Home » Eclipse Projects » SWTBot » getting started with SWT Bot
getting started with SWT Bot [message #695207] Mon, 11 July 2011 05:20 Go to next message
Originally posted by: robert julian chandradoss
I am pretty new to swt bot and i tried to create my first test
example using the tutorial video
http://download.eclipse.org/technology/swtbot/docs/videos/beginners/SWTBotGettingStartedIn5Minutes/
But, i get error=0 or failure=0. I only get " Runs 0/1 ". Any feed back
is most welcome.
Note: I am running java 1.5 with Junit 4.
/** This is the code I ran as a test in SWT Bot. */
import junit.framework.TestCase;
import org.eclipse.swtbot.eclipse.finder.SWTWorkbenchBot;
import org.junit.Test;
public class SWT_TEST extends TestCase {
private SWTWorkbenchBot bot;
public SWT_TEST() {
bot = new SWTWorkbenchBot();
@Test
public void runTest() throws Exception {
try {
bot.viewByTitle("Welcome").close();
catch(Exception e) {
throw new Exception();
Best regards. --robert julian
Re: getting started with SWT Bot [message #695645 is a reply to message #695207] Tue, 12 July 2011 04:24 Go to previous messageGo to next message
Hi Robert,
It looks as if your test did not actually run. You did not mention how you are running your tests (within eclipse, from the command line, through an ANT task, etc.), but this could come from conflicting JUnit jars/plug-in versions.
I faced a similar issue when I first started using SWTBot. If you dig a little bit I am pretty sure you'll find various threads about it in this forum or a corresponding FAQ/article in the SWTBot Wiki.
Hope this helps,
Re: getting started with SWT Bot [message #695660 is a reply to message #695645] Tue, 12 July 2011 04:44 Go to previous message
On 7/12/2011 1:54 PM, Benjamin Ratiarisolo wrote:
> Hi Robert,
> Hope this helps,
dear benjamin,
thank a lot for the reply. yes, the link was very useful.
i have my first swtbot application up and running!. :).
best regards. --robert julian
Previous Topic:How to get terminate/resume button in debug perspective
Next Topic:Custom Context Menus and Dialogs
Current Time: Wed Jul 23 09:29:44 EDT 2025
Powered by FUDForum. Page generated in 5.24065 seconds
