Home » Eclipse Projects » SWTBot » SWTBot with dialog
SWTBot with dialog [message #692876] Tue, 05 July 2011 07:48 Go to next message
Hi All:
I use SWTBot to test our product.And All My Test works fine on my machine!
Now I move the build to Hudson(use another machine),All my Test goes fine except one.
The failed TestCase need to open a dialog,code:
bot = new SWTWorkbenchBot();
//find view
SWTBot viewbot = bot.viewById(DrugUsedbfxView.ID).bot();
//find text and trigger "enter" will show the dialog
viewbot.textWithId("txtYpbh").pressShortcut(SWT.CR, SWT.LF);
SWTBotShell shellbot = bot.shell("shell name");
shellbot.activate();
bot.buttonWithId("okBtn").click();
When I open the RDP,the case can pass,I close the RDP or minimum the RDP,the case goes wrong.
Re: SWTBot with dialog [message #692877 is a reply to message #692876] Tue, 05 July 2011 07:51 Go to previous messageGo to next message
Exception:
T E S T S
Running com.ztkj.his.zhcx.test.ZhcxMzTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.062 sec
Running com.ztkj.his.zhcx.test.ZhcxZyTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0 sec
Running com.ztkj.his.zhcx.test.ZhcxWzTest
log4j:WARN No appenders could be found for logger (org.eclipse.swtbot.swt.finder.matchers.AbstractMatcher).
log4j:WARN Please initialize the log4j system properly.
Tests run: 17, Failures: 0, Errors: 1, Skipped: 0, Time elapsed: 16.593 sec <<< FAILURE!
testDbfx(com.ztkj.his.zhcx.test.ZhcxWzTest) Time elapsed: 5.734 sec <<< ERROR!
org.eclipse.swtbot.swt.finder.exceptions.WidgetNotFoundException: Could not find widget.
at org.eclipse.swtbot.swt.finder.SWTBotFactory.waitUntilWidgetAppears(SWTBotFactory.java:348)
at org.eclipse.swtbot.swt.finder.SWTBotFactory.shells(SWTBotFactory.java:112)
at org.eclipse.swtbot.swt.finder.SWTBotFactory.shell(SWTBotFactory.java:102)
at org.eclipse.swtbot.swt.finder.SWTBotFactory.shell(SWTBotFactory.java:93)
at com.ztkj.his.zhcx.test.ZhcxWzTest.testDbfx(ZhcxWzTest.java:231)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:39)
at java.lang.reflect.Method.invoke(Method.java:592)
at org.junit.runners.model.FrameworkMethod$1.runReflectiveCall(FrameworkMethod.java:44)
at org.junit.internal.runners.model.ReflectiveCallable.run(ReflectiveCallable.java:15)
at org.junit.runners.model.FrameworkMethod.invokeExplosively(FrameworkMethod.java:41)
at org.junit.internal.runners.statements.InvokeMethod.evaluate(InvokeMethod.java:20)
at org.junit.internal.runners.statements.RunBefores.evaluate(RunBefores.java:28)
at org.junit.runners.BlockJUnit4ClassRunner.runChild(BlockJUnit4ClassRunner.java:76)
at org.junit.runners.BlockJUnit4ClassRunner.runChild(BlockJUnit4ClassRunner.java:50)
at org.junit.runners.ParentRunner$3.run(ParentRunner.java:193)
at org.junit.runners.ParentRunner$1.schedule(ParentRunner.java:52)
at org.junit.runners.ParentRunner.runChildren(ParentRunner.java:191)
at org.junit.runners.ParentRunner.access$000(ParentRunner.java:42)
at org.junit.runners.ParentRunner$2.evaluate(ParentRunner.java:184)
at org.junit.runners.ParentRunner.run(ParentRunner.java:236)
at org.apache.maven.surefire.junit4.JUnit4TestSet.execute(JUnit4TestSet.java:62)
at org.apache.maven.surefire.suite.AbstractDirectoryTestSuite.executeTestSet(AbstractDirectoryTestSuite.java:140)
at org.apache.maven.surefire.suite.AbstractDirectoryTestSuite.execute(AbstractDirectoryTestSuite.java:127)
at org.apache.maven.surefire.Surefire.run(Surefire.java:177)
at org.eclipse.tycho.surefire.osgibooter.OsgiSurefireBooter.run(OsgiSurefireBooter.java:72)
at org.eclipse.tycho.surefire.osgibooter.AbstractUITestApplication.runTests(AbstractUITestApplication.java:44)
at org.eclipse.ui.internal.testing.WorkbenchTestable$1.run(WorkbenchTestable.java:71)
at java.lang.Thread.run(Thread.java:595)
Caused by: org.eclipse.swtbot.swt.finder.widgets.TimeoutException: Timeout after: 5000 ms.: Could not find shell matching: with text '药品资料'
at org.eclipse.swtbot.swt.finder.SWTBotFactory.waitUntil(SWTBotFactory.java:398)
at org.eclipse.swtbot.swt.finder.SWTBotFactory.waitUntil(SWTBotFactory.java:372)
at org.eclipse.swtbot.swt.finder.SWTBotFactory.waitUntil(SWTBotFactory.java:360)
at org.eclipse.swtbot.swt.finder.SWTBotFactory.waitUntilWidgetAppears(SWTBotFactory.java:346)
... 29 more
Re: SWTBot with dialog [message #694265 is a reply to message #692876] Fri, 08 July 2011 04:27 Go to previous message
This reminds me of a similar issue I had when deploying our SWTBot test suites to our continuous integration framework (I am using windows as OS on my development platform while the continuous integration servers usually run on Linux).
I had to specifically set the SWTBot keyboard layouts property for keyboard-shortcut based tests to successfully run in the continuous integration environment: I added '-Dorg.eclipse.swtbot.keyboard.layout=EN_US' in the vmargs property of the swtbot-test ANT task. It seemed to work fine for me then.
You can give it a try.
Previous Topic:"Confirm Disable Builder" Dialog -how to access?
Next Topic:How can I properly select a radio button using SWTBot?
Current Time: Tue Jul 22 22:20:21 EDT 2025
Powered by FUDForum. Page generated in 0.03389 seconds
