Home » Eclipse Projects » SWTBot » SWTBot headless problem(my osgi does not init bundle .swtbot..headless...)
SWTBot headless problem [message #705206] Fri, 29 July 2011 11:09 Go to next message
Dear friends of RCP,
Currently I am trying to get SWTBot headless tests running using my Windows7 / Indigo / x86 (32bit) installation. I have a nice .cmd file (which can actually start my product in the target), but when I try with swtbottestapplication, things go terribly awry. The clue seems to be that the headless plugin asks for import package org.eclipse.ui (NOT Required Bundle), which osgi obviously does not want to provide.
Any help highly appreciated.
Kind regards,
Bernhard
Start Command
C:\ANBInstall\Sun\jdk32_6_23\bin\java ^
-Xms256m -Xmx768m -XX:MaxPermSize=512m ^
-classpath c:\ANBWork\ANBERNCommander.wip\test\eclipse\plugins\org.eclipse.equinox.launcher_1.2.0.v20110502.jar ^
org.eclipse.core.launcher.Main ^
-install C:/ANBWork/ANBERNCommander.wip/test/eclipse ^
-application org.eclipse.swtbot.eclipse.junit4.headless.swtbottestapplication ^
-testApplication com.anbern.commander.application ^
-product com.anbern.commander.product ^
-data C:/ANBWork/ANBERNCommander.wip/test/workspace ^
formatter=org.apache.tools.ant.taskdefs.optional.junit.XMLJUnitResultFormatter,C:/ANBWork/ANBERNCommander.wip/test/result/TestResult.xml ^
-testPluginName com.anbern.commander.test ^
-className com.anbern.commander.test.CommanderUITest ^
-arch x86 ^
-debug ^
-consoleLog
Config.ini
(located in eclipse/configuration)
#Product Runtime Configuration File
osgi.bundles.defaultStartLevel=4
osgi.install.area=C:\ANBWork\ANBERNCommander.wip\test\eclipse
osgi.bundles=com.anbern.commander,\
  com.ibm.icu,\
  org.eclipse.core.commands,\
  org.eclipse.core.contenttype,\
  org.eclipse.core.databinding,\
  org.eclipse.core.databinding.beans,\
  org.eclipse.core.databinding.observable,\
  org.eclipse.core.databinding.property,\
  org.eclipse.core.expressions,\
  org.eclipse.core.jobs,\
  org.eclipse.core.runtime@start,\
  org.eclipse.core.runtime.compatibility.auth,\
  org.eclipse.equinox.common@2:start,\
  org.eclipse.equinox.preferences,\
  org.eclipse.equinox.registry,\
  org.eclipse.equinox.app,\
  org.eclipse.equinox.ds,\
  org.eclipse.equinox.launcher,\
  org.eclipse.equinox.simpleconfigurator,\
  org.eclipse.equinox.util,\
  org.eclipse.rcp,\
  org.eclipse.update.configurator,\
  org.eclipse.jface,\
  org.eclipse.jface.databinding,\
  org.eclipse.osgi.services,\
  org.eclipse.swt,\
  org.eclipse.swt.win32.win32.x86,\
  org.eclipse.ui,\
  org.eclipse.ui.workbench,\
  org.eclipse.help,\
  org.eclipse.core.runtime.compatibility,\
  org.apache.log4j,\
  org.hamcrest,\
  org.hamcrest.text,\
  org.hamcrest.library,\
  org.hamcrest.integration,\
  org.hamcrest.core,\
  org.apache.ant,\
  org.junit,\
  org.junit4,\
  org.eclipse.jdt.junit.runtime,\
  org.eclipse.swtbot.swt.finder,\
  org.eclipse.swtbot.junit4_x,\
  org.eclipse.swtbot.eclipse.finder,\
  org.eclipse.swtbot.eclipse.core,\
  org.eclipse.swtbot.ant.optional.junit4,\
Result
Sadly, when I run all this I receive:
!ENTRY org.eclipse.osgi 2 0 2011-07-29 16:54:55.249
!MESSAGE One or more bundles are not resolved because the following root constraints are not resolved:
!SUBENTRY 1 org.eclipse.osgi 2 0 2011-07-29 16:54:55.249
!MESSAGE Bundle initial@reference:file:plugins/org.eclipse.swtbot.eclipse.junit4.headless_2.0.4.20110304_0338-e5aff47-dev-e36/ was not resolved.
!SUBENTRY 2 org.eclipse.swtbot.eclipse.junit4.headless 2 0 2011-07-29 16:54:55.249
!MESSAGE Missing imported package org.eclipse.ui_0.0.0.
!ENTRY org.eclipse.osgi 2 0 2011-07-29 16:54:55.265
!MESSAGE The following is a complete list of bundles which are not resolved, see the prior log entry for the root cause if it exists:
!SUBENTRY 1 org.eclipse.osgi 2 0 2011-07-29 16:54:55.265
!MESSAGE Bundle org.eclipse.swtbot.eclipse.junit4.headless_2.0.4.20110304_0338-e5aff47-dev-e36 [141] was not resolved.
!SUBENTRY 2 org.eclipse.swtbot.eclipse.junit4.headless 2 0 2011-07-29 16:54:55.265
!ENTRY org.eclipse.osgi 4 0 2011-07-29 16:54:55.265
!MESSAGE Application error
!STACK 1
java.lang.RuntimeException: Application "org.eclipse.swtbot.eclipse.junit4.headless.swtbottestapplication" could not be found in the registry. The applications available are: com.anbern.commander.application, org.eclipse.equinox.app.error, org.eclipse.swtbot.eclipse.core.swtbottestapplication.
[Updated on: Mon, 01 August 2011 03:00] by Moderator
Re: SWTBot headless problem [message #710871 is a reply to message #705206] Fri, 05 August 2011 10:13 Go to previous message
The org.eclipse.ui is contributed by a couple of plugins including the
org.eclipse.ui.workbench and org.eclipse.ui.ide plugins. I noticed that
the ide plugin is missing from your plugin list, perhaps that could be a
reason why.
There's also a troubleshooting guide for diagnosing headless startup
problems here on the wiki at http://wiki.eclipse.org/SWTBot/OSGi_Console
should you need to poke around which dependencies are missing.
-- Ketan
> Kind regards,
> Bernhard
> Start Command
> -classpath
> -application
> -arch x86 ^
> -debug ^
> -consoleLog
> Config.ini
> com.ibm.icu,\
> org.eclipse.rcp,\
> org.eclipse.jface,\
> org.eclipse.swt,\
> org.eclipse.ui,\
> org.eclipse.help,\
> org.apache.log4j,\
> org.hamcrest,\
> org.hamcrest.text,\
> org.hamcrest.core,\
> org.apache.ant,\
> org.junit,\
> org.junit4,\
> Result
> !MESSAGE Bundle
> was not resolved.
> 16:54:55.249
> !MESSAGE Bundle
> 16:54:55.265
> !STACK 1
Previous Topic:how to use multiple @RunWith annotations
Next Topic:Getting the Wizard member variables of One Page in other Wizard Page.
Current Time: Fri Jul 25 19:28:10 EDT 2025
Powered by FUDForum. Page generated in 0.03942 seconds
