Home » Eclipse Projects » SWTBot » java.lang.ClassCastException when running SWTBot tests in headless mode
java.lang.ClassCastException when running SWTBot tests in headless mode [message #654980] Thu, 17 February 2011 15:56 Go to next message
Hi all,
at the moment I am playing with SWTBot which I think is great tool. Everything is working like a charm when running the tests from Eclipse. But when I try to run the tests in headless mode on exported RCP app I am facing serious problem.
RCP app starts correctly but no test is performed on it.
There is this exception in the console:
[java] Exception in thread "WorkbenchTestable" java.lang.NoClassDefFoundError junit/framework/TestListener
which seems to be raised often (Troubleshooting section of SWTBot)
But in the log of the test there is other exception:
java.lang.ClassCastException: "<NameofTheClass>" cannot be cast to org.eclipse.core.commands.IHandler
	at org.eclipse.ui.internal.handlers.HandlerProxy.loadHandler(HandlerProxy.java:334)
	at org.eclipse.ui.internal.handlers.HandlerProxy.isEnabled(HandlerProxy.java:304)
	at org.eclipse.core.commands.Command.isEnabled(Command.java:833)
	at org.eclipse.core.commands.Command.setHandler(Command.java:996)
	at org.eclipse.ui.internal.handlers.HandlerAuthority.updateCommand(HandlerAuthority.java:459)
	at org.eclipse.ui.internal.handlers.HandlerAuthority.activateHandler(HandlerAuthority.java:249)
	at org.eclipse.ui.internal.handlers.HandlerService.activateHandler(HandlerService.java:120)
	at org.eclipse.ui.internal.handlers.HandlerService.activateHandler(HandlerService.java:112)
	at org.eclipse.ui.internal.handlers.HandlerService.activateHandler(HandlerService.java:107)
	at org.eclipse.ui.internal.handlers.HandlerPersistence.readDefaultHandlersFromRegistry(HandlerPersistence.java:250)
	at org.eclipse.ui.internal.handlers.HandlerPersistence.reRead(HandlerPersistence.java:204)
	at org.eclipse.ui.internal.handlers.HandlerPersistence.read(HandlerPersistence.java:158)
	at org.eclipse.ui.internal.handlers.HandlerService.readRegistry(HandlerService.java:186)
	at org.eclipse.ui.internal.handlers.HandlerServiceFactory.create(HandlerServiceFactory.java:61)
	at org.eclipse.ui.internal.services.WorkbenchServiceRegistry.getService(WorkbenchServiceRegistry.java:102)
	at org.eclipse.ui.internal.services.ServiceLocator.getService(ServiceLocator.java:174)
	at org.eclipse.ui.internal.Workbench$43.runWithException(Workbench.java:1675)
	at org.eclipse.ui.internal.StartupThreading$StartupRunnable.run(StartupThreading.java:31)
	at org.eclipse.swt.widgets.Synchronizer.syncExec(Synchronizer.java:178)
	at org.eclipse.ui.internal.UISynchronizer.syncExec(UISynchronizer.java:150)
	at org.eclipse.swt.widgets.Display.syncExec(Display.java:4251)
	at org.eclipse.ui.internal.StartupThreading.runWithoutExceptions(StartupThreading.java:94)
	at org.eclipse.ui.internal.Workbench.initializeDefaultServices(Workbench.java:1671)
	at org.eclipse.ui.internal.Workbench.init(Workbench.java:1318)
	at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2312)
	at org.eclipse.ui.internal.Workbench.access$4(Workbench.java:2198)
	at org.eclipse.ui.internal.Workbench$5.run(Workbench.java:493)
	at org.eclipse.core.databinding.observable.Realm.runWithDefault(Realm.java:288)
	at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:488)
	at com.pikeelectronic.tibco.makedoc.gui.rcp.impl.Application.start(Unknown Source)
	at org.eclipse.swtbot.eclipse.junit4.headless.UITestApplication.start(UITestApplication.java:53)
	at org.eclipse.equinox.internal.app.EclipseAppHandle.run(EclipseAppHandle.java:193)
	at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:382)
	at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:39)
	at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:549)
	at org.eclipse.equinox.launcher.Main.basicRun(Main.java:504)
	at org.eclipse.equinox.launcher.Main.run(Main.java:1236)
	at org.eclipse.equinox.launcher.Main.main(Main.java:1212)
	at org.eclipse.core.launcher.Main.main(Main.java:30)
Application Started: 4985
!ENTRY org.eclipse.equinox.p2.ui.sdk 2 0 2011-02-17 21:36:47.625
!MESSAGE Could not locate the running profile instance
Target class is not implementing IHandler interface, but I don't understand why it is necessary to cast when in Eclipse everything is working well.
Using SWTBot 2.0.2 and Eclipse 3.4.0.
Any help will be appreciated.
JJ
[Updated on: Thu, 17 February 2011 16:01] by Moderator
Re: java.lang.ClassCastException when running SWTBot tests in headless mode [message #655091 is a reply to message #654980] Fri, 18 February 2011 05:03 Go to previous messageGo to next message
The java.lang.NoClassDefFoundError junit/framework/TestListener probably happens because you are missing a swtbot.junit fragment. I suggest you to start your tests with OSGi console enabled (just add the -console option on your command-line), and to investigate to understand why you cannot get SWTBot starting correctly.
HTH
Le 17/02/2011 21:56, Jiri Janecek a écrit :
> Hi all,
> at org.eclipse.ui.internal.handlers.HandlerProxy.loadHandler(Ha ndlerProxy.java:334)
> at org.eclipse.ui.internal.handlers.HandlerProxy.isEnabled(Hand lerProxy.java:304)
> at org.eclipse.core.commands.Command.isEnabled(Command.java:833 )
> at org.eclipse.core.commands.Command.setHandler(Command.java:99 6)
> at org.eclipse.ui.internal.handlers.HandlerAuthority.updateComm and(HandlerAuthority.java:459)
> at org.eclipse.ui.internal.handlers.HandlerAuthority.activateHa ndler(HandlerAuthority.java:249)
> at org.eclipse.ui.internal.handlers.HandlerService.activateHand ler(HandlerService.java:120)
> at org.eclipse.ui.internal.handlers.HandlerService.activateHand ler(HandlerService.java:112)
> at org.eclipse.ui.internal.handlers.HandlerService.activateHand ler(HandlerService.java:107)
> at org.eclipse.ui.internal.handlers.HandlerPersistence.readDefa ultHandlersFromRegistry(HandlerPersistence.java:250)
> at org.eclipse.ui.internal.handlers.HandlerPersistence.reRead(H andlerPersistence.java:204)
> at org.eclipse.ui.internal.handlers.HandlerPersistence.read(Han dlerPersistence.java:158)
> at org.eclipse.ui.internal.handlers.HandlerService.readRegistry (HandlerService.java:186)
> at org.eclipse.ui.internal.handlers.HandlerServiceFactory.creat e(HandlerServiceFactory.java:61)
> at org.eclipse.ui.internal.services.WorkbenchServiceRegistry.ge tService(WorkbenchServiceRegistry.java:102)
> at org.eclipse.ui.internal.services.ServiceLocator.getService(S erviceLocator.java:174)
> at org.eclipse.ui.internal.Workbench$43.runWithException(Workbe nch.java:1675)
> at org.eclipse.ui.internal.StartupThreading$StartupRunnable.run (StartupThreading.java:31)
> at org.eclipse.swt.widgets.Synchronizer.syncExec(Synchronizer.j ava:178)
> at org.eclipse.ui.internal.UISynchronizer.syncExec(UISynchroniz er.java:150)
> at org.eclipse.ui.internal.StartupThreading.runWithoutException s(StartupThreading.java:94)
> at org.eclipse.ui.internal.Workbench.initializeDefaultServices( Workbench.java:1671)
> at org.eclipse.ui.internal.Workbench.access$4(Workbench.java:21 98)
> at org.eclipse.core.databinding.observable.Realm.runWithDefault (Realm.java:288)
> at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:488)
> at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.j ava:149)
> at com.pikeelectronic.tibco.makedoc.gui.rcp.impl.Application.st art(Unknown Source)
> at org.eclipse.swtbot.eclipse.junit4.headless.UITestApplication .start(UITestApplication.java:53)
> at org.eclipse.equinox.internal.app.EclipseAppHandle.run(Eclips eAppHandle.java:193)
> at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .runApplication(EclipseAppLauncher.java:110)
> at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .start(EclipseAppLauncher.java:79)
> at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:382)
> at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:179)
> at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAcce ssorImpl.java:39)
> at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMe thodAccessorImpl.java:25)
> at java.lang.reflect.Method.invoke(Method.java:597)
> at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java: 549)
> 2011-02-17 21:36:45 INFO [main] [null:-1] Read license from: X:\MakeDoc\tmp\MakeDocSkeletonExported\_MakeDoc.key.1
> JJ
Mickael Istria -- BonitaSoft S.A.
http://www.bonitasoft.com/products/BPM_download.php
Re: java.lang.ClassCastException when running SWTBot tests in headless mode [message #655125 is a reply to message #654980] Fri, 18 February 2011 07:45 Go to previous messageGo to next message
Mickael thaks for your response, I performed a little investigation by the help of Osgi console with this result:
!ENTRY org.eclipse.osgi 2 0 2011-02-18 12:54:19.651
!MESSAGE The following is a complete list of bundles which are not resolved, see the prior log entry for the root cause if it exists:
!SUBENTRY 1 org.eclipse.osgi 2 0 2011-02-18 12:54:19.651
!MESSAGE Bundle update@plugins/org.eclipse.swtbot.ant.optional.junit4_2.0.2.20110117_1743-b492ddb-dev-e34.jar [1760] was not resolved.
!SUBENTRY 2 org.eclipse.swtbot.ant.optional.junit4 2 0 2011-02-18 12:54:19.651
!MESSAGE Constraints from the fragment conflict with the host: Require-Bundle: org.eclipse.core.runtime.compatibility; bundle-version="0.0.0"
!MESSAGE Constraints from the fragment conflict with the host: Require-Bundle: org.junit4; bundle-version="0.0.0"
When I try to switch to platform of exported rcp app with Eclipse IDE and add dependency of my test plugin to org.eclipse.swtbot.ant.optional.junit4 by adding this line to plugin's manifest
org.eclipse.swtbot.ant.optional.junit4;bundle-version="2.0.2",
I am getting
Unsatisfied version constraint: 'org.eclipse.swtbot.ant.optional.junit4: 2.0.2'
But I absolutly don't know why. The version included in target platform is org.eclipse.swtbot.ant.optional.junit4_2.0.2.20110117_1743-b 492ddb-dev-e34.jar
Note that org.eclipse.core.runtime.compatibility and org.junit4 are included in platform.
Interesting is that the exception from tests log (not console) looks like it has no dependency with unresolved bundles (JavaCastException in the target RCP app).
JJ
[Updated on: Fri, 18 February 2011 08:20] by Moderator
Re: java.lang.ClassCastException when running SWTBot tests in headless mode [message #655218 is a reply to message #655125] Fri, 18 February 2011 11:22 Go to previous messageGo to next message
You might be missing the dependencies of the
org.eclipse.swtbot.ant.optional.junit4 bundle.
I've documented tricks for figuring out some such things on the wiki
page at
http://wiki.eclipse.org/SWTBot/OSGi_Console#Diagnosing_missi ng_dependencies
Ketan
ketan.padegaonkar.name | eclipse.org/swtbot | @ketanpkr
On 2/18/11 4:45 AM, Jiri Janecek wrote:
> Michal thaks for your response, I performed a little investigation by
> !MESSAGE Bundle
> update@plugins /org.eclipse.swtbot.ant.optional.junit4_2.0.2.20110117_1743- b492ddb-dev-e34.jar
> 12:54:19.651
> 12:54:19.651
> manifest
> org.eclipse.swtbot.ant.optional.junit4;bundle-version="2.0.2 ",
> I am getting
> 2.0.2'
> 492ddb-dev-e34.jar
> JJ
Re: java.lang.ClassCastException when running SWTBot tests in headless mode [message #655224 is a reply to message #654980] Fri, 18 February 2011 12:19 Go to previous messageGo to next message
Hi Ketan,
thanks for reply, I tried to inspect missing dependencies. There were only missing constraints as you can read above. For this I found solution in this forum (ant optional fragment and host org.apache.ant in the same feature, thanks to Mickael Wink), so this is correct now.
My original idea was not to mix tests and app source code so this is not ideal for me. I would like to pick exported app, copy everything needed for tests and run tests. But it is still not working at the moment ...
I am actually getting could not find the plugin. When I run target RCP app, in About Dialog can see my test plugin ... Think this is the last step to get it working but don't know, what to do.
Relevat part of ant script:
<target name="suite" depends="path">
		<echo>******************************************************</echo>
    <echo>                Run GUI tests ...                     </echo>
    <property name="temp-workspace" value="workspace" />
      <delete dir="${temp-workspace}" quiet="true" />
    	<ant target="swtbot-test" antfile="${library-file}" dir="${eclipse-home}">
          <property name="data-dir" value="${temp-workspace}" />
          <property name="plugin-name" value="${plugin-name}" />
          <property name="classname" value="com.pike.panther.tests.GuiTests" />
          <property name="vmargs" value=" -Xms128M -Xmx368M -XX:MaxPermSize=256M" />
          <property name="os" value="win32"/>
          <property name="ws" value="win32"/>
          <property name="arch" value="x86"/>
          <property name="formatter" value="org.apache.tools.ant.taskdefs.optional.junit.XMLJUnitResultFormatter" />
          <property name="testApplication" value="MakeDocRCP.application"/>
          <property name="product" value="MakeDocRCP"/>
      </ant>
    </target>
JJ
Re: java.lang.ClassCastException when running SWTBot tests in headless mode [message #658027 is a reply to message #654980] Sat, 05 March 2011 03:29 Go to previous messageGo to next message
After some time I returned to GUI testing with SWTBot. I played with many scenarios to determine conditions when everything is working well.
Tested product includes one feature which contains custom plugins. As I said I wouldn;t like to mix tests and product code, so I created tests feature and added this feature as optional to feature which forms product. This feature is built separately from main build process.
Thanks to Mickael I know that it is necessary to have host org.apache.ant and fragment org.eclipse.swtbot.ant.optional.junit4 (together with org.junit4) in the same feature. But it seems that tests are working well if this plugins are included in original feature only. If not I am getting this:
If I manage to have everything in the test feature, tests become completely hidden from developers and they will not need to add swtbot bundles in their platforms.
Is there any way how to achieve this?
Thanks for your time.
JJ
Re: java.lang.ClassCastException when running SWTBot tests in headless mode [message #658054 is a reply to message #658027] Sat, 05 March 2011 11:37 Go to previous messageGo to next message
+1 so far. We have 2 product files, one for production(without test
features) and one with the test features and dependencies.
The only difference is that we build the production product after the
test product is built, which means that if the tests break, the
production build is never generated forcing devs to fix the problem as
soon as it is detected.
<snipped/>
[Putting my consultant hat on...]
This is unfortunately a people problem, and tools might be a bad idea to
solve them, to the point that people will start hating the tool.
I feel the correct way to address this issue would be to find out why
devs want to hide away the test bundles and encourage them to write very
simple tests to document the feature they are working on. These need not
cover any corner cases, but just go through some happy paths to ensure
that basic functionality works before checking in code.
A set of a handful of such smoke tests that run in under 2-3 minutes to
test basic features of the application to ensure that nothing obvious
has been broken before someone checks in can prove to be very valuable
to developers.
Ketan
http://ketan.padegaonkar.name | http://eclipse.org/swtbot | @ketanpkr
Re: java.lang.ClassCastException when running SWTBot tests in headless mode [message #658097 is a reply to message #654980] Sun, 06 March 2011 06:30 Go to previous messageGo to next message
Ok, understand. In the final phase I discovered one more problem. SWTBot tests are running on Hudson slave. Application is correctly started but will never get focus.
(this is not happening when I run test script manually from command line directly on hudson slave)
Thanks to this I am not able to use Autoit to bypass work with native dialogs.
It is working only if I add some sleep to test and after start manually click into app window but this is not acceptable in case of test automation.
Is there any workaround for this?
EDIT: Note that cursor is in the vm when application is starting
EDIT2: It seems that everything is working if cmd which runs slave has focus, interesting maybe it will help smb.
JJ
[Updated on: Sun, 06 March 2011 07:56] by Moderator
Re: java.lang.ClassCastException when running SWTBot tests in headless mode [message #658161 is a reply to message #658097] Mon, 07 March 2011 03:28 Go to previous messageGo to next message
If you are on Linux, a workaround is to start another X server dedicated to SWTBot tests, and to start instances of your app with SWTBot tests in this X server.
HTH
> JJ
Re: java.lang.ClassCastException when running SWTBot tests in headless mode [message #658162 is a reply to message #658027] Mon, 07 March 2011 03:31 Go to previous messageGo to next message
Do you also have the org.eclipse.core.runtime.compatibility bundle in your feature?
> !MESSAGE Bundle update@plugins /org.eclipse.swtbot.ant.optional.junit4_2.0.2.20110117_1743- b492ddb-dev-e34.jar [1760] was not resolved.
> JJ
Re: java.lang.ClassCastException when running SWTBot tests in headless mode [message #658189 is a reply to message #654980] Mon, 07 March 2011 05:42 Go to previous message
It is WXP machine Sad
Now I haven't complatibility plugin in my feature but tests are working. It is interesting but all is working if fragment and host are in the feature which forms our product. When I move tests and its deps to optional tests feature which is included in main feature it stops working. Now i am trying to create one more product and feature which is copy of main feature + tests and deps as Ketan said.
JJ
[Updated on: Mon, 07 March 2011 05:58] by Moderator
Previous Topic:swtbot find hyperlink
Next Topic:No "Run As - SwtBot Test" available after installation
Current Time: Wed Jul 23 05:34:18 EDT 2025
Powered by FUDForum. Page generated in 0.09729 seconds
