Home » Eclipse Projects » SWTBot » SWTBot UI Test(SWTBot UI Test Error)
SWTBot UI Test [message #826824] Thu, 22 March 2012 10:52 Go to next message
Hello!
I use SWTBot to test my UI.
In my test i start the UI and close the welcome window:
SWTBotView eclipseView = bot.activeView();
if (eclipseView != null && view.getTitle().equals("Welcome")) {
eclipseView.close();
After that i set the perspective:
bot.perspectiveByLabel(perspective).activate();
And after that i will do this:
bot.menu("File").menu("New").menu("Java Project").click();
I will open a new java project and at this point i get an error like this:
Error in --> AbstractSWTBot.class:
public AbstractSWTBot(T w, SelfDescribing description) throws
WidgetNotFoundException {
if (w == null)
throw new WidgetNotFoundException("The widget was null.");
Error Trace:
org.eclipse.swtbot.swt.finder.exceptions.WidgetNotFoundException: The widget was null.
at org.eclipse.swtbot.swt.finder.widgets.AbstractSWTBot.<init>(AbstractSWTBot.java:97)
at org.eclipse.swtbot.swt.finder.widgets.SWTBotMenu.<init>(SWTBotMenu.java:42)
at org.eclipse.swtbot.swt.finder.widgets.SWTBotMenu.menu(SWTBotMenu.java:96)
at com.dfe.esom.freezer.ui.graphic.UITest.createNewJavaProject(UITest.java:62)
Any ideas or hints what may be the cause of this?
Thanks!
[Updated on: Fri, 23 March 2012 09:33] by Moderator
Re: SWTBot UI Test [message #828158 is a reply to message #826824] Sat, 24 March 2012 05:37 Go to previous messageGo to next message
On 03/22/2012 03:52 PM, Kollin Krause wrote:
> Hello!
> if (w == null)
> Error Trace:
> widget was null.
> at
> at
> at
> at
which perspective are you switching to? Because "Java Project" is
available right after "New" only in the Java perspective... you may
want to try this code which should work with all the perspectives
bot.menu("File").menu("New").menu("Project...").click();
SWTBotShell shell = bot.shell("New Project");
shell.activate();
bot.tree().select("Java Project");
bot.button("Next >").click();
hope this helps
Lorenzo
ICQ# lbetto, 16080134 (GNU/Linux User # 158233)
HOME: http://www.lorenzobettini.it MUSIC: http://www.purplesucker.com
http://www.myspace.com/supertrouperabba
BLOGS: http://tronprog.blogspot.com http://longlivemusic.blogspot.com
http://www.gnu.org/software/src-highlite
http://www.gnu.org/software/gengetopt
http://www.gnu.org/software/gengen http://doublecpp.sourceforge.net
Re: SWTBot UI Test [message #829377 is a reply to message #828158] Mon, 26 March 2012 03:59 Go to previous messageGo to next message
Thank you very much ... it works, but after the code:
I create my new Project File with:
bot.button("Finish").click();
The project is created, but after a short while i get this error:
!MESSAGE Unhandled event loop exception
!STACK 0
java.lang.OutOfMemoryError: PermGen space
at java.lang.ClassLoader.defineClass1(Native Method)
at java.lang.ClassLoader.defineClassCond(Unknown Source)
at java.lang.ClassLoader.defineClass(Unknown Source)
at org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.defineClass(DefaultClassLoader.java:188)
at org.eclipse.osgi.baseadaptor.loader.ClasspathManager.defineClass(ClasspathManager.java:601)
at org.eclipse.osgi.baseadaptor.loader.ClasspathManager.findClassImpl(ClasspathManager.java:567)
at org.eclipse.osgi.baseadaptor.loader.ClasspathManager.findLocalClassImpl(ClasspathManager.java:490)
at org.eclipse.osgi.baseadaptor.loader.ClasspathManager.findLocalClass_LockClassLoader(ClasspathManager.java:478)
at org.eclipse.osgi.baseadaptor.loader.ClasspathManager.findLocalClass(ClasspathManager.java:458)
at org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.findLocalClass(DefaultClassLoader.java:216)
at org.eclipse.osgi.internal.loader.BundleLoader.findLocalClass(BundleLoader.java:400)
at org.eclipse.osgi.internal.loader.SingleSourcePackage.loadClass(SingleSourcePackage.java:35)
at org.eclipse.osgi.internal.loader.BundleLoader.findClassInternal(BundleLoader.java:473)
at org.eclipse.osgi.internal.loader.BundleLoader.findClass(BundleLoader.java:429)
at org.eclipse.osgi.internal.loader.BundleLoader.findClass(BundleLoader.java:417)
at org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.loadClass(DefaultClassLoader.java:107)
at org.eclipse.osgi.internal.loader.BundleLoader.loadClass(BundleLoader.java:345)
at org.eclipse.osgi.framework.internal.core.BundleHost.loadClass(BundleHost.java:229)
at org.eclipse.osgi.framework.internal.core.AbstractBundle.loadClass(AbstractBundle.java:1207)
at org.eclipse.core.internal.registry.osgi.RegistryStrategyOSGI.createExecutableExtension(RegistryStrategyOSGI.java:174)
at org.eclipse.core.internal.registry.ExtensionRegistry.createExecutableExtension(ExtensionRegistry.java:905)
at org.eclipse.core.internal.registry.ConfigurationElement.createExecutableExtension(ConfigurationElement.java:243)
at org.eclipse.core.internal.registry.ConfigurationElementHandle.createExecutableExtension(ConfigurationElementHandle.java:55)
at org.eclipse.ui.internal.WorkbenchPlugin.createExtension(WorkbenchPlugin.java:260)
at org.eclipse.ui.internal.registry.ViewDescriptor.createView(ViewDescriptor.java:63)
at org.eclipse.ui.internal.ViewReference.createPartHelper(ViewReference.java:327)
at org.eclipse.ui.internal.ViewReference.createPart(ViewReference.java:229)
at org.eclipse.ui.internal.WorkbenchPartReference.getPart(WorkbenchPartReference.java:595)
at org.eclipse.ui.internal.Perspective.showView(Perspective.java:2245)
at org.eclipse.ui.internal.WorkbenchPage.busyShowView(WorkbenchPage.java:1145)
at org.eclipse.ui.internal.WorkbenchPage$20.run(WorkbenchPage.java:3921)
Thanks!
Re: SWTBot UI Test [message #831144 is a reply to message #829377] Wed, 28 March 2012 10:22 Go to previous messageGo to next message
You should increase the permgen space in the launch of your swtbot test...
I usually do that by setting these arguments in the launch
-Xms40m -Xmx384m -XX:MaxPermSize=256m
hope this helps :)
cheers
Lorenzo
> !STACK 0
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at java.lang.ClassLoader.loadClass(Unknown Source)
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> Thanks!
Re: SWTBot UI Test [message #831723 is a reply to message #831144] Thu, 29 March 2012 04:57 Go to previous message
Hello Lorenzo!
Thank you for your reply. It works! Wink
Kollin
[Updated on: Thu, 29 March 2012 04:57] by Moderator
Previous Topic:find a context menu (which has a keyboard shortcut)
Next Topic:How about enhancing SWTBot to support more Nebula widgets?
Current Time: Thu Jul 24 21:34:03 EDT 2025
Powered by FUDForum. Page generated in 0.05229 seconds
