Home » Eclipse Projects » SWTBot » Headless test report(the report file shows nothing)
Headless test report [message #636092] Fri, 29 October 2010 05:39 Go to next message
Sorry, I've solved my problem. CLOSED! Very Happy
[Updated on: Fri, 29 October 2010 06:30] by Moderator
Re: Headless test report [message #636158 is a reply to message #636092] Fri, 29 October 2010 09:11 Go to previous message
Did you get the xml outout reports ? If you did get the xml output
reports, then this target<http://goo.gl/wv9y> shows you how to generate
the report and fail the build if the tests failed.
Ketan
ketan.padegaonkar.name | eclipse.org/swtbot | @ketanpkr
On 10/29/10 2:40 AM, toni wrote:
> Hi Ketan and Everybody,
> I used ant to execute my headless test cases, the application was
> launched and the test went well. The report files were generated but
> (hmtl file) showed nothing, it showed no test case had been executed).
> Any mistake recommend?
> Toni
Previous Topic:Help with ANT [ Tutorial-Video ]
Next Topic:Howto: SWTHelloWorld with SWTBot?
Current Time: Sun Jul 27 13:03:50 EDT 2025
Powered by FUDForum. Page generated in 0.05177 seconds
