Home » Eclipse Projects » SWTBot » STWBot Launch Delegate - Helios
STWBot Launch Delegate - Helios [message #661049] Tue, 22 March 2011 17:56 Go to next message
I am migrating some test plugins that use swtbot to helios. However, I am unable to run my tests with the IDE's SWTBot Test launch delegate. This worked with an older version of eclipse. When I use the launch delegate, I get the error:
Plug-in org.eclipse.swtbot.eclipse.ui was unable to load class org.eclipse.pde.internal.ui.launcher.PDEMigrationDelegate.
It appears that PDEMigrationDelegate has moved to org.eclipse.pde.internal.launching.launcher.PDEMigrationDele gate which is part of org.eclipse.pde.launching.
Is this a bug?
I was able to work around this by tweaking the plugin xml to remove the reference to PDEMigrationDelegate. However, I then noticed that parts of my tests were unexpectedly failing. For example, the following click caused my radio to end up in a strange state:
bot.radio("some button").click();
I was able to workaround this by calling:
// Create the trace configuration file based on manual selection.
SWTBotRadio someRadio = bot.radio("some button.");
someRadio.setFocus();
someRadio.click();
However, it is not clear to me why I now need this extra setFocus when running the test under helios. Any ideas?
Jessica Deery
Re: STWBot Launch Delegate - Helios [message #661254 is a reply to message #661049] Wed, 23 March 2011 13:18 Go to previous messageGo to next message
These seem likely bugs that were introduced. Could you file bugs for the
2 issues and I'll have a look at it.
Ketan
http://ketan.padegaonkar.name | http://eclipse.org/swtbot | @ketanpkr
On 3/22/11 2:56 PM, Jessica Deery wrote:
> Hello,
> Is this a bug?
> someRadio.click();
> Jessica Deery
Re: STWBot Launch Delegate - Helios [message #661280 is a reply to message #661254] Wed, 23 March 2011 16:44 Go to previous message
Logged 340804 and 340808.
Thanks!
Jessica
Previous Topic:SWTBot / Ant
Next Topic:Start SWTBot tests from within Buckminster on Eclipse Hudson
Current Time: Sun Jul 27 01:58:04 EDT 2025
Powered by FUDForum. Page generated in 0.06717 seconds
