com.xx.ubk.xtext.parser.antlr*,-*Test*,-*test*,-*ArtusCParserParser* -Xms64m -Xmx1024m -XX:MaxPermSize=256m -Xss1024k -XX:-UseSplitVerifier
build 14-Aug-2012 17:47:06 [echo] JUnit Result File: C:\CI7/targets/WTAgent7/eclipse/results/com.xx.codenav.bookmarking.tests.BookmarkingSWTBotTestSuite.xml.
build 14-Aug-2012 17:47:06 [echo] Console output File: C:\CI7/targets/WTAgent7/eclipse/results/com.xx.codenav.bookmarking.tests.BookmarkingSWTBotTestSuite.txt.
build 14-Aug-2012 17:47:42 [java] java.lang.Exception: Could not find plugin "com.xx.codenav.bookmarking.tests"
build 14-Aug-2012 17:47:43 [java] at org.eclipse.swtbot.eclipse.junit4.headless.EclipseTestRunner.loadSuiteClass(EclipseTestRunner.java:303)
build 14-Aug-2012 17:47:43 [java] at org.eclipse.swtbot.eclipse.junit4.headless.EclipseTestRunner.getTest(EclipseTestRunner.java:239)
build 14-Aug-2012 17:47:43 [java] at org.eclipse.swtbot.eclipse.junit4.headless.EclipseTestRunner.<init>(EclipseTestRunner.java:222)
build 14-Aug-2012 17:47:43 [java] at org.eclipse.swtbot.eclipse.junit4.headless.EclipseTestRunner.run(EclipseTestRunner.java:206)
build 14-Aug-2012 17:47:43 [java] at org.eclipse.swtbot.eclipse.junit4.headless.UITestApplication.runTests(UITestApplication.java:116)
build 14-Aug-2012 17:47:43 [java] at org.eclipse.ui.internal.testing.WorkbenchTestable$1.run(WorkbenchTestable.java:71)
build 14-Aug-2012 17:47:43 [java] at java.lang.Thread.run(Unknown Source)
build 14-Aug-2012 17:47:49 [java] Job found still running after platform shutdown. Jobs should be canceled by the plugin that scheduled them during shutdown: com.xx.dgs.tul.logger.LoggerJob
build 14-Aug-2012 17:47:51 [echo] ======================================
build 14-Aug-2012 17:47:51 [echo] If you see errors above please see the file C:\CI7/targets/WTAgent7/eclipse/results/com.xx.codenav.bookmarking.tests.BookmarkingSWTBotTestSuite.txt for more information.
build 14-Aug-2012 17:47:51 [echo] Errors are generally caused by missing or incorrect dependencies.
the console log :
Install location:
file:/c:/CI7/targets/WTAgent7/eclipse/
Configuration file:
file:/c:/CI7/targets/WTAgent7/eclipse/configuration/config.ini loaded
Configuration location:
Framework located:
file:/c:/CI7/targets/WTAgent7/eclipse/plugins/org.eclipse.osgi_3.7.1.R37x_v20110808-1106.jar
Loading extension: org.eclemma.runtime.equinox
Framework classpath:
file:/c:/CI7/targets/WTAgent7/eclipse/plugins/org.eclemma.runtime.equinox_1.1.0.200908261008/./
file:/c:/CI7/targets/WTAgent7/eclipse/plugins/org.eclemma.runtime.equinox_1.1.0.200908261008/emma.jar
Debug options:
file:/C:/CI7/targets/WTAgent7/eclipse/.options not found
Running Equinox with emma code coverage. (Add -Declemma.help for more information)
Covering the bundles with symbolic name(s): com.xx.codenav.fti.help,com.xx.codenav.ecuworx,com.xx.codenav.ecuworx.cdtconfig.help,com.xx.codenav.bookmarking,com.xx.codenav.ecuworx.cdtconfig,com.xx.codenav.externalsearch,com.xx.codenav.externalsearch.help,com.xx.codenav.cdt.help,com.xx.codenav.cdg.importconfig,com.xx.codenav.exuworx.swblaunchconfigs,com.xx.codenav.core.help,com.xx.codenav.cdt.extensions,com.xx.codenav.ecuworx.swbindexsync,com.xx.codenav.cdt.util,com.xx.codenav.core,com.xx.codenav.externaltexteditor.help,com.xx.codenav.fti,com.xx.codenav.multidomainsearch,com.xx.codenav.help,com.xx.codenav.viewfilters,com.xx.codenav.ecuworx.importconfig,com.xx.codenav.ecuworx.ulf,com.xx.codenav.viewfilters.help,com.xx.codenav,com.xx.codenav.ecuworx.newcfile,com.xx.codenav.multidomainsearch.help,com.xx.codenav.externaltexteditor
Time to load bundles: 47
!SESSION 2012-08-14 17:47:07.281 -----------------------------------------------
eclipse.buildId=M20110909-1335
java.version=1.7.0_03
BootLoader constants: OS=win32, ARCH=x86_64, WS=win32, NL=en_US
Framework arguments: -application org.eclipse.swtbot.eclipse.junit4.headless.swtbottestapplication -product com.xx.ubk.targetproduct.product.product formatter=org.apache.tools.ant.taskdefs.optional.junit.XMLJUnitResultFormatter,C:\CI7/targets/WTAgent7/eclipse/com.xx.codenav.bookmarking.tests.BookmarkingSWTBotTestSuite.xml formatter=org.apache.tools.ant.taskdefs.optional.junit.PlainJUnitResultFormatter -testPluginName com.xx.codenav.bookmarking.tests -className com.xx.codenav.bookmarking.tests.BookmarkingSWTBotTestSuite
Command-line arguments: -application org.eclipse.swtbot.eclipse.junit4.headless.swtbottestapplication -data C:\CI7/builds/ECLDGSSWANALYSER-INT1026TESTPLAN-JOB1/junit-workspace -clean -product com.xx.ubk.targetproduct.product.product formatter=org.apache.tools.ant.taskdefs.optional.junit.XMLJUnitResultFormatter,C:\CI7/targets/WTAgent7/eclipse/com.xx.codenav.bookmarking.tests.BookmarkingSWTBotTestSuite.xml formatter=org.apache.tools.ant.taskdefs.optional.junit.PlainJUnitResultFormatter -testPluginName com.xx.codenav.bookmarking.tests -className com.xx.codenav.bookmarking.tests.BookmarkingSWTBotTestSuite -os win32 -ws win32 -arch x86_64 -consoleLog -debug
!ENTRY org.eclipse.osgi 2 0 2012-08-14 17:47:27.202
!MESSAGE One or more bundles are not resolved because the following root constraints are not resolved:
!SUBENTRY 1 org.eclipse.osgi 2 0 2012-08-14 17:47:27.202
!MESSAGE Bundle reference:file:plugins/com.xx.codenav.testutils_1.12.0.N-20120814-1739/ was not resolved.
!SUBENTRY 2 com.xx.codenav.testutils 2 0 2012-08-14 17:47:27.202
!MESSAGE Missing host Bundle-NativeCode_0.0.0.
!MESSAGE The following is a complete list of bundles which are not resolved, see the prior log entry for the root cause if it exists:
!MESSAGE Bundle com.xx.codenav.bookmarking.tests_1.2.0.N-20120814-1739 [206] was not resolved.
!SUBENTRY 2 com.xx.codenav.bookmarking.tests 2 0 2012-08-14 17:47:27.202
!MESSAGE Missing required bundle com.xx.codenav.testutils_0.0.0.
!MESSAGE Bundle com.xx.codenav.cdg.importconfig.tests_1.0.0.N-20120814-1739 [208] was not resolved.
!SUBENTRY 2 com.xx.codenav.cdg.importconfig.tests 2 0 2012-08-14 17:47:27.202
!MESSAGE Bundle com.xx.codenav.cdt.extensions.ecuworx.tests_1.10.0.N-20120814-1739 [210] was not resolved.
!SUBENTRY 2 com.xx.codenav.cdt.extensions.ecuworx.tests 2 0 2012-08-14 17:47:27.202
!MESSAGE Bundle com.xx.codenav.cdt.util.tests_1.8.0.N-20120814-1739 [214] was not resolved.
!SUBENTRY 2 com.xx.codenav.cdt.util.tests 2 0 2012-08-14 17:47:27.202
!MESSAGE Bundle com.xx.codenav.core.tests_1.10.0.N-20120814-1739 [218] was not resolved.
!SUBENTRY 2 com.xx.codenav.core.tests 2 0 2012-08-14 17:47:27.202
!MESSAGE Bundle com.xx.codenav.ecuworx.cdtconfig.tests_1.1.0.N-20120814-1739 [222] was not resolved.
!SUBENTRY 2 com.xx.codenav.ecuworx.cdtconfig.tests 2 0 2012-08-14 17:47:27.202
!MESSAGE Bundle com.xx.codenav.ecuworx.newcfile.tests_1.0.0.N-20120814-1739 [225] was not resolved.
!SUBENTRY 2 com.xx.codenav.ecuworx.newcfile.tests 2 0 2012-08-14 17:47:27.202
!MESSAGE Bundle com.xx.codenav.ecuworx.swbindexsync.tests_1.0.0.N-20120814-1739 [227] was not resolved.
!SUBENTRY 2 com.xx.codenav.ecuworx.swbindexsync.tests 2 0 2012-08-14 17:47:27.202
!MESSAGE Bundle com.xx.codenav.ecuworx.ulf.tests_1.0.0.N-20120814-1739 [229] was not resolved.
!SUBENTRY 2 com.xx.codenav.ecuworx.ulf.tests 2 0 2012-08-14 17:47:27.202
!MESSAGE Bundle com.xx.codenav.externalsearch.tests_1.2.0.N-20120814-1739 [232] was not resolved.
!SUBENTRY 2 com.xx.codenav.externalsearch.tests 2 0 2012-08-14 17:47:27.202
!MESSAGE Bundle com.xx.codenav.externaltexteditor.tests_1.7.0.N-20120814-1739 [235] was not resolved.
!SUBENTRY 2 com.xx.codenav.externaltexteditor.tests 2 0 2012-08-14 17:47:27.202
!MESSAGE Bundle com.xx.codenav.exuworx.swblaunchconfigs.tests_1.0.0.N-20120814-1739 [237] was not resolved.
!SUBENTRY 2 com.xx.codenav.exuworx.swblaunchconfigs.tests 2 0 2012-08-14 17:47:27.202
!MESSAGE Bundle com.xx.codenav.fti.tests_1.11.0.N-20120814-1739 [241] was not resolved.
!SUBENTRY 2 com.xx.codenav.fti.tests 2 0 2012-08-14 17:47:27.202
!MESSAGE Bundle com.xx.codenav.multidomainsearch.tests_1.10.0.N-20120814-1739 [247] was not resolved.
!SUBENTRY 2 com.xx.codenav.multidomainsearch.tests 2 0 2012-08-14 17:47:27.202
!MESSAGE Bundle com.xx.codenav.testutils_1.12.0.N-20120814-1739 [250] was not resolved.
!MESSAGE Bundle com.xx.codenav.viewfilters.tests_1.0.0.N-20120814-1739 [253] was not resolved.
!SUBENTRY 2 com.xx.codenav.viewfilters.tests 2 0 2012-08-14 17:47:27.202
!MESSAGE Bundle org.eclipse.swtbot.ant.optional.junit4_2.0.1.20101106_1831-73ca7af-dev-e36 [1013] was not resolved.
Starting application: 19936
**** SCHEDULE JOB:class com.xx.ubk.wbp.toolusage.logger.util.StartupLog$2
**** JOB ABOUTTORUN:class com.xx.ubk.wbp.toolusage.logger.util.StartupLog$2
**** JOB RUNNING:class com.xx.ubk.wbp.toolusage.logger.util.StartupLog$2
**** SCHEDULE JOB:class org.eclipse.core.internal.events.AutoBuildJob
**** JOB ABOUTTORUN:class org.eclipse.core.internal.events.AutoBuildJob
**** JOB RUNNING:class org.eclipse.core.internal.events.AutoBuildJob
**** JOB DONE:class org.eclipse.core.internal.events.AutoBuildJob
!ENTRY org.eclipse.ui 2 0 2012-08-14 17:47:27.951
!MESSAGE Warnings while parsing the commands from the 'org.eclipse.ui.commands' and 'org.eclipse.ui.actionDefinitions' extension points.
!SUBENTRY 1 org.eclipse.ui 2 0 2012-08-14 17:47:27.951
!MESSAGE Commands should really have a category: plug-in='com.xx.blueworx.validation.reporting.ui', id='com.xx.blueworx.validation.reporting.ui.createReportCommand', categoryId='com.xx.blueworx.validation.ui.commands'
**** JOB DONE:class com.xx.ubk.wbp.toolusage.logger.util.StartupLog$2
**** SCHEDULE JOB:class org.eclipse.mylyn.internal.tasks.ui.TasksUiPlugin$TasksUiInitializationJob
!ENTRY org.eclipse.ui 4 4 2012-08-14 17:47:30.119
!MESSAGE Part already exists in page layout: com.xx.blueworx.core.logging.view.problemslog.
!MESSAGE Referenced part does not exist yet: org.eclipse.spykit.runtime.views.ActivePluginsView.
**** SCHEDULE JOB:class org.eclipse.ui.navigator.CommonNavigatorManager$UpdateActionBarsJob
**** SCHEDULE JOB:class org.eclipse.ui.internal.progress.ProgressViewUpdater$1
Application Started: 34694
**** JOB ABOUTTORUN:class com.xx.dgs.tul.logger.LoggerJob
**** JOB RUNNING:class com.xx.dgs.tul.logger.LoggerJob
**** SCHEDULE JOB:class org.eclipse.ui.internal.Workbench$63
**** JOB ABOUTTORUN:class org.eclipse.mylyn.internal.tasks.ui.TasksUiPlugin$TasksUiInitializationJob
**** JOB RUNNING:class org.eclipse.mylyn.internal.tasks.ui.TasksUiPlugin$TasksUiInitializationJob
**** JOB ABOUTTORUN:class org.eclipse.ui.internal.decorators.DecorationScheduler$2
**** JOB RUNNING:class org.eclipse.ui.internal.decorators.DecorationScheduler$2
**** JOB DONE:class org.eclipse.ui.internal.decorators.DecorationScheduler$2
**** JOB ABOUTTORUN:class org.eclipse.ui.internal.decorators.DecorationScheduler$1
**** JOB RUNNING:class org.eclipse.ui.internal.decorators.DecorationScheduler$1
**** JOB ABOUTTORUN:class org.eclipse.ui.navigator.CommonNavigatorManager$UpdateActionBarsJob
**** JOB ABOUTTORUN:class org.eclipse.ui.internal.Workbench$63
**** JOB RUNNING:class org.eclipse.ui.internal.Workbench$63
**** SCHEDULE JOB:class org.eclipse.ui.internal.progress.AnimationManager$1
**** JOB RUNNING:class org.eclipse.ui.navigator.CommonNavigatorManager$UpdateActionBarsJob
**** JOB ABOUTTORUN:class org.eclipse.ui.internal.progress.ProgressViewUpdater$1
**** JOB RUNNING:class org.eclipse.ui.internal.progress.ProgressViewUpdater$1
**** JOB ABOUTTORUN:class org.eclipse.core.internal.utils.StringPoolJob
**** JOB RUNNING:class org.eclipse.core.internal.utils.StringPoolJob
**** JOB DONE:class org.eclipse.core.internal.utils.StringPoolJob
**** SCHEDULE JOB:class org.eclipse.equinox.internal.p2.engine.ProfilePreferences$SaveJob
**** SCHEDULE JOB:class org.eclipse.ui.internal.AbstractWorkingSetManager$10
**** JOB ABOUTTORUN:class org.eclipse.ui.internal.AbstractWorkingSetManager$10
**** JOB RUNNING:class org.eclipse.ui.internal.AbstractWorkingSetManager$10
**** JOB ABOUTTORUN:class org.eclipse.ui.internal.progress.AnimationManager$1
**** JOB RUNNING:class org.eclipse.ui.internal.progress.AnimationManager$1
**** SCHEDULE JOB:class org.eclipse.team.internal.ui.TeamUIPlugin$2
**** SCHEDULE JOB:class org.eclipse.jdt.internal.core.JavaModelManager$19
**** JOB ABOUTTORUN:class org.eclipse.jdt.internal.core.JavaModelManager$19
**** JOB RUNNING:class org.eclipse.jdt.internal.core.JavaModelManager$19
**** JOB DONE:class org.eclipse.jdt.internal.core.JavaModelManager$19
**** SCHEDULE JOB:class org.eclipse.mylyn.internal.builds.ui.BuildsStartup$1
**** JOB ABOUTTORUN:class org.eclipse.mylyn.internal.builds.ui.BuildsStartup$1
**** JOB RUNNING:class org.eclipse.mylyn.internal.builds.ui.BuildsStartup$1
**** SCHEDULE JOB:class org.eclipse.ui.internal.progress.TaskBarProgressManager$2
**** JOB ABOUTTORUN:class org.eclipse.ui.internal.progress.TaskBarProgressManager$2
**** JOB RUNNING:class org.eclipse.ui.internal.progress.TaskBarProgressManager$2
**** JOB ABOUTTORUN:class org.eclipse.equinox.internal.p2.engine.ProfilePreferences$SaveJob
**** JOB RUNNING:class org.eclipse.equinox.internal.p2.engine.ProfilePreferences$SaveJob
**** JOB DONE:class org.eclipse.equinox.internal.p2.engine.ProfilePreferences$SaveJob
**** SCHEDULE JOB:class org.eclipse.jdt.internal.ui.InitializeAfterLoadJob
**** JOB ABOUTTORUN:class org.eclipse.jdt.internal.ui.InitializeAfterLoadJob
**** JOB RUNNING:class org.eclipse.jdt.internal.ui.InitializeAfterLoadJob
**** JOB DONE:class org.eclipse.ui.internal.Workbench$63
**** SCHEDULE JOB:class org.eclipse.sphinx.emf.internal.model.ModelDescriptorRegistryInitializer
**** JOB ABOUTTORUN:class org.eclipse.sphinx.emf.internal.model.ModelDescriptorRegistryInitializer
**** JOB RUNNING:class org.eclipse.sphinx.emf.internal.model.ModelDescriptorRegistryInitializer
**** SCHEDULE JOB:class org.eclipse.sphinx.platform.util.ExtendedPlatform$4
**** JOB DONE:class org.eclipse.sphinx.emf.internal.model.ModelDescriptorRegistryInitializer
**** JOB ABOUTTORUN:class org.eclipse.sphinx.platform.util.ExtendedPlatform$4
**** JOB RUNNING:class org.eclipse.sphinx.platform.util.ExtendedPlatform$4
**** JOB DONE:class org.eclipse.sphinx.platform.util.ExtendedPlatform$4
Testsuite: com.xx.codenav.bookmarking.tests.BookmarkingSWTBotTestSuite
Tests run: 1, Failures: 0, Errors: 1, Time elapsed: 0 sec
Caused an ERROR
org.eclipse.swtbot.eclipse.junit4.headless.EclipseTestRunner$TestFailedException: java.lang.Exception: Could not find plugin "com.xx.codenav.bookmarking.tests"
at org.eclipse.swtbot.eclipse.junit4.headless.EclipseTestRunner.runFailed(EclipseTestRunner.java:289)
at org.eclipse.swtbot.eclipse.junit4.headless.EclipseTestRunner.getTest(EclipseTestRunner.java:242)
Caused by: java.lang.Exception: Could not find plugin "com.xx.codenav.bookmarking.tests"
**** JOB DONE:class org.eclipse.mylyn.internal.tasks.ui.TasksUiPlugin$TasksUiInitializationJob
**** JOB DONE:class org.eclipse.ui.navigator.CommonNavigatorManager$UpdateActionBarsJob
**** JOB DONE:class org.eclipse.ui.internal.progress.ProgressViewUpdater$1
**** JOB DONE:class org.eclipse.ui.internal.AbstractWorkingSetManager$10
**** JOB DONE:class org.eclipse.ui.internal.progress.AnimationManager$1
**** SCHEDULE JOB:class org.eclipse.cdt.internal.core.settings.model.CProjectDescriptionManager$3
**** SCHEDULE JOB:class org.eclipse.cdt.internal.core.pdom.PDOMManager$2
**** JOB ABOUTTORUN:class org.eclipse.cdt.internal.core.settings.model.CProjectDescriptionManager$3
**** JOB RUNNING:class org.eclipse.cdt.internal.core.settings.model.CProjectDescriptionManager$3
**** JOB ABOUTTORUN:class org.eclipse.cdt.internal.core.pdom.PDOMManager$2
**** JOB RUNNING:class org.eclipse.cdt.internal.core.pdom.PDOMManager$2
**** JOB DONE:class org.eclipse.cdt.internal.core.settings.model.CProjectDescriptionManager$3
**** JOB DONE:class org.eclipse.cdt.internal.core.pdom.PDOMManager$2
**** SCHEDULE JOB:class org.eclipse.cdt.ui.CUIPlugin$2
**** JOB ABOUTTORUN:class org.eclipse.cdt.ui.CUIPlugin$2
**** JOB RUNNING:class org.eclipse.cdt.ui.CUIPlugin$2
**** SCHEDULE JOB:class org.eclipse.cdt.make.internal.ui.MakeStartup
**** JOB ABOUTTORUN:class org.eclipse.cdt.make.internal.ui.MakeStartup
**** JOB RUNNING:class org.eclipse.cdt.make.internal.ui.MakeStartup
**** JOB DONE:class org.eclipse.cdt.ui.CUIPlugin$2
**** JOB DONE:class org.eclipse.cdt.make.internal.ui.MakeStartup
**** JOB DONE:class org.eclipse.mylyn.internal.builds.ui.BuildsStartup$1
**** JOB DONE:class org.eclipse.ui.internal.progress.TaskBarProgressManager$2
**** SCHEDULE JOB:class org.eclipse.jdt.internal.ui.InitializeAfterLoadJob$RealJob
**** JOB ABOUTTORUN:class org.eclipse.jdt.internal.ui.InitializeAfterLoadJob$RealJob
**** JOB DONE:class org.eclipse.jdt.internal.ui.InitializeAfterLoadJob
**** JOB RUNNING:class org.eclipse.jdt.internal.ui.InitializeAfterLoadJob$RealJob
**** JOB DONE:class org.eclipse.jdt.internal.ui.InitializeAfterLoadJob$RealJob
!ENTRY org.eclipse.ui.workbench 4 0 2012-08-14 17:47:43.941
!MESSAGE An unexpected exception was thrown.
!STACK 0
at org.eclipse.ui.internal.WorkbenchWindow.putToolbarLabel(WorkbenchWindow.java:1690)
at org.eclipse.ui.internal.menus.MenuAdditionCacheEntry.createToolBarAdditionContribution(MenuAdditionCacheEntry.java:208)
at org.eclipse.ui.internal.menus.MenuAdditionCacheEntry.createContributionItems(MenuAdditionCacheEntry.java:177)
at org.eclipse.ui.internal.menus.TrimContributionManager.update(TrimContributionManager.java:224)
at org.eclipse.ui.internal.WorkbenchWindow.updateLayoutDataForContents(WorkbenchWindow.java:3867)
at org.eclipse.ui.internal.WorkbenchWindow.setCoolBarVisible(WorkbenchWindow.java:3668)
at org.eclipse.ui.internal.ViewIntroAdapterPart.setBarVisibility(ViewIntroAdapterPart.java:203)
at org.eclipse.ui.internal.ViewIntroAdapterPart.dispose(ViewIntroAdapterPart.java:106)
at org.eclipse.ui.internal.WorkbenchPartReference.doDisposePart(WorkbenchPartReference.java:737)
at org.eclipse.ui.internal.ViewReference.doDisposePart(ViewReference.java:104)
at org.eclipse.ui.internal.WorkbenchPartReference.dispose(WorkbenchPartReference.java:684)
at org.eclipse.ui.internal.WorkbenchPage.disposePart(WorkbenchPage.java:1801)
at org.eclipse.ui.internal.WorkbenchPage.partRemoved(WorkbenchPage.java:1793)
at org.eclipse.ui.internal.ViewFactory.releaseView(ViewFactory.java:257)
at org.eclipse.ui.internal.Perspective.dispose(Perspective.java:292)
at org.eclipse.ui.internal.WorkbenchPage.dispose(WorkbenchPage.java:1872)
at org.eclipse.ui.internal.WorkbenchWindow.closeAllPages(WorkbenchWindow.java:887)
at org.eclipse.ui.internal.WorkbenchWindow.hardClose(WorkbenchWindow.java:1722)
at org.eclipse.ui.internal.WorkbenchWindow.busyClose(WorkbenchWindow.java:730)
at org.eclipse.ui.internal.WorkbenchWindow.access$0(WorkbenchWindow.java:715)
at org.eclipse.ui.internal.WorkbenchWindow$5.run(WorkbenchWindow.java:860)
at org.eclipse.ui.internal.WorkbenchWindow.close(WorkbenchWindow.java:858)
at org.eclipse.jface.window.WindowManager.close(WindowManager.java:109)
at org.eclipse.ui.internal.Workbench$18.run(Workbench.java:1109)
at org.eclipse.ui.internal.Workbench.busyClose(Workbench.java:1106)
at org.eclipse.ui.internal.Workbench.access$15(Workbench.java:1035)
at org.eclipse.ui.internal.Workbench$25.run(Workbench.java:1279)
at org.eclipse.ui.internal.Workbench.close(Workbench.java:1277)
at org.eclipse.ui.internal.Workbench.close(Workbench.java:1249)
at org.eclipse.ui.internal.testing.WorkbenchTestable$2.run(WorkbenchTestable.java:124)
at org.eclipse.swt.widgets.RunnableLock.run(RunnableLock.java:35)
at org.eclipse.swt.widgets.Synchronizer.runAsyncMessages(Synchronizer.java:135)
at org.eclipse.swt.widgets.Display.runAsyncMessages(Display.java:4140)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3757)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.java:2696)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2660)
at org.eclipse.ui.internal.Workbench.access$4(Workbench.java:2494)
at org.eclipse.ui.internal.Workbench$7.run(Workbench.java:674)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:667)
at org.eclipse.ui.internal.ide.application.IDEApplication.start(IDEApplication.java:123)
at org.eclipse.swtbot.eclipse.junit4.headless.UITestApplication.start(UITestApplication.java:53)
at org.eclipse.equinox.internal.app.MainApplicationLauncher.run(MainApplicationLauncher.java:32)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:344)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:622)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:577)
at org.eclipse.equinox.launcher.Main.run(Main.java:1410)
at org.eclipse.equinox.launcher.Main.main(Main.java:1386)
at org.eclipse.core.launcher.Main.main(Main.java:34)
**** JOB ABOUTTORUN:class org.eclipse.mylyn.internal.tasks.core.externalization.ExternalizationManager$ExternalizationJob
**** JOB RUNNING:class org.eclipse.mylyn.internal.tasks.core.externalization.ExternalizationManager$ExternalizationJob
**** JOB DONE:class org.eclipse.ui.internal.decorators.DecorationScheduler$1
**** JOB ABOUTTORUN:class org.eclipse.ui.internal.decorators.DecorationScheduler$3
**** JOB RUNNING:class org.eclipse.ui.internal.decorators.DecorationScheduler$3
**** JOB DONE:class org.eclipse.ui.internal.decorators.DecorationScheduler$3
**** JOB ABOUTTORUN:class org.eclipse.team.internal.ui.TeamUIPlugin$2
**** JOB RUNNING:class org.eclipse.team.internal.ui.TeamUIPlugin$2
**** JOB DONE:class org.eclipse.team.internal.ui.TeamUIPlugin$2
**** JOB DONE:class org.eclipse.mylyn.internal.tasks.core.externalization.ExternalizationManager$ExternalizationJob
**** JOB DONE:class org.eclipse.egit.ui.Activator$RepositoryChangeScanner
**** SCHEDULE JOB:class org.eclipse.ui.internal.console.IOConsolePartitioner$QueueProcessingJob
**** JOB DONE:class org.eclipse.ui.internal.console.IOConsolePartitioner$QueueProcessingJob
**** JOB ABOUTTORUN:class org.eclipse.mylyn.internal.monitor.ui.CheckActivityJob
**** JOB RUNNING:class org.eclipse.mylyn.internal.monitor.ui.CheckActivityJob
**** JOB DONE:class org.eclipse.mylyn.internal.monitor.ui.CheckActivityJob
!ENTRY org.eclipse.core.jobs 2 2 2012-08-14 17:47:49.694
!MESSAGE Job found still running after platform shutdown. Jobs should be canceled by the plugin that scheduled them during shutdown: com.xx.dgs.tul.logger.LoggerJob
Collecting coverage Meta data for bundle com.xx.codenav
Collecting coverage Meta data for bundle com.xx.codenav.bookmarking
Collecting coverage Meta data for bundle com.xx.codenav.cdg.importconfig
Collecting coverage Meta data for bundle com.xx.codenav.cdt.extensions
Collecting coverage Meta data for bundle com.xx.codenav.cdt.help
Collecting coverage Meta data for bundle com.xx.codenav.cdt.util
Collecting coverage Meta data for bundle com.xx.codenav.core
Collecting coverage Meta data for bundle com.xx.codenav.core.help
Collecting coverage Meta data for bundle com.xx.codenav.ecuworx
Collecting coverage Meta data for bundle com.xx.codenav.ecuworx.cdtconfig
Collecting coverage Meta data for bundle com.xx.codenav.ecuworx.cdtconfig.help
Collecting coverage Meta data for bundle com.xx.codenav.ecuworx.importconfig
Collecting coverage Meta data for bundle com.xx.codenav.ecuworx.newcfile
Collecting coverage Meta data for bundle com.xx.codenav.ecuworx.swbindexsync
Collecting coverage Meta data for bundle com.xx.codenav.ecuworx.ulf
Collecting coverage Meta data for bundle com.xx.codenav.externalsearch
Collecting coverage Meta data for bundle com.xx.codenav.externalsearch.help
Collecting coverage Meta data for bundle com.xx.codenav.externaltexteditor
Collecting coverage Meta data for bundle com.xx.codenav.externaltexteditor.help
Collecting coverage Meta data for bundle com.xx.codenav.exuworx.swblaunchconfigs
Collecting coverage Meta data for bundle com.xx.codenav.fti
Collecting coverage Meta data for bundle com.xx.codenav.fti.help
Collecting coverage Meta data for bundle com.xx.codenav.help
Collecting coverage Meta data for bundle com.xx.codenav.multidomainsearch
Collecting coverage Meta data for bundle com.xx.codenav.multidomainsearch.help
Collecting coverage Meta data for bundle com.xx.codenav.viewfilters
Collecting coverage Meta data for bundle com.xx.codenav.viewfilters.help
Saving session data to: C:\CI7/builds/ECLDGSSWANALYSER-INT1026TESTPLAN-JOB1/test-plugins/cvg/emma_coverage.es
Current Time: Sat Jul 26 02:43:47 EDT 2025
Powered by FUDForum. Page generated in 0.49652 seconds
