Home » Eclipse Projects » SWTBot » SWTbot fails with RCP that takes arguments
SWTbot fails with RCP that takes arguments [message #644910] Tue, 14 December 2010 12:23 Go to next message
We have a RCP that can take command line arguments, if we get unknown arguments we throw an exception.
When we try to run SWTbot on the RCP we get that exception. Debugging show that our RCP get the following arguments:
[-keepalive, -version, 3, -port, 55255, -testLoaderClass, org.eclipse.jdt.internal.junit4.runner.JUnit4TestLoader, -loaderpluginname, org.eclipse.jdt.junit4.runtime, -classNames, BaseTest, -testApplication, app.gui.application, -testpluginname, MyTest]
Since these are unknown arguments, we get an exception.
The run configuration is pretty basic, instead of starting up the workbench, we start up the application. Like it has been suggested in all tutorials on the net.
Our code get the arguments from
org.eclipse.equinox.app.getArguments().get("application.args")
My guess: SWTBot adds application arguments but doesn't remove them before starting up the RCP application.
Re: SWTbot fails with RCP that takes arguments [message #645406 is a reply to message #644910] Thu, 16 December 2010 23:41 Go to previous messageGo to next message
Hi Fred,
You'd likely get a different set of arguments based on whether you're
debugging or running normally, your version of junit, and other things.
Eclipse normally does not error out on arguments it does not
understand(primarily so that other plugins can read those arguments and
do something interesting with them). SWTBot continues to follow this
philosophy and I'd suggest that your app does too.
This effectively means that you leave room for other plugins(including
swtbot) to be able to do interesting things with those arguments :)
Ketan
ketan.padegaonkar.name | eclipse.org/swtbot | @ketanpkr
> org.eclipse.equinox.app.getArguments().get("application.args ")
Re: SWTbot fails with RCP that takes arguments [message #645430 is a reply to message #645406] Fri, 17 December 2010 04:13 Go to previous message
Hi Ketan
Thanks for the reply, that confirms what we thought.
Since our RCP can be run in command line mode we need to be able to verify commands and warn the user when something is incorrect/misspelled. We will solve this with a property that will allow all arguments, this will let us run SWTbot.
Fred
Previous Topic:"getId" method?
Next Topic:CheckboxTreeViewer and grayedChecked
Current Time: Sat Jul 26 08:53:35 EDT 2025
Powered by FUDForum. Page generated in 0.03557 seconds
