Home » Eclipse Projects » SWTBot » Why is a menu item disabled when using SWTBot?
Why is a menu item disabled when using SWTBot? [message #558874] Tue, 14 September 2010 13:00 Go to next message
I've posted a question about SWTBot ( http://stackoverflow.com/questions/3706225/why-is-a-menu-ite m-disabled-when-using-swtbot) with the same title as this thread to stackoverflow. Please feel free to either reply to this message or post your answers on stackoverflow.com.
icon5.gif  Re: Why is a menu item disabled when using SWTBot? [message #559514 is a reply to message #558874] Thu, 16 September 2010 19:26 Go to previous messageGo to next message
The following is my piece of code that tries to invoke the extract method refactoring. Please let me know if you find anything wrong with the way I'm having SWTBot invoke this refactoring. The whole test class is available at our repository.
@Test
public void shouldExtractMethod() throws Exception {
	SWTBotEclipseEditor editor= bot.editorByTitle(TEST_NAME + ".java").toTextEditor();
	editor.setFocus();
	// editor.selectLine(5);
	editor.selectRange(5, 2, 37 - 9);
	System.out.println(editor.getSelection());
	System.out.println(editor.cursorPosition());
	SWTBotMenu extractMethodMenuItem= bot.menu("Refactor").menu("Extract Method...");
	//FIXME: The following assertion fails.
	assertTrue(extractMethodMenuItem.isEnabled());
	extractMethodMenuItem.click();
	// editor.pressShortcut(Keystrokes.SHIFT, Keystrokes.ALT,
	// KeyStroke.getInstance("M"));
	bot.shell("Extract Method").activate();
	bot.textWithLabel("Method name:").setText("m");
	bot.button("OK").click();
	bot.sleep(200000);
Re: Why is a menu item disabled when using SWTBot? [message #559516 is a reply to message #558874] Thu, 16 September 2010 19:52 Go to previous messageGo to next message
Mohsen Vakilian wrote on Tue, 14 September 2010 13:00
I also posted something similar (some options on property pages are disabled) here: http://www.eclipse.org/forums/index.php?t=msg&th=175593
Re: Why is a menu item disabled when using SWTBot? [message #559553 is a reply to message #558874] Fri, 17 September 2010 03:26 Go to previous messageGo to next message
are you sure that your menu shouldn't be disabled?
You can check the activeWhen option on the menu/handler.
On the screenshot is the menu really disabled?
regards,
icon5.gif  Re: Why is a menu item disabled when using SWTBot? [message #559726 is a reply to message #559553] Fri, 17 September 2010 13:16 Go to previous messageGo to next message
Yes, I'm sure the menu item shouldn't be disabled, because when I follow the script manually, the menu item is enabled.
I've uploaded the screenshot taken by SWTBot at http://i51.tinypic.com/annb75.jpg
SWTBot doesn't open the menus. So, we cannot tell from the screenshot if the "extract method" refactoring is enabled. But, the failure of the following assertion shows that this menu item is actually disabled.
Re: Why is a menu item disabled when using SWTBot? [message #559759 is a reply to message #559514] Fri, 17 September 2010 18:52 Go to previous messageGo to next message
Just wanted to mention that our SWTBot test has moved to a new location. So, if you need to take a look at the whole source code to debug it, please refer to the new location.
Re: Why is a menu item disabled when using SWTBot? [message #630466 is a reply to message #559726] Sat, 02 October 2010 19:52 Go to previous messageGo to next message
We haven't heard back from anyone about ways to troubleshoot our problem. So, we decided to update you about our progress.
We've been able to fire other refactorings like Extract Constant and Inline constant using SWTBot.
We believe that the problem with invoking the Extract Method refactoring through SWTBot is that it's the only (AFAIK) refactoring that has an enabled/disabled state from the Refactor menu. It tries to check if something is actually selected in the text editor before it enables itself from the menu. Somehow the way SWTBot selects the text in the editor does not communicate it back properly to the Extract Method action item. We believe that this is the problem.
Re: Why is a menu item disabled when using SWTBot? [message #631106 is a reply to message #630466] Wed, 06 October 2010 04:29 Go to previous messageGo to next message
Hello Mohsen,
SWTBotEclipseEditor.selectRange() and selectLine() methods are asynchronous
so you should have a wait condition immediately after the select which checks
for the cursor position before doing anything else (like clicking a context
menu) - the cursor should be positioned at the beginning of the selection.
An example code from one of our tests:
programEditor.selectLine(3);
waitForCursorPosition(programEditor, 3, 0);
programEditor.pressShortcut(Keystrokes.DELETE);
Thanks!
Petar P
Re: Why is a menu item disabled when using SWTBot? [message #631238 is a reply to message #631106] Wed, 06 October 2010 11:51 Go to previous message
Originally posted by: nchen.illinois.edu
On 2010-10-06 03:29:17 -0500, Petar Petrov said:
> Hello Mohsen,
> asynchronous so you should have a wait condition immediately after the
> select which checks for the cursor position before doing anything else
> (like clicking a context menu) - the cursor should be positioned at the
> beginning of the selection. An example code from one of our tests:
> Thanks!
> Petar P
Hi Petar
Thanks for the response. We have tried it (and maybe I'm doing
something wrong below) but that still does not allow the Extract Method
refactoring to be invoked. As Mohsen mentioned, this is the only
refactoring that we have encountered so far that cannot be selected
using the way we have below.
Here is the relevant code snippet:
protected void prepareRefactoring() {
final SWTBotEclipseEditor editor= bot.editorByTitle(TEST_FILE_NAME +
// Extract Method Refactoring
editor.setFocus();
final int cursorLinePosition= 5;
final int cursorColumnBeginPosition= 8;
int cursorColumnEndPosition= 36;
editor.selectRange(cursorLinePosition, cursorColumnBeginPosition,
cursorColumnEndPosition - cursorColumnBeginPosition);
DefaultCondition condition= new DefaultCondition() {
public boolean test() throws Exception {
return editor.cursorPosition().line == cursorLinePosition;
public String getFailureMessage() {
return "Cannot update cursor position in editor";
bot.waitUntil(condition, 5000, 100);
System.out.println("Cursor position:" + editor.cursorPosition());
SWTBotMenu refactorMenu= bot.menu("Refactor");
assertTrue(refactorMenu.isEnabled());
SWTBotMenu extractMethodMenuItem= refactorMenu.menu("Extract Method...");
The System.out.println("Cursor position:" + editor.cursorPosition());
shows that the cursor is at the right position but the
assertTrue(extractMethodMenuItem.isEnabled()) statement still fails.
Am I using the waitUntil(...) method wrongly?
Thank you.
Nick Chen
Previous Topic:Direct Edit a GEF edit part with TextFlow
Next Topic:how to click a Coolbar item in SWTbot
Current Time: Sat Nov 22 15:57:59 EST 2025
Powered by FUDForum. Page generated in 0.04977 seconds
