Cannot correctly install or use full headless buckminster [message #645879] |
Mon, 20 December 2010 17:14  |
Hello Buckminster People
Now that I have Buckminster working within Eclipse with GUI to build my RCP, I need to set it up to run headless to do a nice crossplatform build.
I have been trying to follow the steps on the wiki to set it up to no avail. I can use director to install the barebones buckminster as outlined here: http://www.eclipse.org/buckminster/downloads.html
When I then try to customize it, it fails. I have tried the following:
buckminster install http://download.eclipse.org/tools/buckminster/headless-3.6/ org.eclispe.buckminster.core.headless.feature
Nothing happens.
I have downloaded the zipped archive for the headless buckminster and for the subversive. I have tried installing from these locally with the same failure. I have unzipped them into the buckminster directory and also tried to install my svn connecters from a local eclipse install, and I have just copied them in as well.
When I do listcommands I only have listcommands, lscmds, install, listsite and uninstall (because my buckminster install doesn't know about all the other things I'm trying to install).
Any suggestions? Is there maybe just a nice zipped complete buckminster I can use?
thanks
Tamar
Re: Cannot correctly install or use full headless buckminster [message #646037 is a reply to message #645939] |
Tue, 21 December 2010 11:44  |
Thanks Thomas -- right after I posted I saw that line in the BuckyBook.
So my 4th time around doing the same exact steps for some reason things decided to work. I know this is not a helpful conclusion because I still do not understand why they didn't work in the first place -- I went back through my command buffer and ran the exact same commands (the buckminster install commands, actually) and it worked.
During this process I also experimented with --loglevel DEBUG -- not much information came back. When I run it normally withouth the loglevel set, I was getting no feedback either of success or failure; this may be a good addition.
Thanks to all for your help!
Tamar
FUDForum. Page generated in 0.04625 seconds
