Home » Archived » EPF » How to build EPF from source
How to build EPF from source [message #31214] Thu, 29 March 2007 05:23 Go to next message
I would like to build and start epf from source so that I can follow the
program flow in debugging mode for better understanding the sources.
I downloaded the epf from source and tried to launch the application via
org.eclipse.epf.rcp -> META-INF -> MANIFEST.MF -> Lauchn eclipse
application, but all I get is a standard eclipse workbench ui. I also
tried the same with other possible "Main Plugins" and was not successfull.
Can someone please give me a hint how to start epf in debug mode?
Kris
Re: How to build EPF from source [message #31318 is a reply to message #31214] Fri, 30 March 2007 12:07 Go to previous message
Originally posted by: storaskar.xx.xxx.xxx
Here is the information how to set up EPF in development environment and
run
http://www.eclipse.org/epf/composer_dev_guide/
http://www.eclipse.org/epf/composer_dev_guide/run_debug.php
Cheers
Shilpa
Re: How to build EPF from source [message #577421 is a reply to message #31214] Fri, 30 March 2007 12:07 Go to previous message
run
Cheers
Shilpa
Previous Topic:Cannot reference a new plug-in?
Next Topic:Problems when exporting data (WBS, actors) from EPF composer
Current Time: Sun Oct 19 09:42:37 EDT 2025
Powered by FUDForum. Page generated in 0.03257 seconds
