Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc)  » Cannot create Migrator (Edapt/COPE)(emf model migration)
Cannot create Migrator (Edapt/COPE) [message #714805] Thu, 11 August 2011 10:28 Go to next message
I have installed Edapt:
http://www.eclipse.org/edapt/
and downloaded the example from:
http://cope.in.tum.de/uploads/Documentation/statemachine_models.zip
I have then added a new reference to a type in the model and released the modified model change. Next I would like to create a migrator.
But when I right-click the History node and select 'Edapt' I can only select 'Check for integrity' or 'Check for breaking changes'. Where did the 'Create migrator' go as shown in the demo:
http://cope.in.tum.de/pmwiki.php?n=Demo.Main
Right clicking the 'Release xxx' node gives some more options. One of those is 'Create Custom Migration' but that just launches the wizard to create a custom class for specialized migration code - which should not be necessay.
Any suggestions?
Re: Cannot create Migrator (Edapt/COPE) [message #715146 is a reply to message #714805] Fri, 12 August 2011 09:50 Go to previous messageGo to next message
Edapt is different from COPE in the sense that the migrator no longer
needs to be migrated, but the history is directly interpreted. To
register the history, you need to use the extension point
"org.eclipse.emf.edapt.migrators" from the plugin
"org.eclipse.emf.edapt.history". Then you can use the migrator from the
second Eclipse instance like before.
Sorry, but I did not yet find the time to update the documentation of
Edapt. However, I will try to improve the documentation in the next few
weeks.
Markus
Am 11.08.2011 16:28, schrieb js:
> be necessay.
> Any suggestions?
Re: Cannot create Migrator (Edapt/COPE) [message #865565 is a reply to message #715146] Mon, 30 April 2012 09:11 Go to previous messageGo to next message
I have created metamodel and a model.Now I want to change metamodel and check how it works on the model.I used a reuse operation 'rename' , executed the operation and released the history. Now I was stuck at registering the history to migrate the model. I went through the Edapt tutorial.
But I was not clear with the below statements.
To register the history, you need to use the extension point
Could someone please explain what I have to do in the eclipse editor with the above statements or provide me with some tutorial.
Lucky
Re: Cannot create Migrator (Edapt/COPE) [message #867379 is a reply to message #865565] Tue, 01 May 2012 05:00 Go to previous messageGo to next message
you have to open the plugin.xml Editor and go to the Extensions tab and
here you need to add an extension for extension point
org.eclipse.emf.edapt.migrators like shown in the attached image. If you
do not find the extension point, you have to add the plugin
org.eclipse.emf.edapt.history in the Dependencies tab.
If you have further questions, do not hesitate to ask.
Markus
Am 30.04.2012 15:11, schrieb lucky informatik:
> tutorial.
> Lucky
Re: Cannot create Migrator (Edapt/COPE) [message #867809 is a reply to message #867379] Tue, 01 May 2012 09:48 Go to previous messageGo to next message
Thank you.Now I understood:)
(Edapt/COPE) [message #869551 is a reply to message #867809] Thu, 03 May 2012 11:13 Go to previous messageGo to next message
I created a metamodel and a model and I changed my metamodel by adding a subclass, using Edapt operation and migrated(validated) model. My idea was to create a subclass so that I can change the superclass instance as subclass instance. For that I deleted the super class instance manually and created the same as a subclass instance.
I have heard that by using transformations(model transformation tools) the superclass instances can be transformed to subclass instances. I would like to know if there is some option available which automatically changes the superclass instances as subclass instances.
Lucky
[Updated on: Thu, 03 May 2012 11:25] by Moderator
Re: (Edapt/COPE) [message #869887 is a reply to message #869551] Fri, 04 May 2012 12:09 Go to previous messageGo to next message
Sorry, but there is no explicit operation for that. However, you can use
MakeClassAbstract which allows you to set a subclass to which the
instances of the class that is made abstract are to be migrated. Then
you can use InlineSuperClass to inline the super class into the
subclass. I hope this fits your purpose.
Am 03.05.2012 17:13, schrieb lucky informatik:
> subclass instance. For that I deleted the super class instance and
> Lucky
Re: (Edapt/COPE) [message #870497 is a reply to message #869887] Tue, 08 May 2012 08:45 Go to previous messageGo to next message
Thank you very much. Please could you also clarify me whether meta-model evolution and model co-evolution be considered as one of the types of vertical inconsistency ?
Lucky
Re: (Edapt/COPE) [message #870562 is a reply to message #870497] Tue, 08 May 2012 14:00 Go to previous messageGo to next message
By the way: I now also created a web site which provides the
documentation for all operations:
http://www.eclipse.org/edapt/operations.php
The consistency between a model and the metamodel to which it conforms
is called vertical consistency. If a metamodel evolves, this might thus
result in a vertical inconsistency between the model and the metamodel.
To re-establish the vertical consistency, you need to co-evolve your
model. I hope this explains the terminology.
Am 08.05.2012 14:45, schrieb lucky informatik:
> Lucky
Re: (Edapt/COPE) [message #870650 is a reply to message #870562] Wed, 09 May 2012 04:33 Go to previous messageGo to next message
Thanks for clarifying and the website helps a lot for the beginners like me:)
Lucky
Re: (Edapt/COPE) [message #882825 is a reply to message #870650] Thu, 07 June 2012 05:23 Go to previous messageGo to next message
I need some information.I have seen some classifications for metamodel changes in some literature for metamodel matching approaches like non-breaking, breakable and resolvable, breakable and non resolvable.I would like to know if these classifications are applied for operation based approaches or if there are some other classifications.Please let me know if there is some literature corresponding to these classifications.
I would also like to know if there is some theory behind in creating the operators in EDAPT.
Lucky
Re: (Edapt/COPE) [message #882874 is a reply to message #882825] Thu, 07 June 2012 07:14 Go to previous messageGo to next message
Hi Lucky,
have you taken a look at the publications that listed on the Edapt page:
http://www.eclipse.org/edapt/publications.php
Maybe the following publication gives you some information about
classifications of operators and provides also references to futher
literature:
An Extensive Catalog of Operators for the Coupled Evolution of
Metamodels and Models. Markus Herrmannsdoerfer, Sander Vermolen, and
Guido Wachsmuth. In Proceedings of the 3rd International Conference on
Software Language Engineering (SLE). (2010)
I hope this helps.
Markus
Am 07.06.2012 11:23, schrieb lucky informatik:
> operators in EDAPT.
> Lucky
Re: (Edapt/COPE) [message #890016 is a reply to message #882874] Wed, 20 June 2012 11:11 Go to previous messageGo to next message
Thanks for the information.
I have another question out of my curiosity. Suppose we make some changes to meta-model using Edapt. For example: rename or delete feature. Then we save ecore model and re-load gen-model. Then we observe some error in the source, edit or editor codes. I normally edit the java implementations to remove the errors and then migrate.
I would like to know if there is other process to automatically get rid of those erros?
Lucky
Re: (Edapt/COPE) [message #891310 is a reply to message #890016] Sun, 24 June 2012 12:35 Go to previous messageGo to next message
Hi Lucky,
unfortunately, at the moment, there is no such support in Edapt.
However, I have already thought about this feature and have some ideas
how this can be implemented. The idea would be that an operation also
triggers a code refactoring operation. Unfortunately, I do not have
resources to implement such a feature at the moment. If you have
resources and want to implement such a feature, we can of course
integrate it into Edapt.
Markus
Am 20.06.2012 17:11, schrieb lucky informatik:
> of those erros?
> Lucky
Re: (Edapt/COPE) [message #892712 is a reply to message #891310] Fri, 29 June 2012 06:14 Go to previous message
Hi Markus,
Thanks for the reply. As you know from my questions I just started using Edapt and would like to use it for various examples. In future when I have some plans on this, I'll certainly get back to you.
Best wishes,
Lucky
Previous Topic:my EMF model generated tests...
Next Topic:Hibernate tool for JUNO
Current Time: Sat Jul 26 17:01:23 EDT 2025
Powered by FUDForum. Page generated in 0.08518 seconds
