Home » Eclipse Projects » Rich Client Platform (RCP) » Expand the properties popup menu
Expand the properties popup menu [message #636364] Sun, 31 October 2010 12:48 Go to next message
Hi everybody,
I'm trying to show other informations in the properties in my RCP ! By right-click over a file and pressing properties we normaly see informations like : Path, Type, Location, size, Last modified etc.. I'm adding some references to some files, and I would like to show this references in my properties ! I have a function which returns the references of a giving file ! Is that possible to realize this ??
thank you all !
Crombix.
Re: Expand the properties popup menu [message #636410 is a reply to message #636364] Mon, 01 November 2010 02:02 Go to previous messageGo to next message
On 31/10/10 10:18 PM, Crombix wrote:
> Hi everybody,
> thank you all !
> Crombix.
You can extend the properties view to show the content:
http://www.eclipse.org/articles/Article-Properties-View/prop erties-view.html
- Prakash
Platform UI Team, IBM
www.eclipse-tips.com
Re: Expand the properties popup menu [message #636457 is a reply to message #636364] Mon, 01 November 2010 08:54 Go to previous message
Crombix wrote:
> Hi everybody,
> thank you all !
And if you mean in the properties dialog, you can add a section to that
using org.eclipse.ui.propertyPages
Paul Webster
http://wiki.eclipse.org/Platform_Expression_Framework
http://help.eclipse.org/galileo/index.jsp?topic=/org.eclipse .platform.doc.isv/guide/workbench.htm
Previous Topic:Auto Refresh
Next Topic:How to add java project's classpath to a plug-in's classpath?
Current Time: Sat Jul 26 16:09:42 EDT 2025
Powered by FUDForum. Page generated in 0.04072 seconds
