Is SWTBot working on Win7 64Bit? [message #629440] |
Tue, 28 September 2010 06:07  |
I am running on a Windows 7 64Bit machine. Have installed the latest installations of SWTBot in copy of Eclipse 3.6 (Helios), but can not seem to get any of the features. I created a simple hello world test with the "@RunWith(SWTBotJunit4ClassRunner.class)" annotation etc, but when I right click on the class, the only "Run As" options I get are the JUnit one's, also nothing under the Run Configuration.
Am I missing something or is SWTBot not supported on 64bit yet?
Re: Is SWTBot working on Win7 64Bit? [message #629503 is a reply to message #629440] |
Tue, 28 September 2010 09:57   |
The usual answer is: SWTBot runs in any platform that SWT runs on. There
is nothing platform-specific in SWTBot that I'm aware of.
I don't really know what's going on for you. Seems like SWTBot is
installed correctly since you don't have any compilation problem. May it
be that the UI plugin didn't install? Or maybe you are using a target
platform and SWTBot is installed in it and not on your running Eclipse?
Could you take a look in Help -> About Eclipse -> Installation Details?
In the Installed Software tab, you should have SWTBot for
[GEF|Eclipse|SWT] Testing, and in the Plug-ins tab you should have a
couples of org.eclipse.swtbot entries and
org.eclipse.swtbot.eclipse.core (or ui, I think, depending on your
version) should be there.
Hope this helps.
Pascal Gélinas | Software Developer
*Nu Echo Inc.*
http://www.nuecho.com/ | http://blog.nuecho.com/
*Because performance matters.*
FUDForum. Page generated in 0.05293 seconds
