Home » Eclipse Projects » Eclipse Platform » Dependency of all other projects
Dependency of all other projects [message #710530] Fri, 05 August 2011 01:45 Go to next message
is there a plugin or function within Eclipse which shows all dependent
projects of the project - even the inherited ones, selected?
Within the project properties at Java Build Path/[Projects] only the
directly dependent projects are listed. To get all relevant projects I have
to select these projects and to search their dependent projects - thus an
expensive recursion. Is there an easier way - by a plugin or feature; if
yes, by which?
I use Eclipse 3.5.2.
Thomas Wiedmann
Re: Dependency of all other projects [message #711903 is a reply to message #710530] Sat, 06 August 2011 15:51 Go to previous message
General Java projects:
https://code.google.com/p/epdv/
For Plugins/Bundles:
http://www.eclipse.org/pde/incubator/dependency-visualization/
And if you use Maven:
mvn dependency:tree on the aggregating artifact (e.g. ear, war,...).
I have not checked, whether the plugins linked above work with 3.5.2.
HTH
Michael
Previous Topic:new version of plugins not installed after an update
Next Topic:How to play video file from android device not emulator
Current Time: Sat Jul 26 18:51:20 EDT 2025
Powered by FUDForum. Page generated in 0.04310 seconds
