Home » Eclipse Projects » SWTBot » performing doubleclick on a tree item
performing doubleclick on a tree item [message #707428] |
Mon, 01 August 2011 12:31  |
I'm testing the behavior of an EMF Editor which has a tree viewer; I
want to select an item of the tree and perform a doubleclick.
Upon doubleclick the property view should be shown (and I checked
manually) and it works;
however, if I write the following swtbot test, it fails: the properties
view cannot be found, and indeed, by looking at the test in execution
the property view is not shown at all...
@Test
public void canOpenPropertyView() throws Exception {
SWTBotTreeItem treeItemRoot = getRootOfEditorTree();
treeItemRoot.expand().getNode("Library").doubleClick();
bot.sleep(20000);
bot.viewByTitle("Properties");
the strange thing is that if on the running eclipse I manually do a
double click, the property view is opened (I inserted that sleep to
check this)...
and indeed the log seems to report that the doubleclick is actually
performed:
(AbstractSWTBot$2.java:160) - Sent event MouseDoubleClick [8]:
MouseEvent{Tree {} time=-2044031767 data=null button=0 stateMask=0 x=0
y=0 count=0} to Tree node with text: Library
am I doing something wrong?
thanks in advance
Lorenzo
ICQ# lbetto, 16080134 (GNU/Linux User # 158233)
HOME: http://www.lorenzobettini.it MUSIC: http://www.purplesucker.com
http://www.myspace.com/supertrouperabba
BLOGS: http://tronprog.blogspot.com http://longlivemusic.blogspot.com
http://www.gnu.org/software/src-highlite
http://www.gnu.org/software/gengetopt
http://www.gnu.org/software/gengen http://doublecpp.sourceforge.net
Re: performing doubleclick on a tree item [message #707919 is a reply to message #707428] |
Tue, 02 August 2011 04:10   |
I guess that's related to https://bugs.eclipse.org/bugs/process_bug.cgi
the fix is quite easy, but it looks like it hasn't been applied yet...
On 08/01/2011 06:31 PM, Lorenzo Bettini wrote:
> Hi
> @Test
> bot.sleep(20000);
> check this)...
> performed:
> thanks in advance
> Lorenzo
Re: performing doubleclick on a tree item [message #708983 is a reply to message #707919] |
Wed, 03 August 2011 06:32   |
I filed a new bug https://bugs.eclipse.org/bugs/show_bug.cgi?id=353720
and provided a patch... hope it is applied soon
cheers
Lorenzo
>> Hi
>> @Test
>> bot.sleep(20000);
>> check this)...
>> performed:
>> thanks in advance
>> Lorenzo
Re: performing doubleclick on a tree item [message #723366 is a reply to message #708983] |
Thu, 08 September 2011 08:21   |
I noted that no change on the git repository has been pushed for some
months now... is anyone actively working on swtbot?
cheers
Lorenzo
> cheers
> Lorenzo
>>> Hi
>>> @Test
>>> bot.sleep(20000);
>>> check this)...
>>> performed:
>>> thanks in advance
>>> Lorenzo
Re: performing doubleclick on a tree item [message #723382 is a reply to message #723366] |
Thu, 08 September 2011 08:41   |
Hi Lorenzo,
We are not *actively* working on it, has it does its work in general,
but we try to fix issues when we have time to do it.
If you absolutely need the patch application you can fork and maintain
your fork easily thanks to git.
Anyway thanks for your patch, we will have a look.
Mariot
> cheers
> Lorenzo
>> cheers
>> Lorenzo
>>>> Hi
>>>> @Test
>>>> bot.sleep(20000);
>>>> check this)...
>>>> performed:
>>>> thanks in advance
>>>> Lorenzo
Mariot Chauvin @ Obeo
Blog : http://mariot-thoughts.blogspot.com
Twitter :http://twitter.com/mchv
Professional support : http://obeo.fr/pages/maintenance-and-support/
Re: performing doubleclick on a tree item [message #724945 is a reply to message #723382] |
Tue, 13 September 2011 10:54   |
On 09/08/2011 02:41 PM, Mariot Chauvin wrote:
> Hi Lorenzo,
Hi Mariot
sorry I don't understand the above sentence 'has it does its work in
general'... do you mean that you will not maintain SWTBOT anymore?
thanks in advance
cheers
Lorenzo
> Cheers,
> Mariot
>> cheers
>> Lorenzo
>>> cheers
>>> Lorenzo
>>>>> Hi
>>>>> properties
>>>>> @Test
>>>>> bot.sleep(20000);
>>>>> check this)...
>>>>> performed:
>>>>> thanks in advance
>>>>> Lorenzo
Re: performing doubleclick on a tree item [message #724946 is a reply to message #723382] |
> Hi Lorenzo,
Hi Mariot
thanks in advance
cheers
Lorenzo
> Cheers,
> Mariot
>> cheers
>> Lorenzo
>>> cheers
>>> Lorenzo
>>>>> Hi
>>>>> properties
>>>>> @Test
>>>>> bot.sleep(20000);
>>>>> check this)...
>>>>> performed:
>>>>> thanks in advance
>>>>> Lorenzo
Re: performing doubleclick on a tree item [message #724973 is a reply to message #724945] |
Tue, 13 September 2011 12:02   |
>> Hi Lorenzo,
> Hi Mariot
No sorry if it was unclear.
I mean that we (at least I) do not work currently on new features or
major refactoring.
We maintain SWTBot, but we fix issues and integrate patches only when we
have time to do it.
If you need professional support have a look to :
http://obeo.fr/pages/maintenance-et-support/lts/en
If you don't need any support, just need a SWTBot version with some
patches applied and can't wait, you could easily clone the repo thanks
to git and build your own version :).
I hope I was clear this time, and one more time I thank you for your
contribution.
> thanks in advance
> cheers
> Lorenzo
>> Cheers,
>> Mariot
>>> cheers
>>> Lorenzo
>>>> cheers
>>>> Lorenzo
>>>>>> Hi
>>>>>> properties
>>>>>> @Test
>>>>>> bot.sleep(20000);
>>>>>> check this)...
>>>>>> performed:
>>>>>> x=0
>>>>>> thanks in advance
>>>>>> Lorenzo
Re: performing doubleclick on a tree item [message #724990 is a reply to message #724973] |
Tue, 13 September 2011 12:48  |
>>> Hi Lorenzo,
>> Hi Mariot
> major refactoring.
> have time to do it.
OK, I just wanted to be sure that a cool project like SWTBOT didn't
become a dead-project :)
that's what I had already done, for my personal use; I wouldn't want to
create a fork though :)
by the way, I saw that many bugs are quite critical for testing
purposes, like this one, and some others (e.g., not direct support for
context submenus).
> contribution.
thank you!
and I hope you all will soon have time to introduce possible new features :)
cheers
Lorenzo
>> thanks in advance
>> cheers
>> Lorenzo
>>> Cheers,
>>> Mariot
>>>> cheers
>>>> Lorenzo
>>>>> cheers
>>>>> Lorenzo
>>>>>> yet...
>>>>>>> Hi
>>>>>>> properties
>>>>>>> execution
>>>>>>> @Test
>>>>>>> bot.sleep(20000);
>>>>>>> check this)...
>>>>>>> performed:
>>>>>>> x=0
>>>>>>> thanks in advance
>>>>>>> Lorenzo
Current Time: Fri Jul 25 19:33:00 EDT 2025
Powered by FUDForum. Page generated in 0.04333 seconds
