Home » Eclipse Projects » SWTBot » How Import Projects with Swtbot
How Import Projects with Swtbot [message #869912] Fri, 04 May 2012 14:49 Go to next message
Hi guys.
I need to now how to import projects to workspace using a SWTBot?
bot.tree().expandNode("General").select("Existing Projects into Workspace");
	    bot.button("Next >").click();
After this, what i have to do?
How navigated in windows folders? Its possible?
Thanks for helping.
Re: How Import Projects with Swtbot [message #870473 is a reply to message #869912] Tue, 08 May 2012 07:30 Go to previous messageGo to next message
Import projects is a eclipse dialog. you can select the radio button and do the setText into the textbox.
bot.radio("Select root directory:").click();
bot.text(0).setText("directory path"); //you have to specify your project folder path here
If you want to handle native OS dialogs. you have to use presShortcut and keystrokes for that.
Re: How Import Projects with Swtbot [message #871256 is a reply to message #870473] Fri, 11 May 2012 12:32 Go to previous messageGo to next message
Hello Sandeep Mor, thanks for help me in this problem.
Its works!
You tell me if it is possible to run several tests swtbot one after the other before I send it perform?
How is this done?
Re: How Import Projects with Swtbot [message #871265 is a reply to message #871256] Fri, 11 May 2012 13:14 Go to previous messageGo to next message
Do you want to run multiple tests of swtbot? You can create Junit tests and can use single instance of swtworkbenchbot. Please provide me more details about your requirements.
Re: How Import Projects with Swtbot [message #871273 is a reply to message #871265] Fri, 11 May 2012 13:39 Go to previous messageGo to next message
Yes, i want to run multiple tests of swtbot in the same time, one after one.
Please see attached image.
I need to create a code to perform all the files one by one in an automated manner, without going on the run -> swtbot test;
It is possible to do this?
Sorry to ask so many questions, but I am new to swtbot.
  • Attachment: img.jpg
    (Size: 21.61KB, Downloaded 1230 times)
Re: How Import Projects with Swtbot [message #871275 is a reply to message #871273] Fri, 11 May 2012 13:49 Go to previous messageGo to next message
Hi Miguel,
You can group your multiple test classes into test suite. That is basically a group of tests. You can create test suite following below link and you can add your test classes into this suite.
help.eclipse.org/helios/index.jsp?topic=%2Forg.eclipse.jdt.doc.user%2FgettingStarted%2Fqs-junit.htm
Re: How Import Projects with Swtbot [message #871277 is a reply to message #871275] Fri, 11 May 2012 13:53 Go to previous messageGo to next message
Thanks again for your help.
I'll try to do as the link above.
thank you very much!!!
Re: How Import Projects with Swtbot [message #872308 is a reply to message #871277] Tue, 15 May 2012 17:51 Go to previous messageGo to next message
Hello, I'm not able to perform several consecutive tests.
Using this code:
package pacote;
import org.junit.runner.RunWith;
import org.junit.runners.Suite;
import org.junit.runners.Suite.SuiteClasses;
@RunWith(Suite.class)
@SuiteClasses({
	Hello_World.class,
	CopyOfHello_World.class})
public class Testes {
Only one of the tests are executed, the next run and not reach out ...
What am I doing wrong?
see the attached image
  • Attachment: barra.jpg
    (Size: 49.65KB, Downloaded 287 times)
[Updated on: Tue, 15 May 2012 17:52] by Moderator
Re: How Import Projects with Swtbot [message #872310 is a reply to message #872308] Tue, 15 May 2012 17:53 Go to previous message
Using the Junit Test Suite case, not work.
Previous Topic:Generate Test Report
Next Topic:Workspace issue in SWTBot test
Current Time: Wed Jul 23 20:38:21 EDT 2025
Powered by FUDForum. Page generated in 0.09567 seconds
