Eclipse RCP + AspectJ + Equinox + ltw [message #601184] |
Tue, 17 August 2010 10:28  |
I'm currently trying to create a sample AspectJ + Eclipse RCP + ltw application. I would want to introduce AspectJ + oval.sourceforge.net to a pretty big RCP Project (+ 50 Plug-Ins and growing). And, despite being no newby to Eclipse RCP, am failing miserably :/
My last try was to use the demo provided by http://www.eclipse.org/equinox/incubator/aspects/equinox-asp ects-quick-start.php and get it running without modifications- no success.
Starting the hello.launch prints out
osgi> Hello World
the hello.aspect.launch prints out
info adding AspectJ hooks ...
osgi>
Then I
- created a simple sample Hello World RCP Plug-In,
- added all the required plugins (as defined in the quick start) to a launch configuration,
- corrected the Eclipse-SupplementBundle
- created a config.ini:
osgi.bundles=org.eclipse.equinox.common@2\:start,org.eclipse.update.configurator@3\:start,org.eclipse.core.runtime@start, org.eclipse.equinox.weaving.aspectj@4\:start
osgi.splashPath = platform:/base/plugins/org.eclipse.platform
osgi.framework.extensions=org.eclipse.equinox.weaving.hook
but all I get is a big error message (see end of post, org.eclipse.core.jobs is in the launch configuration).
What am I doing wrong? If you could point me to a working guide or some sample code I'd very glad too.
As I'm running out if time (already spent half a day ...), this forum is my last shot :/
cu and thx,
Jan
Error Message 1:
!SESSION 2010-08-17 16:03:52.364 -----------------------------------------------
eclipse.buildId=unknown
java.version=1.6.0_10-beta
BootLoader constants: OS=win32, ARCH=x86, WS=win32, NL=de_DE
Framework arguments: -application Test.application
Command-line arguments: -application Test.application -data C:\_env\workspace-aspectj-2/../runtime-Test.application -dev file:C:/_env/workspace-aspectj-2/.metadata/.plugins/org.ecli pse.pde.core/Test.application/dev.properties -os win32 -ws win32 -arch x86 -consoleLog
!ENTRY org.eclipse.core.runtime 4 0 2010-08-17 16:03:52.930
!MESSAGE
!STACK 0
org.osgi.framework.BundleException: The bundle could not be resolved. Reason: Missing Constraint: Require-Bundle: org.eclipse.core.jobs; bundle-version="[3.2.0,4.0.0)"
at org.eclipse.osgi.framework.internal.core.AbstractBundle.getR esolverError(AbstractBundle.java:1313)
at org.eclipse.osgi.framework.internal.core.AbstractBundle.getR esolutionFailureException(AbstractBundle.java:1297)
at org.eclipse.osgi.framework.internal.core.BundleHost.startWor ker(BundleHost.java:309)
at org.eclipse.osgi.framework.internal.core.AbstractBundle.resu me(AbstractBundle.java:370)
at org.eclipse.osgi.framework.internal.core.Framework.resumeBun dle(Framework.java:1068)
at org.eclipse.osgi.framework.internal.core.StartLevelManager.r esumeBundles(StartLevelManager.java:557)
at org.eclipse.osgi.framework.internal.core.StartLevelManager.i ncFWSL(StartLevelManager.java:464)
at org.eclipse.osgi.framework.internal.core.StartLevelManager.d oSetStartLevel(StartLevelManager.java:248)
at org.eclipse.osgi.framework.internal.core.StartLevelManager.d ispatchEvent(StartLevelManager.java:445)
at org.eclipse.osgi.framework.eventmgr.EventManager.dispatchEve nt(EventManager.java:227)
at org.eclipse.osgi.framework.eventmgr.EventManager$EventThread .run(EventManager.java:337)
!ENTRY org.eclipse.osgi 4 0 2010-08-17 16:03:52.939
!MESSAGE Bundle initial@reference:file:plugins/org.eclipse.core.runtime_3.5.0.v20090525.jar/ was not resolved.
!ENTRY org.eclipse.osgi 4 0 2010-08-17 16:03:52.947
!MESSAGE Application error
!STACK 1
java.lang.IllegalStateException: Unable to acquire application service. Ensure that the org.eclipse.core.runtime bundle is resolved and started (see config.ini).
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .start(EclipseAppLauncher.java:74)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:368)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:179)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java: 559)
at org.eclipse.equinox.launcher.Main.main(Main.java:1287)
!ENTRY org.eclipse.osgi 2 0 2010-08-17 16:03:52.958
!MESSAGE One or more bundles are not resolved because the following root constraints are not resolved:
!SUBENTRY 1 org.eclipse.osgi 2 0 2010-08-17 16:03:52.958
!SUBENTRY 2 org.eclipse.core.runtime 2 0 2010-08-17 16:03:52.958
!MESSAGE Missing required bundle org.eclipse.equinox.preferences_[3.2.0,4.0.0).
!SUBENTRY 2 org.eclipse.core.runtime 2 0 2010-08-17 16:03:52.959
!MESSAGE Missing required bundle org.eclipse.core.contenttype_[3.3.0,4.0.0).
!MESSAGE Missing required bundle org.eclipse.equinox.app_[1.0.0,2.0.0).
!MESSAGE Missing required bundle org.eclipse.equinox.registry_[3.4.0,4.0.0).
!MESSAGE Missing required bundle org.eclipse.core.jobs_[3.2.0,4.0.0).
!ENTRY org.eclipse.osgi 2 0 2010-08-17 16:03:52.962
!MESSAGE The following is a complete list of bundles which are not resolved, see the prior log entry for the root cause if it exists:
!SUBENTRY 1 org.eclipse.osgi 2 0 2010-08-17 16:03:52.963
!MESSAGE Bundle org.eclipse.core.runtime_3.5.0.v20090525 [9] was not resolved.
!SUBENTRY 2 org.eclipse.core.runtime 2 0 2010-08-17 16:03:52.963
!SUBENTRY 2 org.eclipse.core.runtime 2 0 2010-08-17 16:03:52.964
!MESSAGE Missing optionally required bundle org.eclipse.core.runtime.compatibility.auth_[3.2.0,4.0.0).
!MESSAGE Missing imported package org.eclipse.core.internal.runtime.auth_0.0.0.
Re: Eclipse RCP + AspectJ + Equinox + ltw [message #601193 is a reply to message #601184] |
Wed, 18 August 2010 14:28  |
It looks like you are missing some required bundles in your configuration:
You need to add these bundles to the configuration and try again.
FUDForum. Page generated in 0.29016 seconds
