clearing the workspace in @AfterClass [message #704000] |
Thu, 28 July 2011 03:08  |
I've just started using SWTBOT; I tried with the example
http://wiki.eclipse.org/SWTBot/UsersGuide which creates a new project
protected void createSimpleProject() {
bot.menu("File").menu("New").menu("Project...").click();
SWTBotShell shell = bot.shell("New Project");
shell.activate();
bot.tree().expandNode("General").select("Project");
bot.button("Next >").click();
bot.textWithLabel("Project name:").setText(MY_TEST_PROJECT);
bot.button("Finish").click();
waitForAutoBuild();
after creating the project I'm waiting for the autobuild to finish with
this code
public static void waitForAutoBuild() {
boolean wasInterrupted = false;
do {
try {
Job.getJobManager().join(ResourcesPlugin.FAMILY_AUTO_BUILD,
null);
} catch (OperationCanceledException e) {
e.printStackTrace();
} catch (InterruptedException e) {
wasInterrupted = true;
} while (wasInterrupted);
then, I'd like to clear the whole workspace before the next test, then I
wrote
@AfterClass
public static void clean() throws CoreException {
cleanWorkspace();
bot.sleep(2000);
where cleanWorkspace programmatically deletes all the projects in the
workspace.
However, when the second test is executed (for this example I simply
create another project), I get an exception saying that (I guess) the
menu cannot be found
Caused by: org.eclipse.swt.SWTException: Widget is disposed
at org.eclipse.swt.SWT.error(SWT.java:4282)
at org.eclipse.swt.SWT.error(SWT.java:4197)
at org.eclipse.swt.SWT.error(SWT.java:4168)
at org.eclipse.swt.widgets.Widget.error(Widget.java:466)
at org.eclipse.swt.widgets.Widget.checkWidget(Widget.java:403)
at org.eclipse.swt.widgets.Decorations.getMenuBar(Decorations.java:392)
at
org.eclipse.swtbot.swt.finder.finders.MenuFinder$1.run(MenuFinder.java:106)
at
org.eclipse.swtbot.swt.finder.finders.MenuFinder$1.run(MenuFinder.java:1)
at
org.eclipse.swtbot.swt.finder.finders.UIThreadRunnable$2.doRun(UIThreadRunnable.java:140)
at
org.eclipse.swtbot.swt.finder.finders.UIThreadRunnable$1.run(UIThreadRunnable.java:89)
at org.eclipse.swt.widgets.RunnableLock.run(RunnableLock.java:35)
at
org.eclipse.swt.widgets.Synchronizer.runAsyncMessages(Synchronizer.java:135)
... 24 more
am I doing something wrong? Should I clear the workspace using the bot
somehow?
I saw that SWTWorkbenchBot provides resetWorkbench but this does not
seem to remove the projects in the workspace...
thanks in advance
Lorenzo
ICQ# lbetto, 16080134 (GNU/Linux User # 158233)
HOME: http://www.lorenzobettini.it MUSIC: http://www.purplesucker.com
http://www.myspace.com/supertrouperabba
BLOGS: http://tronprog.blogspot.com http://longlivemusic.blogspot.com
http://www.gnu.org/software/src-highlite
http://www.gnu.org/software/gengetopt
http://www.gnu.org/software/gengen http://doublecpp.sourceforge.net
Re: clearing the workspace in @AfterClass [message #704017 is a reply to message #704000] |
Thu, 28 July 2011 03:16  |
Sorry for the noise: since I'm new to Junit4 as well, I wasn't thinking
that @AfterClass does *not* correspond to tearDown (and indeed it's a
static method)!
using
@After
public void runAfterEveryTest() throws CoreException {
cleanWorkspace();
fixes the problem :)
cheers
Lorenzo
On 07/28/2011 09:08 AM, Lorenzo Bettini wrote:
> Hi
> shell.activate();
> waitForAutoBuild();
> this code
> do {
> try {
> null);
> wrote
> @AfterClass
> cleanWorkspace();
> bot.sleep(2000);
> workspace.
> at
> at
> at
> at
> at
> ... 24 more
> somehow?
> thanks in advance
> Lorenzo
FUDForum. Page generated in 0.08826 seconds
